Hyundai
86
176,834
JLG Scissor Lift AE1932 Service & Maintenance Manual 31215911 2025
Brand: JLG
Type of Machine: Scissor Lift
Type of Manual: Service & Maintenance Manual, Electric Diagrams
Model: JLG AE1932 Scissor Lift
Part Number: 31215911
Publication Date: 2025
Number of Pages: 166 Pages
31215911_C_AE1932_JLG_Service_English
Section A. Introduction - Maintenance Safety Precautions​
General​
Maintenance​
Table of Contents​
List of Figures​
List of Tables​
Section 1. Specifications​
1.1 Operating Specifications​
Machine Specifications​
Platform Capacities​
Machine Dimensional Data​
Tires​
Battery​
Motors​
Electrical System​
Tilt Alarm​
High Drive Speed Cutout Height​
Lubrication Specifications​
SAE Fastener Torque Chart​
SAE Fastener Torque Chart (Continued)​
Metric Fastener Torque Chart​
Metric Fastener Torque Chart (Continued)​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
General​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
Maintenance and Inspection Schedule Codes:​
Scissor Arm - Inspection Prop​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Lubrication​
Battery​
Section 3. Chassis & Scissor Arms​
3.1 Left and Right Side component compartments​
3.2 Battery System Maintenance/ Troubleshooting​
Battery Management System (BMS)​
State of Charge (SOC)​
Battery Quick-Disconnect​
Battery Status Indicator (LED)​
Delta-Q - Battery Charger​
Battery Charger Maintenance​
To remove cover for access​
To remove the module from the machine​
Removal​
Installation​
Components Location​
Removal​
Installation​
Overview of Control Station Components​
Installation/Removal​
Control Station Disassembly​
Joystick Controller​
Tilt Sensor Removal​
Tilt Sensor Installation​
Rotary Angle Sensor Installation​
Drive Motor Covers Installation​
Tire Wear and Damage​
Wheel and Tire Replacement​
Wheel Installation​
Removing Scissor Arm Assembly as a Complete Unit​
Removing/installing Scissor Arms Individually​
Section 4. Actuators​
4.1 Lift Actuator​
Removal​
Installation​
Lift Actuator Manual Override​
Disassembly​
Assembly​
Disassembly​
Assembly​
Disassembly​
Assembly​
Disassembly​
Assembly​
Disassembly​
Assembly​
Removal​
Installation​
Steer Actuator Manual Override​
Section 5. JLG Control System​
5.1 Mobile Diagnostic Device​
Download DaVinciGO App​
Connect Mobile Device To Machine​
Machine Power on Setting​
Connect to Machine Via Bluetooth​
Login to Access Level​
Calibration Adjustment​
Downloading Software​
Installing Software​
New Software Calibration​
Overview​
Working​
Connection​
Section 6. LSS (LOAD SENSING SYSTEM) Service​
6.1 LSS (Load Sensing System)​
Diagnostic Menu​
Calibration​
Testing​
LSS Troubleshooting​
Section 7. Diagnostic Trouble Codes​
7.1 Introduction​
System Fault/DTC Indication​
Section 8. General Electrical Information & Schematics​
8.1 General​
8.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Voltage Measurement​
Resistance Measurement​
Continuity Measurement​
Current Measurement​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
Installation​
AMP Mate-N-Lok​
AMP Faston​
AMP Micro-Fit​
AMP Mini Fit Jr​
Mini Fit Sr​
DIN Connectors​
Exceptions​
Scissor Platform Cable at the Platform Control​
Assembly​
Disassembly​
Wedge Lock​
Service - Voltage Reading​
DT/DTP Series Assembly​
DT/DTP Series Disassembly​
HD30/HDP20 Series Assembly​
HD30/HDP20 Series Disassembly​
Basic check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
