Hyundai
86
176,834
JLG Scissor Lift RT3394 RT4394 Service & Maintenance Manual 31221545 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT3394, RT4394 Scissor Lift
Part Number: 31221545
Publication Date: 2025
Number of Pages: 372 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Generator Specifications (If Equipped)​
2.1.3 Dimensional Data​
2.1.4 Drive Information​
2.1.5 Steering Information​
2.1.6 Tires​
2.1.7 Critical Stability Weights​
2.1.8 Hydraulic Pressure Settings​
2.1.9 Hydraulic Cylinder Specifications​
2.1.10 Engine Specifications​
2.1.11 Gear Pump​
2.1.12 Axial HI 45 Pump​
Serial Number Locations​
Fluids and Lubrication​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Lubrication​
2.3.4 Changing Hydraulic Oil​
2.3.5 Lubrication Specifications​
2.3.6 Fluid Capacities​
2.3.7 Hydraulic Oil Specifications​
2.3.8 Elevation/Tilt Limit Settings​
Clearsky Smart Fleet (If Equipped)​
2.4.1 General​
2.4.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Service and Guidelines​
Service Maintenance Components​
3.3.1 General Maintenance Tips​
3.3.2 Fuel Tank​
3.3.3 Drive Hub​
3.3.4 Scissor Arms - Sliding Wear Pads​
3.3.5 Hydraulic Oil Tank​
3.3.6 Hydraulic Charge Filter​
3.3.7 Oil Change with Filter​
3.3.8 Fuel/Water Separator Filter (Diesel) - Kubota​
3.3.9 Fuel Strainer (Diesel) - Kubota​
3.3.10 Fuel Filter (Gas) - Kubota​
3.3.11 Air Filter​
3.3.12 Engine Coolant​
Preventive Maintenance and Inspection Schedule​
3.4.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines​
Tires & Wheels​
3.6.1 Tire Damage​
3.6.2 Tire Replacement​
3.6.3 Wheel Replacement​
Drive Motor (Hengli) Inspection​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Drive Hub​
Testing Procedures​
4.2.1 Preparation​
4.2.2 Testing LSS Control System Warnings and Interlocks:​
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:​
4.2.4 Testing LSS Platform Load Reading with a Known Weight:​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
Special Procedures​
4.4.1 Setting Scissor Arm Safety Prop​
4.4.2 Drive Pump Pre-Fill Procedure​
4.4.3 Drive Pump Start-Up Procedure​
4.4.4 Joystick Controller​
4.4.5 Re-Aligning Torque Hub Input Coupling​
4.4.6 AXIAL HI 45 Pump​
4.4.7 Cylinder Checking Procedure​
4.4.8 Cylinder Drift Test​
4.4.9 Oscillating Axle Cylinder Bleeding Procedure​
4.4.10 Hydraulic Component Start-Up Procedures and Recommendations​
Service Mode Procedures​
4.5.1 ECM Override (Dual Fuel Only)​
4.5.2 Elevation Service​
4.5.3 EEPROM Reset​
4.5.4 Allow Drive​
4.5.5 Allow Leveling Jack Retract​
Operating Characteristics​
4.6.1 Leveling Jacks (If Equipped)​
4.6.2 Generator​
4.6.3 Lift​
4.6.4 Drive​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Diagnostic Menu​
5.1.3 Personalities​
5.1.4 Machine Setup Menu​
5.1.5 Service​
JLG Analyzer​
5.2.1 Analyzer​
5.2.2 Connecting the Analyzer​
5.2.3 Using the Analyzer​
5.2.4 Changing the Access Level​
5.2.5 Adjusting Parameters​
5.2.6 Machine Setup​
5.2.7 Analyzer Menu Flow Chart​
5.2.8 Connecting The JLG Control System Analyzer​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostic​
5.3.3 Machine Configuration and Programming Settings​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC)​
DTC Check Tables​
6.3.1 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description​
6.3.2 Help Menu and Fault Codes​
6.3.3 ClearSky Smart Fleet DTC Fault Codes​
6.3.4 LSS Troubleshooting​
6.3.5 Drive Motor (Sauer) Troubleshooting​
Hydraulics
Theories of operation​
7.1.1 Cylinders - Theory of Operation​
7.1.2 Valves - Theory of Operation​
Hydraulic Components​
Torque Values​
7.3.1 Lift Cylinder​
7.3.2 Holding Valve​
7.3.3 Main Valve​
Hydraulic Diagram​
7.4.1 All Specs Except CE, UKCA and Japanese​
7.4.2 For CE, UKCA and Japanese Specs​
7.4.3 Leveling Jack​
Electricals
General Information​
8.1.1 General​
8.1.2 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Dielectric Grease Application​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
Electrical Connectors​
8.2.1 DT/DTP Series Assembly​
8.2.2 DT/DTP Series Disassembly​
8.2.3 HD30/HDP20 Series Assembly​
8.2.4 HD30/HDP20 Series Disassembly​
AMP Connector​
8.3.1 Assembly​
8.3.2 Disassembly​
8.3.3 Wedge Lock​
8.3.4 Service - Voltage Reading​
Switches​
8.4.1 Basic Check​
8.4.2 Limit Switches​
8.4.3 Automatic Switches​
8.4.4 Switch Wiring - Low Side, High Side​
Location of Additional Sensors​
Board Layouts​
8.6.1 Jack/Option Control Module Pin Connections​
Removal and Installation
Wheels​
9.1.1 Wheel Installation​
Battery​
9.2.1 REMOVAL​
9.2.2 INSTALLATION​
Tilt Sensor​
9.3.1 Removal​
9.3.2 Installation​
Ground Control Station​
9.4.1 Control Station​
9.4.2 Options Control Module​
Hydraulic Tank​
9.5.1 REMOVAL​
9.5.2 INSTALLATION​
Scissor Arms​
9.6.1 Scissor Arms​
9.6.2 Scissor Arms Assembly​
Platform​
9.7.1 REMOVAL​
9.7.2 INSTALLATION​
Axle Installation​
9.8.1 Removal​
9.8.2 Assembly​
Leveling Jacks​
9.9.1 Leveling Jack Assembly​
9.9.2 Leveling Jack Cylinder​
Side Compartment Covers​
9.10.1 Cover Removal​
9.10.2 Cover Installation​
Fuel Tank​
9.11.1 REMOVAL​
9.11.2 INSTALLATION​
Kubota Engine​
9.12.1 Engine Tray - Swing Out​
9.12.2 Engine Removal and Installation​
9.12.3 Dual Fuel/LPG System​
9.12.4 Changing From Gasoline to LP Gas​
9.12.5 Changing From LP Gas to Gasoline​
9.12.6 Using Liquid Petroleum (LP) Gas​
9.12.7 Propane Fuel System Pressure Relief​
9.12.8 Propane Fuel System Leak Test​
9.12.9 Generator (if equipped)​
9.12.10 Exhaust System​
9.12.11 Dual Fuel - Gas/LPG​
9.12.12 Diesel​
9.12.13 Air Cleaner System​
9.12.14 Radiator​
9.12.15 Engine Electrical Component Locations​
9.12.16 Hydraulic Pump Installation​
9.12.17 Pump Coupling Assembly​
9.12.18 Engine Speed Sensor (Kubota Diesel Engine)​
9.12.19 Throttle Actuator Adjustment​
9.12.20 Air Gap Setting​
9.12.21 Diagnosis of Actuator​
9.12.22 Adjustment of the Actuator​
9.12.23 Adjustment Verification of Actuator​
Drive Motor (Hengli)​
9.13.1 Drive Motor - Removal/Installation​
9.13.2 Drive Assembly​
Hydraulic Valves​
9.14.1 Main Hydraulic Valve​
9.14.2 Main Hydraulic Valve (CE/UKCA Only)​
9.14.3 Flow Divider Valve​
9.14.4 Leveling Jack Directional Valve (If Equipped)​
9.14.5 Leveling Jack Valves (If Equipped)​
9.14.6 Leveling Jack Manifold Valve (If Equipped)​
9.14.7 Pressure Relief Valve - Setting Procedures​
Charge Pump Filter​
9.15.1 REMOVAL​
9.15.2 INSTALLATION​
Steer Installation​
9.16.1 Steer Installation (All Markets Except for CE, UKCA and Japan)​
9.16.2 Steer Installation (CE, UKCA and Japan Markets)​
9.16.3 Axle Lockout Cylinder​
Lift Cylinder​
9.17.1 REMOVAL​
9.17.2 INSTALLATION​
Ladder Assembly​
9.18.1 Removal​
9.18.2 Installation​
9.19.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor (Hengli)​
Scissor Arm Assembly​
10.2.1 Scissor Arm Assembly​
Platform Control Station​
10.4.1 Ground Control Station Components​
Axial HI 45 Pump​
10.5.1 Electric Control Module​
10.5.2 Control Solenoids​
10.5.3 Shaft Seal, Roller Bearing & Shaft Replacement​
10.5.4 Charge Pump​
10.5.5 Charge Check/HPRV​
10.5.6 Charge Pressure Relief Valve​
10.5.7 Pressure Limiter Valve Replacement​
Hydraulic Cylinders​
Cylinder Repair​
10.7.1 Disassembly​
10.7.2 Cleaning and Inspection​
10.7.3 Assembly​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.8 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.9 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.10 Assembly Instructions for 45° SAE Flare Fittings​
11.1.11 Assembly Instructions for O-ring Face Seal (ORFS) Fittings​
11.1.12 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.13 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.14 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.15 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.16 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.17 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.18 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.19 Double Wrench Method​
11.1.20 FFWR and TFFT Methods​
11.1.21 Adjustable Stud End Assembly​
11.1.22 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
