JLG Scissor Lift ES1530L Parts Catalog 31220311
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1530L Scissor Lift
Part Number: 31220311
Publication Date: 2025
Number of Pages: 266 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEER INSTALLATION
FIGURE 1-2. DRIVE COMPONENTS INSTALLATION
FIGURE 1-3. DRIVE MOTOR ASSEMBLY
FIGURE 1-4. TIRE/WHEEL INSTALLATION
FIGURE 1-5. POTHOLE PROTECTION SYSTEM INSTALLATION
FIGURE 1-6. TILT SENSOR INSTALLATION
FIGURE 1-7. BATTERY CHARGER INSTALLATION - DELTA-Q (LESS AC CABLE)
FIGURE 1-8. BATTERY CHARGER INSTALLATION - DELTA-Q WITH CAN TERMINAL (LESS AC CABLE)
FIGURE 1-9. BATTERY CHARGER INSTALLATION - GREEN POWER (LESS AC CABLE)
FIGURE 1-10. STROBE LIGHT INSTALLATION - SINGLE (AMBER) (WITH GUARD)
FIGURE 1-11. STROBE LIGHT INSTALLATION - DUAL (AMBER) (WITH GUARD)
FIGURE 1-12. ALARM INSTALLATION (AMBIENT/WHITE NOISE)
FIGURE 1-13. LADDER INSTALLATION (ALL SPECS EXCEPT JAPANESE SPECS)
FIGURE 1-14. LADDER INSTALLATION (JAPANESE SPECS)
FIGURE 1-15. FRAME COVER INSTALLATION
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENT INSTALLATION
FIGURE 2-2. MOTOR/PUMP/TANK ASSEMBLY
FIGURE 2-3. CLEANGUARD INSTALLATION
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION (WITHOUT LSS)(WITH METAL E-STOP)
FIGURE 2-5. ELECTRICAL COMPONENTS INSTALLATION (WITHOUT LSS)(WITH PLASTIC E-STOP)
FIGURE 2-6. ELECTRICAL COMPONENTS INSTALLATION (WITH LSS) (Prior to SN B200079316, Prior to SN M200064531, Except SN B200079181 through B200079260, Except SN B200079304 through B200079308)
FIGURE 2-7. ELECTRICAL COMPONENTS INSTALLATION (WITH LSS) (SN B200079181 through B200079260, SN B200079304 through B200079308, SN B200079316 to Present, SN M200064531 to Present)
FIGURE 2-8. MOBILE CONTROL INSTALLATION
FIGURE 2-9. MDI INSTALLATION
FIGURE 2-10. BATTERIES INSTALLATION - STANDARD BATTERIES WITHOUT DISCONNECT
FIGURE 2-11. BATTERIES INSTALLATION - STANDARD BATTERIES WITH DISCONNECT
FIGURE 2-12. BATTERIES INSTALLATION - AGM BATTERIES WITHOUT DISCONNECT
FIGURE 2-13. BATTERIES INSTALLATION - AGM VISION BATTERIES WITHOUT DISCONNECT
FIGURE 2-14. BATTERIES INSTALLATION - AGM BATTERIES WITH DISCONNECT
FIGURE 2-15. BATTERIES INSTALLATION - AGM VISION BATTERIES WITH DISCONNECT
FIGURE 2-16. DOORS INSTALLATION
SECTION 3 - SCISSOR ARMSFIGURE 3-1. SCISSOR ARMS INSTALLATION (WITHOUT LSS)
FIGURE 3-2. SCISSOR ARMS INSTALLATION (WITH LSS)
FIGURE 3-3. ARM GUARDS INSTALLATION
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION
FIGURE 4-2. PLATFORM EXTENSION INSTALLATION
FIGURE 4-3. RAILS INSTALLATION (1.0M TUBE IN TUBE)
FIGURE 4-4. RAILS INSTALLATION (1.1M TUBE IN TUBE)
FIGURE 4-5. RAILS INSTALLATION (SIDE BY SIDE)
FIGURE 4-6. GATE LATCH INSTALLATION
FIGURE 4-7. PLATFORM CONSOLE INSTALLATION (ALL SPECS)
FIGURE 4-8. PLATFORM CONTROL PLUG INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY
FIGURE 5-2. STEER CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM
SECTION 7 - ELECTRICALFIGURE 7-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 7-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 7-3. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 7-4. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 7-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 7-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 7-7. AC BOX AT PLATFORM INSTALLATION - 220V AUSTRALIAN PLUG (AUSTRALIAN SPECS)
FIGURE 7-8. AC BOX AT PLATFORM INSTALLATION - 220V CHINA PLUG (CHINA SPECS)
FIGURE 7-9. AC BOX AT PLATFORM INSTALLATION - 220V LOCALLY SUPPLIED
FIGURE 7-10. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (AUSTRALIAN SPECS)
FIGURE 7-11. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 7-12. BREAKER BOX KIT WITH 3 BREAKER
FIGURE 7-13. CAN SPLICE HARNESS
FIGURE 7-14. CHARGER HARNESS
FIGURE 7-15. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG) (ALL SPECS EXCEPT ANSI & AUSTRALIAN SPECS)
FIGURE 7-16. CHARGER PLUG INSTALLATION (110V PLUG) (ANSI & CSA SPECS)
FIGURE 7-17. CHARGER PLUG INSTALLATION (AUSTRALIAN PLUG) (AUSTRALIAN SPECS)
FIGURE 7-18. CHARGER PLUG INSTALLATION (110V IEC YELLOW PLUG) (CE & UK CA SPECS)
FIGURE 7-19. CHARGER PLUG INSTALLATION (220V IEC BLUE PLUG) (CE & UK CA SPECS)
FIGURE 7-20. CHARGER PLUG INSTALLATION (220V CEE7 PLUG) (CE & UK CA SPECS)
FIGURE 7-21. CHARGER PLUG INSTALLATION (220V AFSINT107 PLUG) (CE & UK CA SPECS)
FIGURE 7-22. CHARGER PLUG INSTALLATION (CHINA PLUG) (CHINA SPECS)
FIGURE 7-23. CHARGER PLUG INSTALLATION (KOREAN PLUG) (KOREAN SPECS)
FIGURE 7-24. CHASSIS HARNESS (WITHOUT LSS)(WITH METAL E-STOP)
FIGURE 7-25. CHASSIS HARNESS (WITHOUT LSS) (WITH PLASTIC E-STOP)
FIGURE 7-26. CHASSIS HARNESS (WITH LSS) (Prior to SN B200079316, Prior to SN M200064531, Except SN B200079181 through B200079260, Except SN B200079304 through B200079308)
FIGURE 7-27. CHASSIS HARNESS (WITH LSS) (SN B200079181 through B200079260, SN B200079304 through B200079308, SN B200079316 to Present, SN M200064531 to Present)
FIGURE 7-28. DRIVE CONTROL HARNESS
FIGURE 7-29. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-30. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-31. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-32. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-33. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-34. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-35. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-36. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-37. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-38. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-39. LIFT DOWN HARNESS (WITHOUT LSS)
FIGURE 7-40. LIFT DOWN HARNESS (WITH LSS)
FIGURE 7-41. PLATFORM CONTROL BOX HARNESS
FIGURE 7-42. RECEPTACLE BOX KIT - 110V GFI
FIGURE 7-43. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 7-44. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 7-45. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 7-46. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 7-47. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 7-48. INVERTER INSTALLATION
FIGURE 7-49. HARNESS, AC EXTENSION
FIGURE 7-50. HARNESS, INVERTER
SECTION 8 - DECALSFIGURE 8-1. DECALS INSTALLATION (ANSI SPECS)
FIGURE 8-2. DECALS INSTALLATION (CE & UK CA SPECS)
FIGURE 8-3. DECALS INSTALLATION (CHINA SPECS)
FIGURE 8-4. DECALS INSTALLATION (CSA SPECS)
FIGURE 8-5. DECALS INSTALLATION (JAPANESE SPECS)
FIGURE 8-6. DECALS INSTALLATION (KOREAN SPECS)
FIGURE 8-7. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 10-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
