JLG Scissor Lift RT2669 RT3369 ERT2669 ERT3369 Operation Safety Manual 31219164
Brand: JLG
Type of Machine: Scissor Lift
Type of Manual: Operation Safety Manual
Model: JLG RT2669 RT3369 ERT2669 ERT3369 Scissor Lift
Part Number: 31219164
Publication Date: 2024
Number of Pages: 128 Pages
Safety Precautions
Brand: JLG
Safety Precautions
General
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
RT, ERT Series Pre-Start Inspection
RT2669, RT3369, ERT2669, ERT3369 Walk-Around Inspection
RT2669, RT3369, ERT2669, ERT3369 Function Check
Oscillating Axle - Lockout Cylinder Test (If Equipped) (CE M
2.6.1 Left Side Wheel Test
2.6.2 Right Side Wheel Test
Oscillating Axle - Lockout Cylinder Test (If Equipped) (All
2.7.1 Left Side Wheel Test
2.7.2 Right Side Wheel Test
QuikLevel Advanced Test (If Equipped)
Machine Controls, Indicators, and OperationGeneral
Description
Operating Characteristics and Limitations
3.3.1 Placards
3.3.2 Capacities
3.3.3 Stability
Platform Loading
Battery Charging (ERT Machines)
Midsize RT Scissor Ground Control Station
3.6.1 Ground Control Station Functions
Ground Control Station Display Gauge
Platform Control Station
3.8.1 Platform Control Station Functions
Indicator Display
3.9.1 Indicator Display Functions
Navigating the Indicator Display
Engine Operation
3.11.1 Starting Procedure
Dual Fuel System (If Equipped)
3.12.1 Changing from Gasoline to Liquid Propane Gas (LPG)
3.12.2 Changing from LPG to Gasoline
Traveling (Driving)
3.13.1 Steering
3.13.2 Traveling Forward
3.13.3 Traveling in Reverse
Traveling (Grade/Side Slope)
Platform
3.15.1 Raising
3.15.2 Lowering
3.15.3 Arm Guards (If Equipped)
3.15.4 Platform Extension
Leveling Jacks (If Equipped)
3.16.1 Auto-Leveling
3.16.2 Manual Level Adjustment (Trim)
QuikLevel Advanced (Dual Oscillating Axles) (If Equipped)
3.17.1 Auto-Leveling
3.17.2 Manual Level Adjustment (Trim)
Parking and Stowing
Machine Lifting and Tie Down
3.19.1 Lifting
3.19.2 Tie Down
Platform Rails Fold-Down Procedure
Towing
RT/ERT 26/33 Lifting and Tie Down Chart
Safety Decal Locations - RT Series
Safety Decal Locations - ERT Series
Emergency ProceduresGeneral
Incident Notification - Scissor
Emergency Operation
4.3.1 Use of Ground Controls
4.3.2 Operator Unable to Control Machine
4.3.3 Platform Caught Overhead
4.3.4 Righting of Tipped Machine
Platform Manual Descent Control
Emergency Towing Procedures
4.5.1 RT Machines
4.5.2 ERT Machines
AccessoriesAvailable Accessories - RT2669, ERT2669, RT3369, ERT3369
Footswitch
5.2.1 Operation
Generator (2500W)
Generator (3500W)
5.4.1 Generator Specifications
5.4.2 Safety Precautions
5.4.3 Preparation and Inspection
5.4.4 Operation
Pipe Racks
5.5.1 Safety Precautions
5.5.2 Preparation and Inspection
5.5.3 Operation
Platform Worklights
Workstation
5.7.1 Safety Precautions
5.7.2 Preparation and Inspection
5.7.3 Operation
Machine Specifications and Operator MaintenanceGeneral
Other Publications Available RT2669, RT3369, ERT2669, ERT336
RT2669, RT3369, ERT2669, ERT3369 Machine Specifications
6.3.1 Operating Specifications
6.3.2 Dimensions
6.3.3 Maximum Allowable Operating Slope
6.3.4 Platform Capacity
6.3.5 Fluid Capacities
6.3.6 Batteries (ERT Machine)
6.3.7 Tires
6.3.8 Battery Charger (ERT Machines)
Engine Specifications - RT and ERT Machines
Engine Oil Operating Temp Spec - RT and ERT Machines
Lubrication
Safety Prop
Battery Maintenance and Charging
6.8.1 Battery Charging (Daily)
6.8.2 Battery Maintenance (Quarterly)
Battery Disconnect (ERT Machines)
6.10.1 Fuel Tank
6.10.2 Hydraulic Oil Tank
6.10.3 Drive Hub
6.10.4 Scissor Arm Wear Pads
6.10.5 Engine Coolant
6.10.6 Air Filter
6.10.7 Oil Change with Filter
6.10.8 Fuel/Water Separator Filter (Diesel)
6.10.9 Fuel Strainer (Diesel)
6.10.10 Fuel Filter (Gas)
Propane Fuel System
6.11.1 Pressure Relief
6.11.2 Leak Test
Tires and Wheels
6.12.1 Tire Damage
6.12.2 Tire Replacement
6.12.3 Wheel Replacement
6.12.4 Wheel Installation
Supplemental Information Only Applicable to CE/UKCA Machines
EC Declaration of Conformity - RT2669, RT3369, ERT2669, ERT3
UKCA Declaration of Conformity - RT2669, RT3369, ERT2669, ER
- SuperPac Parts Manual
- StratoLift Parts Manual
