JLG Scissor Lift ES2632 ES3246 Service & Maintenance Manual 31219058
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES2632, ES3246 Scissor Lift
Part Number: 31219058
Publication Date: 2024
Number of Pages: 199 Pages
Brand: JLG
Section 1. Specifications
1.1 Operating Specification
1.2 Limit Switch Activation
1.3 Lubrication
1.4 Hydraulic Oil
1.5 Hydraulic Pressure Settings
1.6 Hydraulic Cylinder Specifications
1.7 Serial Number Location
1.8 Critical Stability Weights
1.9 Major Component Weights
1.10 Torque Requirements
1.11 Thread Locking Compound
1.12 Torque Charts
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance
2.2 Preventive Maintenance and Inspection Schedule
2.3 Service Maintenance Components
2.4 Service and Guidelines
2.5 Lubrication and Information
2.6 Cylinder Drift Test
2.7 Pins and Composite Bearing Repair Guidelines
Section 3. Chassis & Scissor Arms
3.1 Left and Right Side Compartment Components
3.2 Battery Removal/Maintenance
3.3 Battery Charging
3.4 DC/AC Power Inverter Installation - Option
3.5 Logic Control Module Installation
3.6 Drive Control Module
3.7 Drive Module Electrical Evaluation
3.8 Drive Motor Electrical Evaluation
3.9 Ground Control Station
3.10 Platform Control Station
3.11 Tilt Sensor Installation
3.12 Arm Angle Sensor
3.13 Pothole Protection System Components
3.14 Steer and Spindle Assembly Components
3.15 Arms and Platform Positioning and Support
3.16 Platform Removal
3.17 Scissor Arms Removal
Section 4. Basic Hydraulics Information & Schematics
4.1 Cylinders - Theory of Operation
4.2 Valves - Theory of Operation
4.3 Pump/Motor
4.4 Hydraulic Pump/Motor/Tank Assembly Installation
4.5 Hydraulic Manifold Assembly
4.6 Hydraulic Pump/Motor/Tank Assembly
4.7 Rear Wheel Hub and Frame Clamps Installation
4.8 Pressure Setting Procedure
4.9 Cylinder Checking Procedure
4.10 Lift Cylinder Removal Installation
4.11 Cylinder Repair
4.12 Hydraulic Schematics
Section 5. JLG Control System
5.1 Hand Held Analyzer
5.2 Joystick Calibration
5.3 Tilt Sensor Calibration
5.4 Rotary Angle Sensor Calibration
5.5 Updating Software
5.6 Machine Configuration Programming Information
5.7 Machine Model Adjustment (Personality Settings)
Section 6. LSS (Load Sensing System) Service
6.1 LSS (Load Sensing System)
6.2 Analyzer Information
6.3 Calibration Preparation
6.4 Calibration and Verification Procedure
6.5 Testing
6.6 LSS Connector Pin Assignments
6.7 LSS Troubleshooting
Section 7. Diagnostic Trouble Codes
7.1 Introduction
7.2 Diagnostic Trouble Codes (DTC)
7.3 DTC Check Tables
Section 8. Basic Electrical Information & Schematics
8.1 General
8.2 Multimeter Basics
8.3 Applying Silicone Dielectric Compound to AMP Connectors
8.4 Dielectric Grease Application
8.5 AMP Connector
8.6 Deutsch Connectors
8.7 Switches
8.8 Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
