JLG Scissor Lift ES1330L Parts Catalog 31221555
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1330L Scissor Lift
Part Number: 31221555
Publication Date: 2025
Number of Pages: 276 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEER INSTALLATION
FIGURE 1-2. DRIVE COMPONENTS INSTALLATION (OMNIGEAR)
FIGURE 1-3. DRIVE COMPONENTS INSTALLATION (DANA/FAIRFIELD)
FIGURE 1-4. DRIVE MOTOR ASSEMBLY (OMNIGEAR)
FIGURE 1-5. DRIVE MOTOR ASSEMBLY (RH) (DANA/FAIRFIELD)
FIGURE 1-6. DRIVE MOTOR ASSEMBLY (LH) (DANA/FAIRFIELD)
FIGURE 1-7. TIRE/WHEEL INSTALLATION
FIGURE 1-8. POTHOLE PROTECTION SYSTEM INSTALLATION
FIGURE 1-9. TILT SENSOR INSTALLATION
FIGURE 1-10. BATTERY CHARGER INSTALLATION - DELTA-Q (LESS AC CABLE)
FIGURE 1-11. BATTERY CHARGER INSTALLATION - DELTA-Q WITH CAN TERMINAL (LESS AC CABLE)
FIGURE 1-12. BATTERY CHARGER INSTALLATION - GREEN POWER (LESS AC CABLE)
FIGURE 1-13. BEACON/STROBE LIGHT INSTALLATION - SINGLE (WITHOUT CLEARSKY BEACON)
FIGURE 1-14. BEACON/STROBE LIGHT INSTALLATION - DUAL (WITHOUT CLEARSKY BEACON)
FIGURE 1-15. BEACON/STROBE LIGHT INSTALLATION - SECOND (WITH CLEARSKY BEACON)
FIGURE 1-16. ALARM INSTALLATION (AMBIENT/WHITE NOISE)
FIGURE 1-17. LADDER INSTALLATION
FIGURE 1-18. FRAME COVER INSTALLATION
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENT INSTALLATION
FIGURE 2-2. MOTOR/PUMP/TANK ASSEMBLY
FIGURE 2-3. CLEANGUARD INSTALLATION
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION (WITH PLATFORM DRIVE SELECT SWITCH) (MACHINES WITH SN STARTING WITH 12, B2, G2 & M2)
FIGURE 2-5. MDI INSTALLATION
FIGURE 2-6. BATTERIES INSTALLATION - STANDARD BATTERIES WITHOUT DISCONNECT
FIGURE 2-7. BATTERIES INSTALLATION - STANDARD BATTERIES WITH DISCONNECT
FIGURE 2-8. BATTERIES INSTALLATION - AGM BATTERIES WITHOUT DISCONNECT
FIGURE 2-9. BATTERIES INSTALLATION - AGM VISION BATTERIES WITHOUT DISCONNECT
FIGURE 2-10. BATTERIES INSTALLATION - AGM BATTERIES WITH DISCONNECT
FIGURE 2-11. BATTERIES INSTALLATION - AGM VISION BATTERIES WITH DISCONNECT
FIGURE 2-12. DOORS INSTALLATION
SECTION 3 - SCISSOR ARMSFIGURE 3-1. SCISSOR ARMS INSTALLATION (WITH LSS)
FIGURE 3-2. SCISSOR ARMS INSTALLATION (WITH LSS) (SN B200087206 to Present, SN M200080321 to Present)
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION
FIGURE 4-2. PLATFORM EXTENSION INSTALLATION
FIGURE 4-3. RAILS INSTALLATION (1.0M TUBE IN TUBE) (Prior to SN B200091546, Prior to SN M200092801)
FIGURE 4-4. RAILS INSTALLATION (1.0M TUBE IN TUBE) (SN B200091546 to Present, SN M200092801 to Present)
FIGURE 4-5. RAILS INSTALLATION (1.1M TUBE IN TUBE) (Prior to SN B200091546, Prior to SN M200092801)
FIGURE 4-6. RAILS INSTALLATION (1.1M TUBE IN TUBE) (SN B200091546 to Present, SN M200092801 to Present)
FIGURE 4-7. RAILS INSTALLATION (SIDE BY SIDE) (Prior to SN B200091546, Prior to SN M200092801)
FIGURE 4-8. RAILS INSTALLATION (SIDE BY SIDE) (SN B200091546 to Present, SN M200092801 to Present)
FIGURE 4-9. GATE LATCH INSTALLATION
FIGURE 4-10. PLATFORM CONSOLE INSTALLATION (ALL SPECS)
FIGURE 4-11. PLATFORM CONTROL PLUG INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY
FIGURE 5-2. STEER CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM
SECTION 7 - ELECTRICALFIGURE 7-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 7-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 7-3. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 7-4. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 7-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 7-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 7-7. AC BOX AT PLATFORM INSTALLATION - 220V AUSTRALIAN PLUG (AUSTRALIAN SPECS)
FIGURE 7-8. AC BOX AT PLATFORM INSTALLATION - 220V CHINA PLUG (CHINA SPECS)
FIGURE 7-9. AC BOX AT PLATFORM INSTALLATION - 220V LOCALLY SUPPLIED
FIGURE 7-10. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (AUSTRALIAN SPECS)
FIGURE 7-11. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 7-12. BREAKER BOX KIT WITH 3 BREAKER
FIGURE 7-13. CHARGER HARNESS
FIGURE 7-14. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG) (ALL SPECS EXCEPT ANSI & AUSTRALIAN SPECS)
FIGURE 7-15. CHARGER PLUG INSTALLATION (110V PLUG) (ANSI & CSA SPECS)
FIGURE 7-16. CHARGER PLUG INSTALLATION (AUSTRALIAN PLUG) (AUSTRALIAN SPECS)
FIGURE 7-17. CHARGER PLUG INSTALLATION (110V IEC YELLOW PLUG) (CE & UK CA SPECS)
FIGURE 7-18. CHARGER PLUG INSTALLATION (220V IEC BLUE PLUG) (CE & UK CA SPECS)
FIGURE 7-19. CHARGER PLUG INSTALLATION (220V CEE7 PLUG) (CE & UK CA SPECS)
FIGURE 7-20. CHARGER PLUG INSTALLATION (220V AFSINT107 PLUG) (CE & UK CA SPECS)
FIGURE 7-21. CHARGER PLUG INSTALLATION (CHINA PLUG) (CHINA SPECS)
FIGURE 7-22. CHARGER PLUG INSTALLATION (KOREAN PLUG) (KOREAN SPECS)
FIGURE 7-23. CHASSIS HARNESS
FIGURE 7-24. DRIVE CONTROL HARNESS
FIGURE 7-25. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 7-26. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE & UK CA SPECS) (Prior to SN B200092144, Prior to SN M200087659)
FIGURE 7-27. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS) (Prior to SN B200092144, Prior to SN M200087659)
FIGURE 7-28. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 7-29. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS) (Prior to SN B200092144, Prior to SN M200087659)
FIGURE 7-30. CLEARSKY CS550 BEACON INSTALLATION (SN B200092144 to Present, SN M200087659 to Present)
FIGURE 7-31. CLEARSKY HARNESS - 3-WIRE TELEMATICS (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 7-32. CLEARSKY JUMPER HARNESS - 3-WIRE TELEMATICS (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 7-33. CLEARSKY HARNESS - CANBUS TELEMATICS (Prior to SN B200092144, Prior to SN M200087659)
FIGURE 7-34. CLEARSKY SPLICE HARNESS - CANBUS TELEMATICS (Prior to SN B200092144, Prior to SN M200087659)
FIGURE 7-35. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-36. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-37. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-38. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-39. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-40. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-41. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-42. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-43. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-44. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-45. LIFT DOWN HARNESS (WITH LSS)
FIGURE 7-46. LIFT DOWN HARNESS (WITH LSS) (SN B200087206 to Present, SN M200080321 to Present)
FIGURE 7-47. PLATFORM CONTROL BOX HARNESS
FIGURE 7-48. RECEPTACLE BOX KIT - 110V GFI
FIGURE 7-49. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 7-50. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 7-51. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 7-52. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 7-53. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 7-54. INVERTER INSTALLATION
FIGURE 7-55. HARNESS, AC EXTENSION
FIGURE 7-56. HARNESS, INVERTER
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION (ANSI SPECS)
FIGURE 8-2. DECAL INSTALLATION (AUSTRALIAN SPECS)
FIGURE 8-3. DECAL INSTALLATION (CE & UK CA SPECS)
FIGURE 8-4. DECAL INSTALLATION (CHINA SPECS)
FIGURE 8-5. DECAL INSTALLATION (CSA SPECS)
FIGURE 8-6. DECAL INSTALLATION (KOREAN SPECS)
FIGURE 8-7. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 10-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
