JLG Scissor Lift AE1932 Service & Maintenance Manual 31217449 2025
Brand: JLG
Type of Machine: Scissor Lift
Type of Manual: Service & Maintenance Manual, Electric Diagram
Model: JLG AE1932 Scissor Lift
Part Number: 31217449
Publication Date: 2025
Number of Pages: 172 Pages
Brand: JLG
Section 1. Specifications
1.1 Operating Specifications
Machine Specifications
Platform Capacities
Machine Dimensional Data
Tires
Battery
Motors
Tilt Alarm
High Drive Speed Cutout Height
Lubrication Specifications
SAE Fastener Torque Chart
SAE Fastener Torque Chart (Continued)
Metric Fastener Torque Chart
Metric Fastener Torque Chart (Continued)
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance
General
Pre-Start Inspection
Pre-Delivery Inspection and Frequent Inspection
Annual Machine Inspection
Preventative Maintenance
Maintenance and Inspection Schedule Codes:
Scissor Arm - Inspection Prop
General
Safety and Workmanship
Cleanliness
Components Removal and Installation
Component Disassembly and Reassembly
Pressure-Fit Parts
Bearings
Gaskets
Bolt Usage and Torque Application
Lubrication
Battery
Section 3. Chassis & Scissor Arms
3.1 Left and Right Side component compartments
3.2 Battery System Maintenance/ Troubleshooting
Battery Management System (BMS)
State of Charge (SOC)
Battery Quick-Disconnect
Battery Status Indicator (LED)
Delta-Q - Battery Charger
Battery Charger Maintenance
To remove cover for access
To remove the module from the machine
Removal
Installation
Components Location
Removal
Installation
Overview of Control Station Components
Installation/Removal
Control Station Disassembly
Joystick Controller
Tilt Sensor Removal
Tilt Sensor Installation
Rotary Angle Sensor Installation
Drive Motor Covers Installation
Tire Wear and Damage
Wheel and Tire Replacement
Wheel Installation
Removing Scissor Arm Assembly as a Complete Unit
Removing/installing Scissor Arms Individually
Section 4. Actuators
4.1 Lift Actuator
Removal
Installation
Lift Actuator Manual Override
Disassembly
Assembly
Disassembly
Assembly
Disassembly
Assembly
Disassembly
Assembly
Disassembly
Assembly
Removal
Installation
Steer Actuator Manual Override
Section 5. JLG Control System
5.1 Mobile Diagnostic Device
Download DaVinciGO App
Connect Mobile Device To Machine
Machine Power on Setting
Connect to Machine Via Bluetooth
Login to Access Level
Calibration Adjustment
Downloading Software
Installing Software
New Software Calibration
Overview
Working
Connection
Section 6. LSS (LOAD SENSING SYSTEM) Service
6.1 LSS (Load Sensing System)
Diagnostic Menu
Calibration
Testing
LSS Troubleshooting
Section 7. Diagnostic Trouble Codes
7.1 Introduction
System Fault/DTC Indication
Section 8. General Electrical Information & Schematics
8.1 General
8.2 Multimeter Basics
Grounding
Backprobing
Min/Max
Polarity
Scale
Voltage Measurement
Resistance Measurement
Continuity Measurement
Current Measurement
Continuity Measurement Over Long Distances
Requirements:
Procedure
Installation
AMP Mate-N-Lok
AMP Faston
AMP Micro-Fit
AMP Mini Fit Jr
Mini Fit Sr
DIN Connectors
Exceptions
Scissor Platform Cable at the Platform Control
Assembly
Disassembly
Wedge Lock
Service - Voltage Reading
DT/DTP Series Assembly
DT/DTP Series Disassembly
HD30/HDP20 Series Assembly
HD30/HDP20 Series Disassembly
Basic check
Limit Switches
Automatic Switches
Switch Wiring - Low Side, High Side
- SuperPac Parts Manual
- StratoLift Parts Manual
