JLG Scissor Lift RT3394 RT4394 Parts Manual 3122566100
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT3394, RT4394 Scissor Lift
Part Number: 3122566100
Publication Date: 2025
Number of Pages: 374 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION
FIGURE 1-2. STEER INSTALLATION (ALL SPECS EXCEPT CE AND JAPANESE SPECS)
FIGURE 1-3. STEER INSTALLTION (CE, JAPANESE & UK CA SPECS)
FIGURE 1-4. WHEEL DRIVE INSTALLATION
FIGURE 1-5. DRIVE HUB ASSEMBLY - FRONT
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR
FIGURE 1-7. DRIVE MOTOR ASSEMBLY
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM-FILLED NON MARKING
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 33/16LL X 16.1 FOAM-FILLED
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 33/1550-16.5 FOAM-FILLED
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - IN315/55D20 FOAM-FILLED
FIGURE 1-13. BEACON/STROBE LIGHT INSTALLATION (AMBER) (WITHOUT CLEARSKY BEACON CS550)
FIGURE 1-14. LEVELING JACKS INSTALLATION
FIGURE 1-15. LEVELING JACKS ASSEMBLY
FIGURE 1-16. LEVELING JACKS VALVE ASSEMBLY
SECTION 2 - GROUND CONTROLSFIGURE 2-1. VALVES INSTALLATION (ALL SPECS EXCEPT CE AND JAPANESE SPECS)
FIGURE 2-2. VALVES INSTALLATION (CE, JAPANESE & UK CA SPECS)
FIGURE 2-3. MAIN VALVE ASSEMBLY (ALL SPECS EXCEPT CE, JAPANESE & UK CA SPECS)
FIGURE 2-4. MAIN VALVE ASSEMBLY (CE, JAPANESE & UK CA SPECS)
FIGURE 2-5. FLOW DIVIDER VALVE ASSEMBLY
FIGURE 2-6. TANKS AND HORN INSTALLATION (DIESEL MACHINES)
FIGURE 2-7. TANKS AND HORN INSTALLATION (GAS MACHINES)
FIGURE 2-8. HYDRAULIC TANK ASSEMBLY
FIGURE 2-9. GROUND CONTROL BOX ASSEMBLY (DIESEL MACHINES)
FIGURE 2-10. GROUND CONTROL BOX ASSEMBLY (GAS MACHINES)
FIGURE 2-11. MOTION ALARM INSTALLATION
FIGURE 2-12. HOODS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION - KUBOTA DIESEL T4F
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL E4B
FIGURE 3-3. ENGINE ASSEMBLY - KUBOTA DIESEL E4B
FIGURE 3-4. ENGINE INSTALLATION - KUBOTA DIESEL STAGE T4F WITH GENERATOR
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL E4B WITH GENERATOR
FIGURE 3-6. ENGINE ASSEMBLY - KUBOTA DIESEL E4B WITH GENERATOR
FIGURE 3-7. ENGINE COMPONENTS - KUBOTA DIESEL E4B
FIGURE 3-8. ENGINE INSTALLATION - KUBOTA GASOLINE
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-10. ENGINE ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-11. ENGINE INSTALLATION - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-13. ENGINE ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-14. ENGINE COMPONENTS - KUBOTA GASOLINE
FIGURE 3-15. FUEL/WATER SEPARATOR ASSEMBLY - DIESEL ENGINES
FIGURE 3-16. COUPLING KIT - DIESEL ENGINES
FIGURE 3-17. COUPLING KIT - GASOLINE ENGINES
FIGURE 3-18. PISTON PUMP ASSEMBLY
FIGURE 3-19. 7500W GENERATOR INSTALLATION - 50HZ (KUBOTA DIESEL)
FIGURE 3-20. 7500W GENERATOR INSTALLATION - 60HZ (KUBOTA DIESEL)
FIGURE 3-21. 7500W GENERATOR INSTALLATION - 60HZ (KUBOTA GASOLINE)
FIGURE 3-22. 4000W GENERATOR INSTALLATION - 50HZ (KUBOTA DIESEL)
FIGURE 3-23. 4000W GENERATOR INSTALLATION - 60HZ (KUBOTA DIESEL)
FIGURE 3-24. 4000W GENERATOR INSTALLATION - 60HZ (KUBOTA DUAL FUEL)
FIGURE 3-25. JUNCTION BOX ASSEMBLY - 4000W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 3-26. JUNCTION BOX ASSEMBLY - 7500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 3-27. JUNCTION BOX ASSEMBLY - 4000W/7500W GENERATOR (AUSTRALIAN, CE & UK CA SPECS)
FIGURE 3-28. QUICKFIT OIL DRAIN INSTALLATION - KUBOTA DIESEL ENGINE
FIGURE 3-29. QUICKFIT OIL DRAIN INSTALLATION - KUBOTA GASOLINE ENGINE
SECTION 4 - SCISSORS ARMSFIGURE 4-1. SCISSORS ARMS INSTALLATION (RT3394)
FIGURE 4-2. SCISSORS ARMS ASSEMBLY (RT3394)
FIGURE 4-3. SCISSORS ARMS INSTALLATION - WITH GENERATOR (RT3394)
FIGURE 4-4. SCISSORS ARMS ASSEMBLY - WITH GENERATOR (RT3394)
FIGURE 4-5. SCISSORS ARMS INSTALLATION (RT4394)
FIGURE 4-6. SCISSORS ARMS ASSEMBLY (RT4394)
FIGURE 4-7. SCISSORS ARMS INSTALLATION - WITH GENERATOR (RT4394)
FIGURE 4-8. SCISSORS ARMS ASSEMBLY - WITH GENERATOR (RT4394)
SECTION 5 - PLATFORMFIGURE 5-1. LADDER INSTALLATION (RT4394)
FIGURE 5-2. PLATFORM MOUNT INSTALLATION (LSS)
FIGURE 5-3. PLATFORM WITH SINGLE EXTENSION INSTALLATION
FIGURE 5-4. PLATFORM (12.6FT/3.84M LENGTH) WITH DUAL EXTENSION INSTALLATION
FIGURE 5-5. RAIL INSTALLATION - PLATFORM WITH SINGLE EXTENSION
FIGURE 5-6. RAIL INSTALLATION - 12.6FT/3.84M LENGTH PLATFORM WITH DUAL EXTENSION
FIGURE 5-7. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES (WITHOUT LEVELING JACKS)
FIGURE 5-8. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES (WITH LEVELING JACKS)
FIGURE 5-9. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES (WITHOUT LEVELING JACKS)
FIGURE 5-10. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES (WITH LEVELING JACKS)
FIGURE 5-11. DRIVE/STEER CONTROLLER ASSEMBLY
FIGURE 5-12. PLATFORM MODULE INSTALLATION (LSS)
FIGURE 5-13. PIPE RACKS INSTALLATION (OPTIONAL)
FIGURE 5-14. WELDER ASSEMBLY
FIGURE 5-15. WORKSTATION INSTALLATION (OPTIONAL)
FIGURE 6-2. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-3. LIFT CYLINDER ASSEMBLY
FIGURE 6-4. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - LEVELING JACKS
FIGURE 7-2. HYDRAULIC DIAGRAM - STANDARD (ALL SPECS EXCEPT CE, JAPANESE & UK CA SPECS)
FIGURE 7-3. HYDRAULIC DIAGRAM - STANDARD (CE, JAPANESE & UK CA SPECS)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 220V (PLUG AND RECEPTACLE SUPPLY LOCALLY) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 220V (PLUG AND RECEPTACLE BOX SUPPLY LOCALLY) (ALL SPECS EXCEPT JAPANESE SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 70X70 BOX (CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2X4 BOX (CE & UK CA SPECS)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 70X70 BOX (CE & UK CA SPECS)
FIGURE 8-11. BATTERY CABLE KIT
FIGURE 8-12. BREAKER BOX KIT
FIGURE 8-13. CHASSIS HARNESS INSTALLATION
FIGURE 8-14. CHASSIS HARNESS
FIGURE 8-15. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-16. ENGINE HARNESS - KUBOTA DIESEL
FIGURE 8-17. ENGINE HARNESS - KUBOTA GASOLINE
FIGURE 8-18. GENERATOR HARNESS - 7500W
FIGURE 8-19. GENERATOR HARNESS - 4000W
FIGURE 8-20. GENERATOR HARNESS - 4000W
FIGURE 8-21. GROUND CONTROL BOX HARNESS (LOWER)
FIGURE 8-22. GROUND CONTROL BOX HARNESS (UPPER)
FIGURE 8-23. GROUND TO PLATFORM HARNESS (RT3394)
FIGURE 8-24. GROUND TO PLATFORM HARNESS (RT4394)
FIGURE 8-25. GROUND WIRE HARNESS
FIGURE 8-26. LEVELING JACKS HARNESS
FIGURE 8-27. LSS HARNESS
FIGURE 8-28. PLATFORM CONTROL BOX HARNESS
FIGURE 8-29. PLATFORM MODULE HARNESS
FIGURE 8-30. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-31. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-32. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-33. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-34. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-35. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70X70 BOX (CE & UK CA SPEC)
FIGURE 8-36. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-37. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70X70 BOX (CE & UK CA SPEC)
FIGURE 8-38. RECEPTACLE/BREAKER BOX ASSEMBLY - 220V GFI
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN, CE, JAPANESE & UK CA SPEC (ENGLISH)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE)
FIGURE 9-4. DECAL INSTALLATION - CHINESE SPECS (ENGLISH/CHINESE)
FIGURE 9-5. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH)
FIGURE 9-6. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN)
FIGURE 9-7. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/SPANISH)
FIGURE 9-8. DECAL INSTALLATION - OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
