Hyundai
86
176,834
JLG Scissor Lift R1532i, R1932i, R1932 Service & Maintenance Manual 31219991 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG R1532i, R1932i, R1932 Scissor Lift
Part Number: 31219991
Publication Date: 2025
Number of Pages: 324 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications (reference)​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Platform Capacities​
2.1.4 Tires​
2.1.5 Batteries​
2.1.6 Battery Charger​
2.1.7 Motors​
2.1.8 Limit Switch Activation​
2.1.9 Hydraulic Pressure Settings​
2.1.10 Hydraulic Cylinder Specifications​
2.1.11 Critical Stability Weights​
2.1.12 Major Component Weights​
2.1.13 High Drive Speed Cutout Height​
Serial Number Locations (concept)​
Fluids and Lubrication (task)​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Lubrication Specifications​
2.3.5 Capacities​
2.3.6 Fluids​
Machine Preparation, Inspection, and Maintenance (task)​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Service and Guidelines (task)​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
Preventive Maintenance and Inspection Schedule (task)​
3.3.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines (task)​
Tires & Wheels (task)​
3.5.1 Tire Wear and Damage​
3.5.2 Wheel and Tire Replacement​
Battery Charger (reference)​
3.6.1 Battery Charging​
3.6.2 DC/AC Power Inverter Installation - Option​
3.6.3 Checking/Changing the Battery Charger Algorithm​
Testing, Calibrations and Special Procedures
Special Tools (concept)​
4.1.1 Multimeter​
4.1.2 Continuity Measurement Over Long Distances​
4.1.3 Requirements:​
4.1.4 Procedure​
4.1.5 Threadlocking Compound​
Testing Procedures (task)​
4.2.1 LSS Testing​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System (LSS) Calibration​
4.3.4 Tilt Sensor Calibration​
4.3.5 Rotary Angle (Elevation) Sensor Calibration​
Special Procedures (task)​
4.4.1 Machine Component Locations​
4.4.2 Scissor Arm - Safety Prop​
4.4.3 Joystick Controller​
4.4.4 Arms and Platform Positioning and Support​
4.4.5 Cylinder Checking Procedure​
4.4.6 Cylinder Drift Test​
System Software
Load Sensing System (LSS) (reference)​
5.1.1 Theory of Operation​
5.1.2 Lift Cylinder - LSS Pressure Sensor Location (If Equipped)​
5.1.3 LSS Connector Pin Assignments​
5.1.4 Personalities Menu​
5.1.5 Diagnostic Menu​
JLG Analyzer (task)​
5.2.1 Hand Held Analyzer​
5.2.2 Diagnostic Port​
5.2.3 To Connect the Hand Held Analyzer:​
5.2.4 Using the Analyzer:​
5.2.5 Changing the Access Level of the Hand Held Analyzer:​
5.2.6 Adjusting Parameters Using the Hand Held Analyzer​
5.2.7 Machine Setup​
5.2.8 Updating Software​
Analyzer Software Accessibility (reference)​
5.3.1 Machine Model Adjustment (Personality Settings)​
Fault Codes
Introduction (concept)​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC) (concept)​
DTC Check Tables (reference)​
6.3.1 Diagnostic Trouble Codes (DTC)​
6.3.2 LSS Troubleshooting​
Hydraulics
General Information & Safety (concept)​
Theories of operation (reference)​
7.2.1 Cylinders​
7.2.2 Valves​
7.2.3 Hydraulic Oil Check Procedure​
7.2.4 Pump/Motor​
Torque Values (reference)​
7.3.1 Hydraulic Manifold Assembly​
7.3.2 Hose Routing​
Hydraulic Diagram (task)​
Pressure Setting Procedure (task)​
7.5.1 Pressure Settings​
7.5.2 Main Relief Valve​
7.5.3 Lift-Up Relief Valve​
7.5.4 Steer Relief Valves​
Remote Tow Components​
7.6.1 Push Button Brake Release (AUS only)​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Harness Layout (reference)​
8.3.1 Cable Routing​
AMP Connector​
8.4.1 Assembly​
8.4.2 Disassembly​
8.4.3 Wedge Lock​
8.4.4 Service - Voltage Reading​
Switches​
8.5.1 Basic check​
8.5.2 Limit Switches​
8.5.3 Automatic Switches​
8.5.4 Switch Wiring - Low Side, High Side​
Pothole Protection System (reference)​
Wheels (task)​
9.2.1 Removal​
9.2.2 Installation​
Battery (task)​
9.3.1 Battery Quick-Disconnect​
9.3.2 Battery Maintenance and Safety Practices​
Logic Control Module (task)​
9.4.1 To swing the module down for access​
9.4.2 To remove the module from the machine​
Tilt Sensor (task)​
9.5.1 Tilt Sensor Removal​
9.5.2 Tilt Sensor Installation​
Ground Control Station (task)​
9.6.1 Components Location​
9.6.2 Removal​
9.6.3 Installation​
Hydraulic Tank (task)​
Side Swing Doors (task)​
Pump/Motor (task)​
9.9.1 Pump/Motor Removal​
9.9.2 Pump/Motor Installation​
Scissor Arms (task)​
9.10.1 Removal​
9.10.2 Installation​
Arm Angle Sensor (task)​
9.11.1 Scissor Arm Rotary Angle (Elevation) Sensor​
9.11.2 Rotary Angle (Elevation) Sensor Installation​
Platform Control Station (task)​
9.12.1 Overview of Control Station Components​
9.12.2 Removal​
9.12.3 Installation​
Platform (task)​
9.13.1 Removal (1532i)​
9.13.2 Removal (R1932i/R1932)​
9.13.3 Installation​
Lift Cylinder (task)​
Pump Control Module (task)​
9.15.1 Main Power Contactor Relay and Pump Control Module​
9.15.2 Removal​
9.15.3 Installation​
Drive Motor (task)​
9.16.1 Removal​
9.16.2 Installation​
Hydraulic Brake (task)​
9.17.1 Hydraulic Brake Release​
Steer and Spindle Assembly Components​
Disassembly and Assembly
Scissor Arm Assembly (task)​
10.1.1 Scissor Arm Assembly (R1532i)​
10.1.2 Scissor Arm Assembly (R1932i, R1932)​
10.2.1 Control Station Disassembly​
10.2.2 Assembly​
Hydraulic Cylinders (task)​
10.3.1 Disassembly​
10.3.2 Cleaning and Inspection​
10.3.3 Assembly​
Pump/Motor​
10.4.1 Pump/Motor Disassembly​
10.4.2 Pump/Motor Assembly​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts (task)​
11.2.1 Torque Requirements​
11.2.2 SAE Fastener Torque Chart​
11.2.3 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics (task)​
Electrical Schematics (task)​
