JLG Scissor Lift RT2669 RT3369 ERT2669 ERT3369 Service & Maintenance Manual 31219165
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT2669 RT3369 ERT2669 ERT3369 Scissor Lift
Part Number: 31219165
Publication Date: 2024
Number of Pages: 438 Pages
Brand: JLG
Section A. INTRODUCTION - Maintenance Safety Precautions
A General
B Hydraulic System Safety
C Maintenance
Revision Log
Table of Contents
List of Figures
List of Tables
Section 1. Specifications
1.1 Specifications
1.2 Serial Number Location
1.3 Lubrication
1.4 Hydraulic Pressure Settings
1.5 Hydraulic Cylinder Specifications
1.6 Engine Specifications
1.7 Battery Charger (ERT Machines)
1.8 Elevation/Tilt Limit Settings
1.9 Threadlocking Compound
1.10 Torque Charts
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance
2.2 Preventive Maintenance and Inspection Schedule
2.3 Service and Guidelines
2.4 Lubrication and Information
2.5 Service Maintenance Components
2.6 Cylinder Drift Test
2.7 Pins and Composite Bearing Repair Guidelines
Section 3. Chassis, Platform, & Scissor Arms
3.1 Operating Characteristics
3.2 Tires, Wheels & Drive Assembly
3.3 Drive Hub - 2WD (For RT)
3.4 Drive Hub - 4WD (FOR RT)
3.5 Drive Hub (For ERT)
3.6 Drive Motor (Sauer)
3.7 Axle Installation
3.8 Steer Installation
3.9 Leveling Jacks (If Equipped)
3.10 Platform
3.11 Scissor Arms
3.12 Side Compartment Covers
3.13 Ground Control Station
3.14 Battery
3.15 Tank
3.16 Battery Charger
Section 4. Basic Hydraulic Information & Schematics
4.1 Cylinders - Theory of Operation
4.2 Valves - Theory of Operation
4.3 Cylinder Checking Procedure
4.4 Oscillating Axle - Lockout Cylinder Test
4.5 Gear Pump Priming
4.6 Hydraulic Component Start-Up Procedures & Recommendations
4.7 Hydraulic Connection Assembly and Torque Specification
4.8 Hydraulic Valves
4.9 Gear Pump
4.10 Cylinder Repair
4.11 Cylinder Assemblies
4.12 Hydraulic Schematics (For RT)
4.13 Hydraulic Schematics (For ERT)
Section 5. JLG Control System
5.1 Analyzer
5.2 Analyzer Menu Flow Chart (For RT)
5.3 Analyzer Menu Flow Chart (For ERT)
5.4 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description (For RT)
5.5 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description (For ERT)
5.6 Chassis Tilt Sensor Installation
5.7 Location of Additional Sensors
5.8 Calibration Procedures
5.9 Service Mode Procedures
5.10 Machine Configuration and Programming Settings (For RT)
5.11 Machine Configuration and Programming Settings (For ERT)
Section 6. LSS Setup/Calibration/Service
6.1 Connecting the JLG Control System Analyzer
6.2 Help Menu & Fault Codes
6.3 Machine Setup Menu
6.4 Service
6.5 Calibration
6.6 Troubleshooting
Section 7. General Electrical Information & Schematics
7.1 General
7.2 Multimeter Basics
7.3 Applying Silicone Dielectric Compound to Electrical Connections
7.4 Dielectric Grease Application
7.5 AMP Connector
7.6 Working with Deutsch Connectors
7.7 Switches
7.8 Electrical Schematics (For RT)
7.9 Electrical Schematics (For ERT)
- SuperPac Parts Manual
- StratoLift Parts Manual
