Hyundai
86
176,834
JLG Scissor Lift ES1932, ES1932i Service & Maintenance Manual 3122314800 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1932, ES1932i Scissor Lift
Part Number: 3122314800
Publication Date: 2025
Number of Pages: 328 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specification​
2.1.2 Machine Dimensional Data​
2.1.3 Platform Capacities​
2.1.4 Tires​
2.1.5 Batteries​
2.1.6 Battery Charger​
2.1.7 Motors​
2.1.8 Drive Control Module​
2.1.9 Limit Switch Activation​
2.1.10 Hydraulic Pressure Settings​
2.1.11 Hydraulic Cylinder Specifications​
2.1.12 Critical Stability Weights​
2.1.13 Major Component Weights​
Serial Number Location (reference)​
Fluids and Lubrication​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Specifications​
2.3.5 Capacities​
2.3.6 Fluids​
Clearsky Smart Fleet (If Equipped)​
2.4.1 General​
2.4.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection and Maintenance (concept)​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines (task)​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
Preventive Maintenance and Inspection Schedule (task)​
3.3.1 Maintenance and Inspection Schedule Codes:​
Pins and Composite Bearing Repair Guidelines (task)​
Tires and Wheels (concept)​
3.5.1 Tire Wear and Damage​
3.5.2 Wheel and Tire Replacement​
Battery Charger​
3.6.1 Battery Charging​
3.6.2 Lithium-Ion Batteries (If Equipped)​
3.6.3 Charger Indicator LEDs​
3.6.4 Battery Charger Maintenance​
3.6.5 DC/AC Power Inverter​
Battery System Maintenance/Troubleshooting​
3.7.1 Battery Management System (BMS)​
3.7.2 State of Charge (SOC)​
3.7.3 Battery Status Indicator (LED)​
Machine Component Location​
Pressure Setting Procedure​
Testing, Calibrations and Special Procedures
Special Tools (concept)​
4.1.1 Multimeter​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing (task)​
Calibration Procedures (task)​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System (LSS) Calibration​
4.3.4 Tilt Sensor Calibration​
4.3.5 Rotary Angle (Elevation) Sensor Calibration​
Special Procedures (task)​
4.4.1 Scissor Arm - Safety Prop​
4.4.2 Drive Module Electrical Evaluation​
4.4.3 Drive Motor Electrical Evaluation​
4.4.4 AC Drive Motor Troubleshooting Notes​
4.4.5 Power Controller Troubleshooting Notes​
4.4.6 Joystick Controller​
4.4.7 Arms and Platform Positioning and Support​
4.4.8 Cylinder Checking Procedure​
4.4.9 Cylinder Drift Test​
4.4.10 Hydraulic Pressures​
4.4.11 Lithium-Ion Battery Troubleshooting Notes​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Lift Cylinder - LSS Pressure Sensor Location (If Equipped)​
5.1.3 LSS Connector Pin Assignments​
5.1.4 Personalities Menu​
5.1.5 Diagnostic Menu​
JLG Analyzer​
5.2.1 Hand held Analyzer​
5.2.2 Diagnostic Port​
5.2.3 To Connect the Hand Held Analyzer:​
5.2.4 Analyzer Software Version P1.20.0​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostic​
5.3.3 Machine Configuration Programming Information​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction (concept)​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC) (concept)​
DTC Check Tables​
6.3.1 Diagnostic Trouble Codes (DTC’s) and Flash Codes Description​
6.3.2 ClearSky Smart Fleet DTC Fault Codes​
6.3.3 LSS Troubleshooting​
Hydraulics
General Information and Safety (concept)​
Theories of Operation (concept)​
7.2.1 Cylinders​
7.2.2 Valves​
7.2.3 Hydraulic Oil Check Procedure​
7.2.4 Hydraulic Circuits​
7.2.5 Pump/Motor​
Hydraulic Components (reference)​
7.3.1 Hydraulic Hose Routing​
Electricals
General Information (concept)​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
8.1.11 Exceptions​
8.1.12 Enclosures​
8.1.13 Carling Switch Connectors​
8.1.14 Scissor Platform Cable at the Platform Control​
Electrical Connectors (reference)​
8.2.1 Deutsch Connectors​
Electrical Harness Layout (reference)​
8.3.1 Cable Routing​
Board Layouts​
8.4.1 Logic Control Module​
AMP Connector (task)​
8.5.1 Assembly​
8.5.2 Disassembly​
8.5.3 Wedge Lock​
8.5.4 Service - Voltage Reading​
Switches (task)​
8.6.1 Basic Check​
8.6.2 Limit Switches​
8.6.3 Automatic Switches​
8.6.4 Switch Wiring - Low Side, High Side​
Pothole Protection System (reference)​
9.1.1 Pothole Protection System Components​
Wheels (task)​
9.2.1 Removal​
9.2.2 Installation​
Battery​
9.3.1 Battery Removal/Maintenance​
9.3.2 Lithium Ion Battery (1-Battery System)​
9.3.3 Removal​
9.3.4 Installation​
9.3.5 Lithium Ion Battery (2-Battery System)​
Battery Charger​
9.4.1 Battery Charger (Delta Q)​
9.4.2 Battery Charger (Green Power)​
9.4.3 Battery Charger (Delta-Q 1200 W)​
Logic Control Module (task)​
9.5.1 To swing the module down for access​
9.5.2 To remove the module from the machine​
9.6.1 Removal​
9.6.2 Installation​
Tilt Sensor​
9.7.1 Tilt Sensor Removal​
9.7.2 Tilt Sensor Installation​
Ground Control Station (task)​
9.8.1 Components Location​
9.8.2 Removal​
9.8.3 Installation​
Hydraulic Pump​
9.9.1 Removal​
9.9.2 Installation​
Side Swing Door (reference)​
Scissor Arms (task)​
9.11.1 Removal​
9.11.2 Installation​
Arm Angle Sensor (task)​
9.12.1 Rotary Angle (Elevation) Sensor Installation​
Platform Control Station (task)​
9.13.1 Overview of Control Station Components​
9.13.2 Removal​
9.13.3 Installation​
Platform (task)​
9.14.1 Removal​
9.14.2 Installation​
Lift Cylinder (task)​
9.15.1 Removal​
9.15.2 Installation​
Steer and Spindle Assembly​
Drive Motor Covers​
9.17.1 Drive Motor Covers Installation - Option​
Motor​
9.18.1 Motor Cover/Motor Installation​
9.18.2 Preventative Maintenance - Brush Wear - Dust Removal Procedure​
9.18.3 Motor Brush Installation​
9.19.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly (concept)​
10.1.1 Drive Hub​
Scissor Arm Assembly (task)​
10.3.1 Disassembly​
10.3.2 Assembly​
Hydraulic Cylinders​
10.4.1 Disassembly​
10.4.2 Cleaning and Inspection​
10.4.3 Assembly​
Torque/Connection Information
Hydraulic Fittings (task)​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts (reference)​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics (reference)​
Electrical Schematics​
