JLG Scissor Lift ES2646 Parts Catalog 3122315600
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES2646 Scissor Lift
Part Number: 3122315600
Publication Date: 2025
Number of Pages: 188 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. DRIVE MOTOR AND STEERING INSTALLATION
FIGURE 1-2. DRIVE MOTOR ASSEMBLY
FIGURE 1-3. REAR WHEEL HUB INSTALLATION
FIGURE 1-4. HUB ASSEMBLY - REAR
FIGURE 1-5. TIRE AND WHEEL INSTALLATION
FIGURE 1-6. POTHOLE PROTECTION SYSTEM INSTALLATION
FIGURE 1-7. TILT SENSOR INSTALLATION
FIGURE 1-8. BATTERY CHARGER INSTALLATION (650W)
FIGURE 1-9. BATTERY CHARGER INSTALLATION (1200W)
FIGURE 1-10. BEACON/STROBE LIGHT INSTALLATION - SINGLE (WITHOUT CLEARSKY CS550 BEACON)
FIGURE 1-11. BEACON/STROBE LIGHT INSTALLATION - DUAL (WITHOUT CLEARSKY CS550 BEACON)
FIGURE 1-12. BEACON/STROBE LIGHT INSTALLATION - SECOND (WITH CLEARSKY CS550 BEACON)
FIGURE 1-13. ALARM INSTALLATION (AMBIENT/WHITE NOISE)
FIGURE 1-14. LADDER INSTALLATION
FIGURE 1-15. FRAME COVERS INSTALLATION
SECTION 2 - GROUND CONTROLSFIGURE 2-1. PUMP/MOTOR/TANK AND HOSES INSTALLATION
FIGURE 2-2. PUMP/MOTOR/TANK ASSEMBLY
FIGURE 2-3. CLEANGUARD INSTALLATION
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 2-5. MDI INSTALLATION
FIGURE 2-6. BATTERIES INSTALLATION - STANDARD 220AH BATTERIES
FIGURE 2-7. BATTERIES INSTALLATION - AGM 220AH BATTERIES (Prior to SN M200116930, Excluding M200115978, M200115979, M200116082, M200116839 and M200116842)
FIGURE 2-8. BATTERIES INSTALLATION - AGM 220AH BATTERIES (SN M200116930 to Present, Including M200115978, M200115979, M200116082, M200116839 and M200116842)
FIGURE 2-9. BATTERIES INSTALLATION - LITHIUM (24V-90AH)
FIGURE 2-10. BATTERIES INSTALLATION - LITHIUM+ (24V-90AH)
FIGURE 2-11. INVERTER INSTALLATION (WITHOUT LITHIUM BATTERIES)
FIGURE 2-12. INVERTER INSTALLATION (WITH LITHIUM BATTERIES)
FIGURE 2-13. DOORS INSTALLATION
SECTION 3 - SCISSORS ARMSFIGURE 3-1. SCISSORS ARMS INSTALLATION
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION
FIGURE 4-2. PLATFORM EXTENSION INSTALLATION
FIGURE 4-3. RAILS INSTALLATION (SIDE BY SIDE)
FIGURE 4-4. RAILS INSTALLATION (TUBE IN TUBE)
FIGURE 4-5. EXTENSION HANDLES INSTALLATION
FIGURE 4-6. GATE LATCH INSTALLATION
FIGURE 4-7. PLATFORM CONSOLE BOX INSTALLATION
FIGURE 4-8. DRIVE/STEER CONTROLLER ASSEMBLY
FIGURE 4-9. ELECTRICIAN TREE INSTALLATION
FIGURE 4-10. ELECTRICIANS PACKAGE INSTALLATION
FIGURE 4-11. ELECTRICIANS TREE ACCESSORY
FIGURE 4-12. MACHINIST VISE ACCESSORY
FIGURE 4-13. PIPE RACK ASSEMBLY ACCESSORY
FIGURE 4-14. WORKSTATION ACCESSORY
FIGURE 4-15. PANEL CARRIER INSTALLATION
FIGURE 4-16. PIPE RACKS INSTALLATION (OPTIONAL)
FIGURE 4-17. PLUMBER PACKAGE INSTALLATION
FIGURE 4-18. USB/PHONE CRADLE INSTALLATION
FIGURE 4-19. WORKLIGHT INSTALLATION
FIGURE 4-20. WORKSTATION INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY
FIGURE 5-2. STEER CYLINDER ASSEMBLY
SECTION 6 - ELECTRICALFIGURE 6-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI
FIGURE 6-2. AC BOX AT PLATFORM INSTALLATION - 220V LOCALLY SUPPLIED
FIGURE 6-3. ACTUATOR POWER CABLE
FIGURE 6-4. BEACON HARNESS
FIGURE 6-5. CHARGER PLUG INSTALLATION - CUSTOMER SUPPLIED PLUG
FIGURE 6-6. CHARGER PLUG INSTALLATION - 110V PLUG
FIGURE 6-7. CHASSIS HARNESS
FIGURE 6-8. CLEARSKY CS550 BEACON INSTALLATION (WITH ANTI-TAMPER PLATE)
FIGURE 6-9. CLEARSKY CS550 BEACON INSTALLATION (WITHOUT ANTI-TAMPER PLATE)
FIGURE 6-10. DRIVE CONTROL HARNESS
FIGURE 6-11. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE
FIGURE 6-12. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE
FIGURE 6-13. INVERTER HARNESS (LITHIUM BATTERIES)
FIGURE 6-14. LIFT DOWN HARNESS
FIGURE 6-15. LITHIUM BATTERY HARNESS
FIGURE 6-16. PLATFORM CONTROL BOX HARNESS
FIGURE 6-17. RECEPTACLE BOX KIT - 110V GFI
FIGURE 6-18. SKYSENSE BOX HARNESS
SECTION 7 - DECALSFIGURE 7-1. DECAL INSTALLATION (ANSI SPECS)
FIGURE 7-2. DECAL INSTALLATION (BRAZIL SPECS)
FIGURE 7-3. DECAL INSTALLATION (CSA SPECS)
FIGURE 7-4. DECAL INSTALLATION (LATIN AMERICAN SPECS)
FIGURE 7-5. DECAL INSTALLATIONS - OPTIONS
SECTION 8 - RECOMMENDED SERVICE PARTS STOCKFIGURE 8-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 9 - SPECIAL OPTIONSFIGURE 9-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
