Hyundai
86
176,834
JLG Scissor Lift RT2669, ERT2669, RT3369, ERT3369 Service & Maintenance Manual 3122566600 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT2669, ERT2669, RT3369, ERT3369 Scissor Lift
Part Number: 3122566600
Publication Date: 2025
Number of Pages: 570 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Generator Specifications (If Equipped)​
2.1.3 Machine Dimensional Data​
2.1.4 Fluid Capacities​
2.1.5 Drive Information​
2.1.6 Steering Information​
2.1.7 Quicklevel Information​
2.1.8 Batteries (For ERT)​
2.1.9 Tires​
2.1.10 Critical Stability Weights​
2.1.11 Hydraulic Pressure Settings​
2.1.12 Hydraulic Cylinder Specifications​
2.1.13 Engine Specifications​
2.1.14 Battery Charger (ERT Machines)​
2.1.15 Elevation/Tilt Limit Settings​
Serial Number Location (concept)​
Fluids and Lubrication (task)​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Lubrication Specifications​
2.3.5 Hydraulic Oil Specification​
Clearsky Smart Fleet (If Equipped)​
2.4.1 General​
2.4.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance (task)​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Service and Guidelines (task)​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Lubrication and Servicing​
Preventive Maintenance and Inspection Schedule (task)​
3.3.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines (task)​
Tires and Wheels (concept)​
3.5.1 Tire Damage​
3.5.2 Tire Replacement​
3.5.3 Wheel Replacement​
Battery Charger (task)​
3.6.1 Delta-Q - Battery Charger​
3.6.2 Battery Charging​
3.6.3 Battery Charger Maintenance​
3.6.4 IC Series Setup and Troubleshooting Guide​
Operating Characteristics (task)​
3.7.1 Leveling Jacks (If Equipped)​
3.7.2 Quiklevel Advanced (Dual Oscillating Axles) (If Equipped)​
3.7.3 Lift​
3.7.4 Drive​
Service Maintenance Components (task)​
3.8.1 Fuel Tank​
3.8.2 Drive Hub​
3.8.3 Scissor Arms - Sliding Wear Pads​
3.8.4 Hydraulic Oil Tank​
3.8.5 Engine Coolant​
3.8.6 Oil Change with Filter​
3.8.7 Fuel Strainer (Diesel)​
3.8.8 Fuel Filter (Gas)​
3.8.9 Air Filter​
3.8.10 Fuel/Water Separator Filter (Diesel)​
3.8.11 Fan Belt​
Testing, Calibrations and Special Procedures
Special Tools (concept)​
4.1.1 Multimeter​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Preparation​
4.2.2 Testing LSS Control System Warnings and Interlocks:​
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:​
4.2.4 Testing LSS Platform Load Reading with a Known Weight:​
Calibration Procedures (task)​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Chassis Tilt Sensor - Non QuikLevel Equipped Machine​
4.3.5 Chassis Tilt Sensor - QuikLevel Equipped Machine​
4.3.6 Troubleshooting Steps :​
4.3.7 Front Oscillating Axle Tilt Sensor (CE, UKCA or Quiklevel Equipped Machines Only)​
4.3.8 Elevation Sensor​
4.3.9 Rear Axle Tilt Sensor (Quiklevel Equipped Machines Only)​
4.3.10 Joystick​
4.3.11 Steer Sensor (ERT Family Only)​
4.3.12 Set Charger (ERT Family Only)​
4.3.13 Pressure Relief Valve - Setting Procedures (For RT)​
4.3.14 Pressure Relief Valve - Setting Procedures (For ERT)​
4.3.15 Quick Level Advanced (QLA) Pressure Setting (If Equipped)​
4.3.16 QLA Function Speed Setting (If Equipped)​
Special Procedures (task)​
4.4.1 Setting Scissor Arm Safety Prop​
4.4.2 General Maintenance Tips​
4.4.3 Joystick Controller​
4.4.4 Cylinder Drift Test​
4.4.5 Dual Fuel/LPG System​
4.4.6 Service Mode Procedures​
4.4.7 Initial Start-Up Procedures​
System Software
Load Sensing System (LSS) (reference)​
5.1.1 Theory of Operation​
5.1.2 Service​
5.1.3 Connecting the JLG control system Analyzer​
5.1.4 Machine setup menu​
JLG Analyzer (task)​
5.2.1 Hand Held Analyzer​
5.2.2 Analyzer Menu Flow Chart (Software Version P1.11) (For RT)​
5.2.3 Analyzer Menu Flow Chart (Software Version P1.10) (For ERT)​
Analyzer Software Accessibility (reference)​
5.3.1 Machine Configuration and Programming Settings (Software Version P1.11 For RT)​
5.3.2 Machine Configuration and Programming Settings (Software Version P1.10 For ERT)​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC)​
DTC Check Tables (concept)​
6.3.1 DTC and Flash Codes​
6.3.2 ClearSky CSV3 Smart Fleet DTC Fault Codes​
6.3.3 Help Menu and Fault Codes​
6.3.4 Troubleshooting​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
Theories of Operation (concept)​
7.1.1 Cylinders​
7.1.2 Valves​
7.1.3 Cylinder Checking Procedure​
7.1.4 Oscillating Axle- Lockout Cylinder Test​
7.1.5 Hydraulic Component Start-Up Procedures and Recommendations​
Torque Values​
7.2.1 Main Hydraulic Valve​
7.2.2 Junction Manifold Valve​
7.2.3 Electric Option Valve​
7.2.4 Leveling Jack Valves (If Equipped)​
7.2.5 Dual Axle Option Valve​
7.2.6 Traction Valve (2WD)​
7.2.7 Traction Valve (4WD)​
Gear Pump (task)​
7.3.1 General Repair Instructions​
7.3.2 Gear Pump Priming​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
8.1.11 Exceptions​
8.1.12 Enclosures​
8.1.13 Carling Switch Connectors​
8.1.14 Scissor Platform Cable at the Platform Control​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Harness Layouts​
8.3.1 Electrical Layout For RT2669, RT3369​
8.3.2 Electrical Layout For ERT2669, ERT3369​
Board Layouts​
8.4.1 Ground Control Module (For RT)​
8.4.2 Ground Control Module (For ERT)​
AMP Connector​
8.5.1 Assembly​
8.5.2 Disassembly​
8.5.3 Wedge Lock​
8.5.4 Service - Voltage Reading​
Switches​
8.6.1 Basic check​
8.6.2 Limit Switches​
8.6.3 Automatic Switches​
8.6.4 Switch Wiring - Low Side, High Side​
Battery (task)​
9.1.1 Battery Removal - RT​
9.1.2 Battery Removal -ERT​
Tilt Sensor (task)​
Ground Control Station (task)​
9.3.1 Control Station Removal​
9.3.2 Removal​
9.3.3 Installation​
9.3.4 Ground Control Station Components​
Tank (task)​
9.4.1 Tank Installation - RT​
9.4.2 Tank Installation - For ERT​
Scissor Arms (task)​
9.5.1 Lift Cylinder​
9.5.2 Scissor Arms​
9.5.3 Scissor Arm Assembly​
Platform (task)​
Wheel (task)​
9.7.1 Removal​
9.7.2 Installation​
Axle (task)​
9.8.1 Removal​
9.8.2 Installation​
Steer (task)​
9.9.1 Steer - For RT​
9.9.2 Steer - For ERT​
Leveling Jacks (task)​
9.10.1 Cylinder Removal​
9.10.2 Cylinder Removal (Full Cover)​
9.10.3 Assembly Removal​
Oscillating Axle Cylinder (task)​
9.11.1 Removal​
9.11.2 Installation​
Drive Motor (Sauer) (task)​
9.12.1 Shaft Seal Replacement​
9.12.2 Loop Flushing Valve​
9.12.3 Troubleshooting​
Generator (If Equipped) (task)​
9.13.1 AC Generator​
9.13.2 Belt Routing​
Drive Assembly (task)​
9.14.1 Spindle Assembly Hub - For RT (2WD)​
9.14.2 Drive Assembly - For ERT​
Side Compartment Covers (Task)​
9.15.1 Removal​
9.15.2 Installation​
Engine​
9.16.1 Exhaust System - Dual Fuel - Gas/LPG​
9.16.2 Exhaust System – Diesel​
9.16.3 Air Cleaner System – Dual Fuel - Gas/LPG​
9.16.4 Air Cleaner System – Diesel​
9.16.5 Radiator​
9.16.6 Engine Electrical Component Locations​
Hydraulic Pump (task)​
9.17.1 Pump Coupling Assembly​
Hydraulic Valves (task)​
Ground Control Panel (task)​
Sensor (task)​
9.20.1 Location of Additional Sensors​
9.21.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 DRIVE HUB- 2WD (FOR RT)​
10.1.2 DRIVE HUB - 4WD (FOR RT)​
10.1.3 DRIVE HUB (FOR ERT)​
10.1.4 Drive Motor (Sauer)​
10.2.1 Scissor Arm Assembly​
Platform Control Station​
10.3.1 Disassembly​
10.3.2 Assembly​
Hydraulic Cylinders​
10.4.1 Disassembly​
10.4.2 Cleaning and Inspection​
10.4.3 Assembly​
Cylinder Assemblies​
10.5.1 Steer Cylinder​
10.5.2 Lift Cylinder​
10.5.3 Oscillating Axle Cylinder​
10.5.4 Leveling Jack Cylinder​
10.5.5 Oscillating Axle Cylinder Bleeding Procedure​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
12.1.1 Hydraulic Schematics (for RT)​
12.1.2 Hydraulic Schematics (for ERT)​
Electrical Schematics​
12.2.1 Electrical Schematic (For RT)​
12.2.2 Electrical Schematic (For ERT)​
