JLG Scissor Lift ES2632 ES3246 Service & Maintenance Manual 31219147
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES2632 ES3246 Scissor Lift
Part Number: 31219147
Publication Date: 2024
Number of Pages: 236 Pages
Brand: JLG
SPECIFICATIONS
Operating Specification (task)
Limit Switch Activation (task)
Lubrication (task)
Hydraulic Oil (task)
Hydraulic Pressure Settings (task)
Hydraulic Cylinder Specifications (task)
Serial Number Location (concept)
Critical Stability Weights (task)
Major Component Weights (reference)
Torque Requirements (concept)
Thread Locking Compound (reference)
Torque Charts
GENERAL
Machine Preparation, Inspection, and Maintenance
Preventive Maintenance and Inspection Schedule
Service Maintenance Components (task)
Service and Guidelines
Lubrication and Information (task)
Cylinder Drift Test (task)
Pins and Composite Bearing Repair Guidelines
CHASSIS & SCISSOR ARMS
Left and Right Side Compartment Components (task)
Battery Removal/Maintenance (task)
Battery Charging (task)
DC/AC Power Inverter Installation - Option (task)
Logic Control Module Installation (task)
Drive Control Module (task)
Drive Module Electrical Evaluation (task)
Drive Motor Electrical Evaluation (task)
Ground Control Station (task)
Platform Control Station (task)
Tilt Sensor Installation (task)
Arm Angle Sensor (task)
Pothole Protection System Components (task)
Steer and Spindle Assembly Components (task)
Arms and Platform Positioning and Support (task)
Platform Removal (task)
Scissor Arms Removal (task)
BASIC HYDRAULICS INFORMATION & SCHEMATICS
Cylinders - Theory of Operation (concept)
Valves - Theory of Operation (task)
Pump/Motor (task)
Hydraulic Pump/Motor/Tank Assembly Installation (task)
Hydraulic Manifold Assembly (task)
Hydraulic Pump/Motor/Tank Assembly (task)
Rear Wheel Hub and Frame Clamps Installation (task)
Pressure Setting Procedure (task)
Cylinder Checking Procedure (task)
Cylinder Removal Installation (task)
Cylinder Repair (task)
Hydraulic Schematics
JLG CONTROL SYSTEM
Hand Held Analyzer (task)
Joystick Calibration (task)
Tilt Sensor Calibration (task)
Rotary Angle Sensor Calibration (task)
Analyzer Software (task)
Machine Configuration Programming Information (task)
Machine Model Adjustment (Personality Settings) (task)
LSS (LOAD SENSING SYSTEM) SERVICE
LSS (Load Sensing System) (task)
Analyzer Information (task)
Calibration Preparation (task)
Calibration and Verification Procedure (task)
Testing (task)
LSS Connector Pin Assignments (task)
LSS Troubleshooting (task)
DIAGNOSTIC TROUBLE CODES
Introduction
Diagnostic Trouble Codes (DTC)
DTC Check Tables (task)
BASIC ELECTRICAL INFORMATION & SCHEMATICS
General (concept)
Multimeter Basics (task)
Applying Silicone Dielectric Compound to Amp Connectors (tas
Dielectric Grease Application (task)
AMP Connector
Deutsch Connectors
Switches
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
