JLG Scissor Lift RT3394 RT4394 Service & Maintenance Manual 3122566000 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT3394, RT4394 Scissor Lift
Part Number: 3122566000
Publication Date: 2025
Number of Pages: 382 Pages
Coverpage
Effectivity Page
Safety
Brand: JLG
Coverpage
Effectivity Page
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Generator Specifications (If Equipped)
2.1.3 Dimensional Data
2.1.4 Drive Information
2.1.5 Steering Information
2.1.6 Tires
2.1.7 Critical Stability Weights
2.1.8 Hydraulic Pressure Settings
2.1.9 Hydraulic Cylinder Specifications
2.1.10 Engine Specifications
2.1.11 Gear Pump
2.1.12 Axial HI 45 Pump
Serial Number Locations
Fluids and Lubrication
2.3.1 Hydraulic System
2.3.2 Hydraulic Oil
2.3.3 Lubrication
2.3.4 Changing Hydraulic Oil
2.3.5 Lubrication Specifications
2.3.6 Fluid Capacities
2.3.7 Hydraulic Oil Specifications
2.3.8 Elevation/Tilt Limit Settings
Clearsky Smart Fleet (If Equipped)
2.4.1 General
2.4.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventative Maintenance
Service and Guidelines
Service Maintenance Components
3.3.1 General Maintenance Tips
3.3.2 Fuel Tank
3.3.3 Drive Hub
3.3.4 Scissor Arms - Sliding Wear Pads
3.3.5 Hydraulic Oil Tank
3.3.6 Hydraulic Charge Filter
3.3.7 Oil Change with Filter
3.3.8 Fuel/Water Separator Filter (Diesel) - Kubota
3.3.9 Fuel Strainer (Diesel) - Kubota
3.3.10 Fuel Filter (Gas) - Kubota
3.3.11 Air Filter
3.3.12 Engine Coolant
Preventive Maintenance and Inspection Schedule
3.4.1 Maintenance and Inspection Schedule Codes
Pins and Composite Bearing Repair Guidelines
Tires & Wheels
3.6.1 Tire Damage
3.6.2 Tire Replacement
3.6.3 Wheel Replacement
Drive Motor (Hengli) Inspection
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Drive Hub
Testing Procedures
4.2.1 Preparation
4.2.2 Testing LSS Control System Warnings and Interlocks:
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:
4.2.4 Testing LSS Platform Load Reading with a Known Weight:
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
Special Procedures
4.4.1 Setting Scissor Arm Safety Prop
4.4.2 Drive Pump Pre-Fill Procedure
4.4.3 Drive Pump Start-Up Procedure
4.4.4 Joystick Controller
4.4.5 Re-Aligning Torque Hub Input Coupling
4.4.6 AXIAL HI 45 Pump
4.4.7 Cylinder Checking Procedure
4.4.8 Cylinder Drift Test
4.4.9 Oscillating Axle Cylinder Bleeding Procedure
4.4.10 Hydraulic Component Start-Up Procedures and Recommendations
Service Mode Procedures
4.5.1 ECM Override (Dual Fuel Only)
4.5.2 Elevation Service
4.5.3 EEPROM Reset
4.5.4 Allow Drive
4.5.5 Allow Leveling Jack Retract
Operating Characteristics
4.6.1 Leveling Jacks (If Equipped)
4.6.2 Generator
4.6.3 Lift
4.6.4 Drive
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Diagnostic Menu
5.1.3 Personalities
5.1.4 Machine Setup Menu
5.1.5 Service
JLG Analyzer
5.2.1 Analyzer
5.2.2 Connecting the Analyzer
5.2.3 Using the Analyzer
5.2.4 Changing the Access Level
5.2.5 Adjusting Parameters
5.2.6 Machine Setup
5.2.7 Analyzer Menu Flow Chart
5.2.8 Connecting The JLG Control System Analyzer
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostic
5.3.3 Machine Configuration and Programming Settings
Machine Configuration Programming Information
Machine Tilt Configuration
Machine Model Personality Adjustment
ClearSky (CS550) Configuration and Troubleshooting
5.7.1 ClearSky Smart FleetTM CS550 Configuration
5.7.2 Troubleshooting
Fault CodesIntroduction
6.1.1 System Fault/DTC Indication
Diagnostic Trouble Codes (DTC)
DTC Check Tables
6.3.1 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description
6.3.2 Help Menu and Fault Codes
6.3.3 ClearSky Smart Fleet DTC Fault Codes
6.3.4 LSS Troubleshooting
6.3.5 Drive Motor (Sauer) Troubleshooting
HydraulicsTheories of operation
7.1.1 Cylinders - Theory of Operation
7.1.2 Valves - Theory of Operation
Hydraulic Components
Torque Values
7.3.1 Lift Cylinder
7.3.2 Holding Valve
7.3.3 Main Valve
Hydraulic Diagram
7.4.1 All Specs Except CE, UKCA and Japanese
7.4.2 For CE, UKCA and Japanese Specs
7.4.3 Leveling Jack
ElectricalsGeneral Information
8.1.1 General
8.1.2 Applying Silicone Dielectric Compound to Electrical Connections
8.1.3 Dielectric Grease Application
8.1.4 AMP Mate-N-Lok
8.1.5 AMP Faston
8.1.6 AMP Micro-Fit
8.1.7 AMP Mini Fit Jr
8.1.8 Mini Fit Sr
8.1.9 DIN Connectors
8.1.10 Exceptions
Electrical Connectors
8.2.1 DT/DTP Series Assembly
8.2.2 DT/DTP Series Disassembly
8.2.3 HD30/HDP20 Series Assembly
8.2.4 HD30/HDP20 Series Disassembly
AMP Connector
8.3.1 Assembly
8.3.2 Disassembly
8.3.3 Wedge Lock
8.3.4 Service - Voltage Reading
Switches
8.4.1 Basic Check
8.4.2 Limit Switches
8.4.3 Automatic Switches
8.4.4 Switch Wiring - Low Side, High Side
Location of Additional Sensors
Board Layouts
8.6.1 Jack/Option Control Module Pin Connections
Removal and InstallationWheels
9.1.1 Wheel Installation
Battery
9.2.1 REMOVAL
9.2.2 INSTALLATION
Tilt Sensor
9.3.1 Removal
9.3.2 Installation
Ground Control Station
9.4.1 Control Station
9.4.2 Options Control Module
Hydraulic Tank
9.5.1 REMOVAL
9.5.2 INSTALLATION
Scissor Arms
9.6.1 Scissor Arms
9.6.2 Scissor Arms Assembly
Platform
9.7.1 REMOVAL
9.7.2 INSTALLATION
Axle Installation
9.8.1 Removal
9.8.2 Assembly
Leveling Jacks
9.9.1 Leveling Jack Assembly
9.9.2 Leveling Jack Cylinder
Side Compartment Covers
9.10.1 Cover Removal
9.10.2 Cover Installation
9.11.1 REMOVAL
9.11.2 INSTALLATION
Kubota Engine
9.12.1 Engine Tray - Swing Out
9.12.2 Engine Removal and Installation
9.12.3 Dual Fuel/LPG System
9.12.4 Changing From Gasoline to LP Gas
9.12.5 Changing From LP Gas to Gasoline
9.12.6 Using Liquid Petroleum (LP) Gas
9.12.7 Propane Fuel System Pressure Relief
9.12.8 Propane Fuel System Leak Test
9.12.9 Generator (if equipped)
9.12.10 Exhaust System
9.12.11 Dual Fuel - Gas/LPG
9.12.12 Diesel
9.12.13 Air Cleaner System
9.12.14 Radiator
9.12.15 Engine Electrical Component Locations
9.12.16 Hydraulic Pump
9.12.17 Pump Coupling Assembly
9.12.18 Engine Speed Sensor (Kubota Diesel Engine)
9.12.19 Throttle Actuator Adjustment
9.12.20 Air Gap Setting
9.12.21 Diagnosis of Actuator
9.12.22 Adjustment of the Actuator
9.12.23 Adjustment Verification of Actuator
9.13.1 Drive Motor - Removal/Installation
9.13.2 Drive Assembly
Hydraulic Valves
9.14.1 Main Hydraulic Valve
9.14.2 Main Hydraulic Valve (CE/UKCA Only)
9.14.3 Flow Divider Valve
9.14.4 Leveling Jack Directional Valve (If Equipped)
9.14.5 Leveling Jack Valves (If Equipped)
9.14.6 Leveling Jack Manifold Valve (If Equipped)
9.14.7 Pressure Relief Valve - Setting Procedures
Charge Pump Filter
9.15.1 REMOVAL
9.15.2 INSTALLATION
Steer Installation
9.16.1 Steer Installation (All Markets Except for CE, UKCA and Japan)
9.16.2 Steer Installation (CE, UKCA and Japan Markets)
9.16.3 Axle Lockout Cylinder
Lift Cylinder
9.17.1 REMOVAL
9.17.2 INSTALLATION
Ladder Assembly
9.18.1 Removal
9.18.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.19.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Motor (Hengli)
Scissor Arm Assembly
10.2.1 Scissor Arm Assembly
Platform Control Station
10.4.1 Ground Control Station Components
Axial HI 45 Pump
10.5.1 Electric Control Module
10.5.2 Control Solenoids
10.5.3 Shaft Seal, Roller Bearing & Shaft Replacement
10.5.4 Charge Pump
10.5.5 Charge Check/HPRV
10.5.6 Charge Pressure Relief Valve
10.5.7 Pressure Limiter Valve Replacement
Hydraulic Cylinder
Cylinder Repair
10.7.1 Disassembly
10.7.2 Cleaning and Inspection
10.7.3 Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.8 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.9 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.10 Assembly Instructions for 45° SAE Flare Fittings
11.1.11 Assembly Instructions for O-ring Face Seal (ORFS) Fittings
11.1.12 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.13 Assembly Instructions for Bulkhead (BH) Fittings
11.1.14 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.15 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.16 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.17 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.18 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.19 Double Wrench Method
11.1.20 FFWR and TFFT Methods
11.1.21 Adjustable Stud End Assembly
11.1.22 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
