JLG Scissor Lift ES1530LC Parts Catalog 3122326600
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1530LC Scissor Lift
Part Number: 3122326600
Publication Date: 2025
Number of Pages: 210 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. TRACK DRIVE INSTALLATION (ALL SPECS EXCEPT JAPANESE SPECS)
FIGURE 1-2. TRACK DRIVE INSTALLATION (JAPANESE SPECS)
FIGURE 1-3. TRACK DRIVE INSTALLATION (ANSI SPECS, MOL70 SPECS & CHINA SPECS)
FIGURE 1-4. DRIVE MOTOR ASSEMBLY
FIGURE 1-5. DRIVE MOTOR ASSEMBLY (ANSI SPECS, MOL70 SPECS & CHINA SPECS)
FIGURE 1-6. IDLER WHEEL ASSEMBLY
FIGURE 1-7. ALARM INSTALLATION (AMBIENT/WHITE NOISE)
FIGURE 1-8. TILT SENSOR INSTALLATION
FIGURE 1-9. BEACON/STROBE LIGHT INSTALLATION - SINGLE (WITHOUT CLEARSKY)
FIGURE 1-10. BEACON/STROBE LIGHT INSTALLATION - DUAL (WITHOUT CLEARSKY)
FIGURE 1-11. BEACON/STROBE LIGHT INSTALLATION - DUAL (WITH CLEARSKY)
FIGURE 1-12. BATTERY DOOR & FRAME COVERS INSTALLATION
FIGURE 1-13. LADDER INSTALLATION
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENTS INSTALLATION
FIGURE 2-2. MOTOR/PUMP/TANK ASSEMBLY
FIGURE 2-3. ELECTRICAL COMPONENTS INSTALLATION (WITHOUT LSS)
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION (LSS)
FIGURE 2-5. BATTERY TRAY INSTALLATION
FIGURE 2-6. BATTERIES INSTALLATION - STANDARD BATTERIES WITHOUT DISCONNECT
FIGURE 2-7. BATTERIES INSTALLATION - STANDARD BATTERIES WITH DISCONNECT
FIGURE 2-8. BATTERIES INSTALLATION - AGM BATTERIES WITHOUT DISCONNECT
FIGURE 2-9. BATTERIES INSTALLATION - AGM BATTERIES WITH DISCONNECT
FIGURE 2-10. BATTERIES INSTALLATION - AGM VISION BATTERIES WITHOUT DISCONNECT
FIGURE 2-11. BATTERIES INSTALLATION - AGM VISION BATTERIES WITH DISCONNECT
FIGURE 2-12. BATTERIES INSTALLATION - LITHIUM
FIGURE 2-13. BATTERY CHARGER INSTALLATION (DELTA - Q - 650W)
FIGURE 2-14. BATTERY CHARGER INSTALLATION (GREENPOWER)
SECTION 3 - SCISSOR ARMSFIGURE 3-1. SCISSOR ARMS INSTALLATION (WITHOUT LSS) (Prior to SN B200099006)
FIGURE 3-2. SCISSOR ARMS INSTALLATION (WITHOUT LSS) (SN B20009906 to Present)
FIGURE 3-3. SCISSOR ARMS INSTALLATION (WITH LSS) (Prior to SN B200099006)
FIGURE 3-4. SCISSOR ARMS INSTALLATION (WITH LSS) (SN B20009906 to Present)
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION (Prior to SN B200099006)
FIGURE 4-2. PLATFORM INSTALLATION (SN B200099006 to Present)
FIGURE 4-3. PLATFORM EXTENSION INSTALLATION
FIGURE 4-4. RAILS INSTALLATION (1.1M TUBE IN TUBE)
FIGURE 4-5. RAILS INSTALLATION (1.0M TUBE IN TUBE)
FIGURE 4-6. RAILS INSTALLATION (SIDE BY SIDE)
FIGURE 4-7. GATE LATCH INSTALLATION
FIGURE 4-8. PLATFORM CONSOLE INSTALLATION
FIGURE 4-9. CONTROLLER ASSEMBLY
FIGURE 4-10. PLATFORM CONTROL PLUG INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY
SECTION 6 - ELECTRICALFIGURE 6-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 6-2. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 6-3. AC BOX AT PLATFORM INSTALLATION - 220V CHINA PLUG (CHINA SPECS)
FIGURE 6-4. AC BOX AT PLATFORM INSTALLATION - 220V LOCALLY SUPPLIED
FIGURE 6-5. BREAKER BOX KIT WITH 3 BREAKER
FIGURE 6-6. CAN SPLICE HARNESS
FIGURE 6-7. CHARGER HARNESS
FIGURE 6-8. CHARGER JUMPER HARNESS
FIGURE 6-9. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG FOR DELTA-Q CHARGER) (ALL SPECS EXCEPT AUSTRALIAN SPECS)
FIGURE 6-10. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG FOR GREEN POWER CHARGER)
FIGURE 6-11. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG FOR GREEN POWER CHARGER) (CHINA SPECS)
FIGURE 6-12. CHARGER PLUG INSTALLATION (110V PLUG) (ANSI & CSA SPECS)
FIGURE 6-13. CHARGER PLUG INSTALLATION (CHINA PLUG FOR DELTA-Q CHARGER) (CHINA SPECS)
FIGURE 6-14. CHARGER PLUG INSTALLATION (KOREAN PLUG) (KOREAN SPECS)
FIGURE 6-15. CHASSIS HARNESS (WITHOUT LSS)
FIGURE 6-16. CHASSIS HARNESS (WITH LSS)
FIGURE 6-17. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 6-18. DRIVE CONTROL HARNESS
FIGURE 6-19. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 6-20. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 6-21. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 6-22. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 6-23. LIFT DOWN HARNESS (WITHOUT LSS)
FIGURE 6-24. LIFT DOWN HARNESS (WITH LSS)
FIGURE 6-25. LITHIUM BATTERY HARNESS
FIGURE 6-26. MOBILE CONTROL HARNESS
FIGURE 6-27. PLATFORM CONTROL BOX HARNESS
FIGURE 6-28. RECEPTACLE BOX KIT - 110V GFI
FIGURE 6-29. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
SECTION 7 - DECALSFIGURE 7-1. DECALS INSTALLATION (ANSI SPECS)
FIGURE 7-2. DECALS INSTALLATION (CHINA SPECS)
FIGURE 7-3. DECALS INSTALLATION (CSA SPECS)
FIGURE 7-4. DECALS INSTALLATION (JAPANESE SPECS)
FIGURE 7-5. DECALS INSTALLATION (KOREAN SPECS)
FIGURE 7-6. DECAL INSTALLATION - OPTIONS
SECTION 8 - RECOMMENDED SERVICE PARTS STOCKFIGURE 8-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 9 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 9-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
