Hyundai
86
176,834
JLG Scissor Lift ES1930M Service & Maintenance Manual 3122551500 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1930M Scissor Lift
Part Number: 3122551500
Publication Date: 2025
Number of Pages: 318 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Operating Specifications​
Dimensions​
Platform Capacity​
Maximum Allowable Operating Slope​
Tires​
Fluid Capacities​
Batteries​
2.7.1 Batteries (Lead Acid, AGM)​
Motors​
Battery Charger​
Drive Control Module​
Hydraulic Pressure Settings​
Hydraulic Cylinder Specifications​
Critical Stability Weights​
Serial Number Location​
Fluids and Lubrication​
2.15.1 Hydraulic System​
2.15.2 Hydraulic Oil​
2.15.3 Changing Hydraulic Oil​
2.15.4 Lubrication Specifications​
2.15.5 Hydraulic Oil​
Clearsky Smart Fleet (If Equipped)​
2.16.1 General​
2.16.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance (task)​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Service and Guidelines (task)​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
Preventive Maintenance and Inspection Schedule (task)​
3.3.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines (task)​
Tires and Wheels (concept)​
3.5.1 Tire Wear and Damage​
3.5.2 Wheel and Tire Replacement​
Battery Charger​
3.6.1 Battery Charging​
3.6.2 Lithium-Ion Batteries (If Equipped)​
3.6.3 Charger Indicator LEDs​
3.6.4 Battery Charger Maintenance​
Battery System Maintenance/Troubleshooting​
3.7.1 Battery Management System (BMS)​
3.7.2 State of Charge (SOC)​
3.7.3 Battery Status Indicator (LED)​
Testing, Calibrations and Special Procedures
Special Tools (concept)​
4.1.1 Multimeter​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing (task)​
4.2.1 LSS Testing​
Calibration Procedures (task)​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Tilt Sensor Calibration​
4.3.4 Rotary Angle Sensor Calibration​
4.3.5 Load Sensing System (LSS) Calibration​
4.3.6 LSS Verification​
Special Procedures (task)​
4.4.1 Scissor Arm - Safety Prop​
4.4.2 Drive Module Electrical Evaluation​
4.4.3 Drive Motor Electrical Evaluation​
4.4.4 AC Drive Motor Troubleshooting Notes​
4.4.5 Power Controller Troubleshooting Notes​
4.4.6 Joystick Controller​
4.4.7 Arms and Platform Positioning and Support​
4.4.8 Cylinder Checking Procedure​
4.4.9 Cylinder Drift Test​
4.4.10 Traction System​
4.4.11 Drive Motor Cable Routing​
4.4.12 Factory Reset​
4.4.13 Preventative Maintenance - Brush Wear - Dust Removal Procedure​
4.4.14 Lithium-Ion Battery Troubleshooting Notes​
System Software
Load Sensing System​
5.1.1 Theory of Operation​
5.1.2 Lift Cylinder - LSS Pressure Sensor Location​
5.1.3 Personalities Menu​
5.1.4 Diagnostic Menu​
5.1.5 LSS Connector Pin Assignments​
JLG Analyzer​
5.2.1 Hand Held Analyzer​
5.2.2 Diagnostic Port​
5.2.3 To Connect the Hand Held Analyzer​
5.2.4 Updating Software​
Analyzer Software Accessibility​
5.3.1 Machine Configuration Programming Information​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction (concept)​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC) (concept)​
DTC Check Tables​
6.3.1 Diagnostic Trouble Codes (DTC’s) and Flash Codes Description​
6.3.2 ClearSky Smart Fleet DTC Fault Codes​
6.3.3 LSS Troubleshooting​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information & Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
7.2.3 Hydraulic Oil Check Procedure​
7.2.4 Pump/Motor​
7.2.5 Hydraulic Pressure Setting Procedure​
7.2.6 Pump Components​
Hydraulic Components​
7.3.1 Hydraulic Hose Routing​
Hydraulic Diagram​
7.4.1 Hydraulic Manifold Assembly​
Electricals
General Information (reference)​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
Electrical Connectors (reference)​
Electrical Harness Layout​
8.3.1 Cable Routing​
Board Layouts​
8.4.1 Logic Control Module​
AMP Connector (task)​
8.5.1 Assembly​
8.5.2 Disassembly​
8.5.3 Wedge Lock​
8.5.4 Service - Voltage Reading​
Switches (task)​
8.6.1 Basic Check​
8.6.2 Limit Switches​
8.6.3 Automatic Switches​
8.6.4 Switch Wiring - Low Side, High Side​
Pothole Protection System​
9.1.1 Removal​
9.1.2 Installation​
Wheel (task)​
9.2.1 Removal​
9.2.2 Installation​
Battery​
9.3.1 Battery Removal/Maintenance​
9.3.2 Lithium Ion Battery​
Battery Charger​
9.4.1 Removal​
9.4.2 Installation​
9.5.1 Removal​
9.5.2 Installation​
Drive Control Module (task)​
9.6.1 Removal​
9.6.2 Installation​
Tilt Sensor​
9.7.1 Removal​
9.7.2 Installation​
Ground Control Station​
9.8.1 Removal​
9.8.2 Installation​
Pump/Motor/Valve Assembly​
9.9.1 Removal​
9.9.2 Installation​
Side Swing Doors (task)​
Scissor Arms​
9.11.1 Removal​
9.11.2 Installation​
Arm Angle Sensor (task)​
9.12.1 Rotary Angle (Elevation) Sensor Installation​
Platform Control Station (task)​
9.13.1 Overview of Control Station Components​
9.13.2 Removal​
9.13.3 Installation​
Platform​
9.14.1 Removal​
9.14.2 Installation​
Lift Cylinder (task)​
9.15.1 Removal​
9.15.2 Installation​
Steer and Spindle Assembly​
9.16.1 Removal​
9.16.2 Installation​
Drive Motor Cover​
9.17.1 Removal​
9.17.2 Installation​
Drive Motor​
9.18.1 Removal​
9.18.2 Installation​
Motor Brush (task)​
9.19.1 Removal/Installation​
Motor Cover/Motor (task)​
9.20.1 Removal/Installation​
9.21.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly (concept)​
10.1.1 Drive Hub​
Scissor Arm Assembly​
10.2.1 Disassembly​
10.2.2 Assembly​
10.3.1 Disassembly​
10.3.2 Assembly​
Hydraulic Cylinder​
10.4.1 Disassembly​
10.4.2 Cleaning and Inspection​
10.4.3 Assembly​
Torque Hub (task)​
10.5.1 Roll Test​
10.5.2 Leak Test​
10.5.3 Oil Check/Fill Procedure​
Primary Planet Carrier (task)​
10.6.1 Disassembly​
10.6.2 Primary Planet Carrier Assembly​
Spindle Carrier (task)​
10.7.1 Disassembly​
10.7.2 Assembly​
Motor and Brake (task)​
10.8.1 Disassembly​
10.8.2 Assembly​
Torque/Connection Information
Hydraulic Fittings (task)​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts (task)​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
