JLG Scissor Lift ES1330L Parts Catalog 31220310
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG ES1330L Scissor Lift
Part Number: 31220310
Publication Date: 2025
Number of Pages: 242 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEER INSTALLATION
FIGURE 1-2. DRIVE COMPONENTS INSTALLATION
FIGURE 1-3. DRIVE MOTOR ASSEMBLY
FIGURE 1-4. TIRE/WHEEL INSTALLATION
FIGURE 1-5. POTHOLE PROTECTION SYSTEM INSTALLATION
FIGURE 1-6. TILT SENSOR INSTALLATION
FIGURE 1-7. BATTERY CHARGER INSTALLATION - DELTA-Q (LESS AC CABLE)
FIGURE 1-8. BATTERY CHARGER INSTALLATION - DELTA-Q WITH CAN TERMINAL (LESS AC CABLE)
FIGURE 1-9. BATTERY CHARGER INSTALLATION - GREEN POWER (LESS AC CABLE)
FIGURE 1-10. STROBE LIGHT INSTALLATION - SINGLE (AMBER) (WITH GUARD)
FIGURE 1-11. STROBE LIGHT INSTALLATION - DUAL (AMBER) (WITH GUARD)
FIGURE 1-12. ALARM INSTALLATION (AMBIENT/WHITE NOISE)
FIGURE 1-13. LADDER INSTALLATION
FIGURE 1-14. FRAME COVER INSTALLATION
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENT INSTALLATION
FIGURE 2-2. MOTOR/PUMP/TANK ASSEMBLY
FIGURE 2-3. CLEANGUARD INSTALLATION
FIGURE 2-4. ELECTRICAL COMPONENTS INSTALLATION (WITH LSS) (SN B200079239 through B200079240, SN B200079243 through B200079243, SN B200079309 through M200064527, SN M200064623 through M200064631, SN M200064633 through M200064730, SN M200064735 through ...
FIGURE 2-5. MOBILE CONTROL INSTALLATION
FIGURE 2-6. MDI INSTALLATION
FIGURE 2-7. BATTERIES INSTALLATION - STANDARD BATTERIES WITHOUT DISCONNECT
FIGURE 2-8. BATTERIES INSTALLATION - STANDARD BATTERIES WITH DISCONNECT
FIGURE 2-9. BATTERIES INSTALLATION - AGM BATTERIES WITHOUT DISCONNECT
FIGURE 2-10. BATTERIES INSTALLATION - AGM VISION BATTERIES WITHOUT DISCONNECT
FIGURE 2-11. BATTERIES INSTALLATION - AGM BATTERIES WITH DISCONNECT
FIGURE 2-12. BATTERIES INSTALLATION - AGM VISION BATTERIES WITH DISCONNECT
FIGURE 2-13. DOORS INSTALLATION
SECTION 3 - SCISSOR ARMSFIGURE 3-1. SCISSOR ARMS INSTALLATION (WITH LSS)
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION
FIGURE 4-2. PLATFORM EXTENSION INSTALLATION
FIGURE 4-3. RAILS INSTALLATION (1.0M TUBE IN TUBE)
FIGURE 4-4. RAILS INSTALLATION (1.1M TUBE IN TUBE)
FIGURE 4-5. RAILS INSTALLATION (SIDE BY SIDE)
FIGURE 4-6. GATE LATCH INSTALLATION
FIGURE 4-7. PLATFORM CONSOLE INSTALLATION (ALL SPECS)
FIGURE 4-8. PLATFORM CONTROL PLUG INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY
FIGURE 5-2. STEER CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM
SECTION 7 - ELECTRICALFIGURE 7-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 7-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 7-3. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 7-4. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 7-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 7-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 7-7. AC BOX AT PLATFORM INSTALLATION - 220V AUSTRALIAN PLUG (AUSTRALIAN SPECS)
FIGURE 7-8. AC BOX AT PLATFORM INSTALLATION - 220V CHINA PLUG (CHINA SPECS)
FIGURE 7-9. AC BOX AT PLATFORM INSTALLATION - 220V LOCALLY SUPPLIED
FIGURE 7-10. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (AUSTRALIAN SPECS)
FIGURE 7-11. BREAKER BOX KIT WITH 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 7-12. BREAKER BOX KIT WITH 3 BREAKER
FIGURE 7-13. CAN SPLICE HARNESS
FIGURE 7-14. CHARGER HARNESS
FIGURE 7-15. CHARGER PLUG INSTALLATION (LOCALLY SUPPLIED PLUG) (ALL SPECS EXCEPT ANSI & AUSTRALIAN SPECS)
FIGURE 7-16. CHARGER PLUG INSTALLATION (110V PLUG) (ANSI & CSA SPECS)
FIGURE 7-17. CHARGER PLUG INSTALLATION (AUSTRALIAN PLUG) (AUSTRALIAN SPECS)
FIGURE 7-18. CHARGER PLUG INSTALLATION (110V IEC YELLOW PLUG) (CE & UK CA SPECS)
FIGURE 7-19. CHARGER PLUG INSTALLATION (220V IEC BLUE PLUG) (CE & UK CA SPECS)
FIGURE 7-20. CHARGER PLUG INSTALLATION (220V CEE7 PLUG) (CE & UK CA SPECS)
FIGURE 7-21. CHARGER PLUG INSTALLATION (220V AFSINT107 PLUG) (CE & UK CA SPECS)
FIGURE 7-22. CHARGER PLUG INSTALLATION (CHINA PLUG) (CHINA SPECS)
FIGURE 7-23. CHARGER PLUG INSTALLATION (KOREAN PLUG) (KOREAN SPECS)
FIGURE 7-24. CHASSIS HARNESS (WITH LSS) (SN B200079239 through B200079240, SN B200079243 through B200079243, SN B200079309 through M200064527, SN M200064623 through M200064631, SN M200064633 through M200064730, SN M200064735 through M200064912, SN M20...
FIGURE 7-25. DRIVE CONTROL HARNESS
FIGURE 7-26. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-27. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-28. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-29. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-30. GROUND TO PLATFORM CABLE INSTALLATION - WITHOUT PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-31. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-32. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH
FIGURE 7-33. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITHOUT FOOTSWITCH (AUSTRALIAN SPECS)
FIGURE 7-34. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITHOUT AC CABLE/WITH FOOTSWITCH
FIGURE 7-35. GROUND TO PLATFORM CABLE INSTALLATION - WITH PLATFORM COIL CABLE/WITH AC CABLE/WITH FOOTSWITCH
FIGURE 7-36. LIFT DOWN HARNESS (WITH LSS)
FIGURE 7-37. PLATFORM CONTROL BOX HARNESS
FIGURE 7-38. RECEPTACLE BOX KIT - 110V GFI
FIGURE 7-39. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 7-40. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 7-41. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 7-42. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 7-43. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 7-44. INVERTER INSTALLATION
FIGURE 7-45. HARNESS, AC EXTENSION
FIGURE 7-46. HARNESS, INVERTER
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION (ANSI SPECS)
FIGURE 8-2. DECAL INSTALLATION (AUSTRALIAN SPECS)
FIGURE 8-3. DECAL INSTALLATION (CE & UK CA SPECS)
FIGURE 8-4. DECAL INSTALLATION (CHINA SPECS)
FIGURE 8-5. DECAL INSTALLATION (CSA SPECS)
FIGURE 8-6. DECAL INSTALLATION (JAPANESE SPECS)
FIGURE 8-7. DECAL INSTALLATION (KOREAN SPECS)
FIGURE 8-8. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 10-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
