JLG Scissor Lift RT2669 RT3369 Parts Manual 31219158
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT2669 RT3369 Scissor Lift
Part Number: 31219158
Publication Date: 2024
Number of Pages: 314 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - SINGLE OSCILLATING (WITHOUT SENSORS)
FIGURE 1-2. AXLE INSTALLATION - SINGLE OSCILLATING (WITH SENSORS)
FIGURE 1-3. AXLE INSTALLATION - DUAL OSCILLATING
FIGURE 1-4. VALVE ASSEMBLY - DUAL AXLE
FIGURE 1-5. STEERING INSTALLATION
FIGURE 1-6. DRIVE INSTALLATION (2WD)
FIGURE 1-7. DRIVE INSTALLATION (4WD)
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (2WD)
FIGURE 1-9. DRIVE HUB AND BRAKE ASSEMBLY (2WD REAR)
FIGURE 1-10. HUB/SPINDLE ASSEMBLY (2WD FRONT)
FIGURE 1-11. VALVE ASSEMBLY - TRACTION (2WD)
FIGURE 1-12. VALVE ASSEMBLY- TRACTION (4WD)
FIGURE 1-13. DRIVE ASSEMBLY (4WD)
FIGURE 1-14. DRIVE HUB AND BRAKE ASSEMBLY (4WD)
FIGURE 1-15. FRAME COVERS INSTALLATION
FIGURE 1-16. LADDER INSTALLATION (RT2669)
FIGURE 1-17. LADDER INSTALLATION (RT3369)
FIGURE 1-18. LEVELING JACKS INSTALLATION - PARTIAL COVERS
FIGURE 1-19. LEVELING JACKS INSTALLATION - FULL COVERS
FIGURE 1-20. LEVELING JACKS VAVLE ASSEMBLY
FIGURE 1-21. OIL COOLER INSTALLATION
FIGURE 1-22. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED
FIGURE 1-23. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED NON-MARKING
FIGURE 1-24. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED TURF NON-MARKING
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENTS INSTALLATION - DIESEL
FIGURE 2-2. HYDRAULIC COMPONENTS INSTALLATION - DUAL FUEL
FIGURE 2-3. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 2-5. GROUND CONTROL ASSEMBLY
FIGURE 2-6. ALARM INSTALLATION (HORN)
FIGURE 2-7. ALARM INSTALLATION (WHITE NOISE)
FIGURE 2-8. HOODS INSTALLATION
FIGURE 2-9. HYDRAULIC TANK ASSEMBLY
FIGURE 2-10. STROBE LIGHT INSTALLATION - SINGLE
FIGURE 2-11. STROBE LIGHT INSTALLATION - DUAL
FIGURE 2-12. NO BEACON (COVERS)
SECTION 3 - ENGINEFIGURE 3-1. ENGINE MOUNTING INSTALLATION
FIGURE 3-2. ENGINE AND PUMP ASSEMBLY - DIESEL
FIGURE 3-3. PUMP ASSEMBLY - DIESEL
FIGURE 3-4. ENGINE COMPONENTS - DIESEL
FIGURE 3-5. COUPLING ASSEMBLY - ENGINE PUMP (DIESEL)
FIGURE 3-6. ENGINE FUEL LINES INSTALLATION - DIESEL
FIGURE 3-7. ENGINE ELECTRICAL INSTALLATION - DIESEL
FIGURE 3-8. ENGINE COOLING SYSTEM INSTALLATION - DIESEL
FIGURE 3-9. AIR INTAKE INSTALLATION - DIESEL
FIGURE 3-10. EXHAUST INSTALLATION - DIESEL
FIGURE 3-11. OIL FILTER INSTALLATION - REMOTE - DIESEL
FIGURE 3-12. ENGINE AND PUMP ASSEMBLY - DUAL FUEL
FIGURE 3-13. PUMP ASSEMBLY - DUAL FUEL
FIGURE 3-14. ENGINE COMPONENTS - DUAL FUEL
FIGURE 3-15. COUPLING ASSEMBLY - ENGINE PUMP (DUAL FUEL)
FIGURE 3-16. ENGINE FUEL LINES INSTALLATION - DUAL FUEL
FIGURE 3-17. ENGINE ELECTRICAL INSTALLATION - DUAL FUEL
FIGURE 3-18. ENGINE COOLING SYSTEM INSTALLATION - DUAL FUEL
FIGURE 3-19. AIR INTAKE INSTALLATION - DUAL FUEL
FIGURE 3-20. EXHAUST INSTALLATION - DUAL FUEL
FIGURE 3-21. OIL FILTER INSTALLATION - REMOTE - DUAL FUEL
FIGURE 3-22. GENERATOR INSTALLATION - 2500W/60HZ (DIESEL MACHINES)
FIGURE 3-23. GENERATOR INSTALLATION - 2500W/60HZ (DUAL FUEL MACHINES)
FIGURE 3-24. LP TANK BRACKETS INSTALLATION (SINGLE TANK)
FIGURE 3-25. LP TANK BRACKETS INSTALLATION (DUAL TANKS)
SECTION 4 - SCISSORS ARMSFIGURE 4-1. ARMS INSTALLATION (RT2669)
FIGURE 4-2. ARMS ASSEMBLY (RT2669)
FIGURE 4-3. ARMS INSTALLATION (RT3369)
FIGURE 4-4. ARMS ASSEMBLY (RT3369)
FIGURE 4-5. CYLINDER & LIFT DOWN VALVE ASSEMBLY
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM INSTALLATION
FIGURE 5-2. PLATFORM EXTENSION INSTALLATION (SINGLE)
FIGURE 5-3. PLATFORM RAILS INSTALLATION (SINGLE EXTENSION)
FIGURE 5-4. PLATFORM CONTROL BOX INSTALLATION - SIDE MOUNT
FIGURE 5-5. PLATFORM CONTROL BOX INSTALLATION
FIGURE 5-6. CONTROLLER ASSEMBLY
FIGURE 6-2. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-3. LIFT CYLINDER ASSEMBLY
FIGURE 6-4. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (DUAL OSCILLATING)
FIGURE 7-2. HYDRAULIC DIAGRAM - LEVELING JACKS
FIGURE 7-3. HYDRAULIC DIAGRAM - STANDARD (2WD)
FIGURE 7-4. HYDRAULIC DIAGRAM - STANDARD (4WD)
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED PLUG & RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN & CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ALL SPECS)
FIGURE 8-10. AXLE HARNESS - REAR OSCILLATING
FIGURE 8-11. BREAKER BOX KIT - 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 8-12. BREAKER BOX KIT - 1 DOUBLE & 1 SINGLE BREAKER (CE & UK CA SPECS)
FIGURE 8-13. CHASSIS HARNESS
FIGURE 8-14. ENGINE HARNESS - DIESEL
FIGURE 8-15. ENGINE HARNESS - DUAL FUEL
FIGURE 8-16. GENERATOR HARNESS
FIGURE 8-17. GROUND TO PLATFORM HARNESS (RT2669)
FIGURE 8-18. GROUND TO PLATFORM HARNESS (RT3369)
FIGURE 8-19. LEVELING JACK HARNESS
FIGURE 8-20. LIFT DOWN HARNESS
FIGURE 8-21. LSS HARNESS
FIGURE 8-22. OIL COOLER HARNESS
FIGURE 8-23. PLATFORM HARNESS
FIGURE 8-24. PLATFORM CABLE INSTALLATION – WITHOUT FOOTSWITCH
FIGURE 8-25. PLATFORM CABLE HARNESS – WITHOUT FOOTSWITCH
FIGURE 8-26. PLATFORM CABLE INSTALLATION – WITH FOOTSWITCH
FIGURE 8-27. PLATFORM CABLE HARNESS – WITH FOOTSWITCH
FIGURE 8-28. PLATFORM CONTROL BOX HARNESS
FIGURE 8-29. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-30. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-31. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-32. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-33. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-34. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-35. TILT SENSOR HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS (ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN,CE & UK CA SPECS (ENGLISH LANGUAGE)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION - CHINA SPECS (ENGLISH/CHINESE LANGUAGES)
FIGURE 9-5. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/KSPANISH LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION - OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
