JLG Scissor Lift ES2632, ES3246 Service & Maintenance Manual 3122315100 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES2632, ES3246 Scissor Lift
Part Number: 3122315100
Publication Date: 2025
Number of Pages: 346 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specification
2.1.2 Machine Dimensional Data
2.1.3 Platform Capacities
2.1.4 Tires
2.1.5 Batteries
2.1.6 Battery Charger
2.1.7 Motors
2.1.8 Limit Switch Activation
2.1.9 Hydraulic Pressure Settings
2.1.10 Hydraulic Cylinder Specifications
2.1.11 Critical Stability Weights
2.1.12 Major Component Weights
Serial Number Location
Fluids and Lubrication
2.3.1 Hydraulic System
2.3.2 Hydraulic Oil
2.3.3 Changing Hydraulic Oil
2.3.4 Specifications
2.3.5 Capacities
2.3.6 Fluids
Clearsky Smart Fleet (If Equipped)
2.4.1 General
2.4.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventative Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
Preventive Maintenance and Inspection Schedule
3.3.1 Maintenance and Inspection Schedule Codes:
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Wear and Damage
3.5.2 Wheel and Tire Replacement
Battery Charger
3.6.1 Battery Charging
3.6.2 Lithium-Ion Batteries (If Equipped)
3.6.3 Charger Indicator LEDs
3.6.4 Battery Charger Maintenance
3.6.5 DC/AC Power Inverter Installation - Option
Battery System Maintenance/Troubleshooting
3.7.1 Battery Management System (BMS)
3.7.2 State of Charge (SOC)
3.7.3 Battery Status Indicator (LED)
Machine Component Location
Pressure Setting Procedure
3.9.1 Machine Model Pressure setting
3.9.2 Main Relief Adjustment
3.9.3 Steer Left Pressure Adjustment
3.9.4 Steer Right Pressure Adjustment
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing
4.2.1 LSS Testing
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System (LSS) Calibration
4.3.4 Tilt Sensor Calibration
4.3.5 Rotary Angle Sensor Calibration
Special Procedures
4.4.1 Scissor Arm - Safety Prop
4.4.2 Drive Module Electrical Evaluation
4.4.3 Drive Motor Electrical Evaluation
4.4.4 AC Drive Motor Troubleshooting Notes
4.4.5 Power Controller Troubleshooting Notes
4.4.6 Joystick Controller
4.4.7 Arms and Platform Positioning and Support
4.4.8 Cylinder Checking Procedure
4.4.9 Cylinder Drift Test
4.4.10 Hydraulic Pressures
4.4.11 Lithium-Ion Battery Troubleshooting Notes
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Lift Cylinder - LSS Pressure Sensor Location
5.1.3 LSS Connector Pin Assignments
5.1.4 Personalities Menu
5.1.5 Diagnostic Menu
JLG Analyzer
5.2.1 Hand held Analyzer
5.2.2 Diagnostic Port
5.2.3 To Connect the Hand Held Analyzer:
5.2.4 Analyzer Software Version P1.20.0
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostic
5.3.3 Machine Configuration Programming Information
5.3.4 Machine Model Adjustment (Personality Settings)
ClearSky (CS550) Configuration and Troubleshooting
5.4.1 ClearSky Smart FleetTM CS550 Configuration
5.4.2 Troubleshooting
Fault CodesIntroduction
6.1.1 System Fault/DTC Indication
Diagnostic Trouble Codes (DTC)
DTC Check Tables
6.3.1 Diagnostic Trouble Codes (DTC’s) and Flash Codes Description
6.3.2 ClearSky Smart Fleet DTC Fault Codes
6.3.3 LSS Troubleshooting
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
7.2.3 Hydraulic Oil Check Procedure
7.2.4 Hydraulic Circuits
7.2.5 Pump/Motor
Hydraulic Components
7.3.1 Hydraulic Pump/Motor/Tank Assembly Installation
7.3.2 Hydraulic Hose Routing
Torque Values
7.4.1 Hydraulic Pump/Motor/Tank Assembly - Torque Specifications
Hydraulic Diagram
7.5.1 Hydraulic Manifold Assembly
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors
8.1.2 Dielectric Grease Application
8.1.3 Installation
8.1.4 AMP Mate-N-Lok
8.1.5 AMP Faston
8.1.6 AMP Micro-Fit
8.1.7 AMP Mini Fit Jr
8.1.8 Mini Fit Sr
8.1.9 DIN Connectors
8.1.10 Exceptions
8.1.11 Enclosures
8.1.12 Carling Switch Connectors
8.1.13 Scissor Platform Cable at the Platform Control
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Harness Layout
8.3.1 Cable Routing
Board Layouts (reference)
8.4.1 Logic Control Module
8.4.2 Drive Control Module
AMP Connector
8.5.1 Assembly
8.5.2 Disassembly
8.5.3 Wedge Lock
8.5.4 Service - Voltage Reading
Switches
8.6.1 Basic check
8.6.2 Limit Switches
8.6.3 Automatic Switches
8.6.4 Switch Wiring - Low Side, High Side
Removal and InstallationPothole Protection System
9.1.1 Pothole Protection System Components
9.2.1 Removal
9.2.2 Installation
Battery
9.3.1 Battery Removal/Maintenance
9.3.2 Lithium Ion Battery (1-Battery System)
9.3.3 Removal
9.3.4 Installation
9.3.5 Lithium Ion Battery (2-Battery System)
Battery Charger
9.4.1 Battery Charger (Delta Q)
9.4.2 Battery Charger (Green Power)
9.4.3 Battery Charger (Delta-Q 1200 W)
9.5.1 Module Access
9.5.2 Removing Module from Machine
9.6.1 Removal
9.6.2 Installation
Tilt Sensor
9.7.1 Removal
9.7.2 Installation
Ground Control Station
9.8.1 Components Location
9.8.2 Removal
9.8.3 Installation
9.9.1 Removal
9.9.2 Installation
Side Swing Door
Scissor Arms
9.11.1 Removal
9.11.2 Installation
Arm Angle Sensor
9.12.1 Arm Angle Sensor Installation
Platform Control Station
9.13.1 Overview of Control Station Components
9.13.2 Removal
9.13.3 Installation
Platform
9.14.1 Removal
9.14.2 Installation
Lift Cylinder
9.15.1 Removal
9.15.2 Installation
Steer and Spindle Assembly
Drive Motor Covers
Motor
9.18.1 Motor Cover/Motor Installation
9.18.2 Preventative Maintenance - Brush Wear - Dust Removal Procedure
9.18.3 Motor Brush Installation
Rear Wheel Hub and Frame Clamp
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.20.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
Scissor Arm Assembly
10.2.1 Scissor Arm Assembly (ES3246)
10.2.2 Scissor Arm Assembly (ES2632)
10.3.1 Disassembly
10.3.2 Assembly
Hydraulic Cylinders
10.4.1 Disassembly
10.4.2 Cleaning and Inspection
10.4.3 Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
