Hyundai
86
176,834
JLG Scissor Lift 530LRT Service & Maintenance Manual 3121708 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 530LRT Scissor Lift
SN 1200027648 -1200027657
Prior to SN E200000676
Part Number: 3121708
Publication Date: 2025
Number of Pages: 194 Pages
Section A. Maintenance Safety Precautions
General​
Hydraulic System Safety​
Maintenance​
Section 1. Specifications
1.1 Specifications​
Operating Specifications​
Dimensional Data​
Capacities​
Tires​
Critical Stability Weights​
Major Component Weights​
1.2 Engine Specifications​
Kubota (D1305-E4B - T4F - Diesel)​
Kubota (D1305-E3B - T4i - Diesel)​
Kubota (WG972-GL-E4F -T3 - Dual Fuel)​
1.3 Hydraulic Pressure Settings​
1.4 Hydraulic Cylinder Specifications​
1.5 Serial Number Locations​
1.6 Elevation/Tilt Limit Settings​
1.7 Lubrication​
1.8 Torque Charts​
SAE Fasteners​
Metric Fasteners​
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance​
General​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
2.2 Preventive Maintenance and Inspection Schedule​
Footnotes and Performance Codes​
Schedule​
2.3 Service and Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication​
Battery​
Lubrication and Servicing​
2.4 Lubrication and Information​
Hydraulic System​
Hydraulic Oil​
Changing Hydraulic Oil​
Lubrication Specifications​
2.5 Service Maintenance Components​
Setting Scissor Arm Safety Prop​
General Maintenance Tips​
Fuel Tank​
Drive Hub​
Scissor Arms - Sliding Wear Pads​
Hydraulic Oil Tank​
Engine - Oil Change w/Filter - Kubota - (WG972-GL- E4F -T3) Dual Fuel​
Engine - Oil Change w/Filter - Kubota (D1305-E4B - T4F - Diesel) and (D1305-E3B - T4 - Diesel)​
Fuel/Water Separator Filter (Diesel) - Kubota​
Hydraulic Charge Filter (Diesel) - Kubota​
Fuel Strainer (Diesel) - Kubota​
Fuel Filter (Gas) - Kubota​
Air Filter​
2.6 Cylinder Drift Test​
Platform Drift​
Cylinder Drift​
2.7 Pins and Composite Bearing Repair Guidelines​
Section 3. Chassis, Platform & Scissor Arms
3.1 Operating Characteristics​
Leveling Jacks​
Generator​
Lift​
Drive​
3.2 Tires, Wheels, & Drive Assembly​
Tire Inflation​
Tire Damage​
Tire Replacement​
Wheel Replacement​
Wheel Installation​
Drive Assembly​
3.3 Drive Hub (Fairfield)​
Roll and Leak Testing​
Tightening and Torquing Bolts​
Oil Information​
Main Disassembly for Drive Hub​
Hub-Spindle Disassembly​
Cover Disassembly​
Carrier Disassembly​
Assembly of the Carrier​
Cover Sub-Assembly​
Hub-Spindle Sub-Assembly​
Main Assembly​
Tool List​
Re-Aligning Torque Hub Input Coupling​
3.4 Drive Motor (Sauer)​
Description​
Shaft Seal Replacement​
Loop Flushing Valve​
Troubleshooting​
Disassembly​
Inspection​
Assembly​
Initial Start-Up Procedures​
3.5 Front Axle​
Front Axle Assembly (Fixed)​
Front Axle Assembly (Oscillating)​
Steering Assembly​
Axle Lockout Cylinder​
3.6 Leveling Jacks​
Cylinder Removal​
Assembly Removal​
3.7 Platform​
Platform Control Station​
Joystick Controller​
3.8 Scissor Arms​
Lift Cylinder Removal​
Scissor Arms Removal​
Scissor Arm Assembly Removal​
3.9 Side Compartment Covers​
Engine Compartment (Left Side)​
Hydraulic/Fuel Compartment (Right Side)​
Cover Removal​
Cover Installation​
3.10 Ground Control Station​
Control Station Removal​
Ground Control Station Components​
Options Control Module​
3.11 Battery​
3.12 Fuel Tank​
3.13 Hydraulic Tank​
3.14 Kubota Engine​
Engine Tray - Swing Out​
Generator (If Equipped)​
Exhaust System​
Air Cleaner System​
Radiator​
Engine Electrical Component Locations​
Hydraulic Pumps​
Pump Coupling Assembly​
Engine Removal​
3.15 Dual Fuel/LPG System​
Changing From Gasoline to LP Gas​
Changing From LP Gas to Gasoline​
Using Liquid Petroleum (LP) Gas​
Propane Fuel System Pressure Relief​
Propane Fuel System Leak Test​
Section 4. Hydraulics
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
Solenoid Control Valves (Bang-Bang)​
Relief Valves​
Crossover Relief Valves​
4.3 Cylinder Checking Procedure​
Cylinders Without Counterbalance Valves​
Cylinders With Single Counterbalance Valve​
4.4 Oscillating Axle - Lockout Cylinder Test (if equipped)​
Left Side Wheel Test​
Right Side Wheel Test​
4.5 Drive Pump Start-up Procedure​
4.6 Hydraulic Component Start-Up Procedures & Recommendations​
4.7 Hydraulic Valves​
Main Hydraulic Valve​
Flow Divider Valve​
Leveling Jack Directional Valve​
Leveling Jack Valves​
Pressure Relief Valve - Setting Procedures​
4.8 Gear Pumps​
Gear Pump Priming​
All Diesel Engines/Dual Fuel Engines Prior to SN E200000368​
Dual Fuel Engines (SN E200000369 through E200000675)​
4.9 Axial HI 45 Pump​
General Repair Instructions​
Start-Up Procedure​
Removing the pump​
Electric Control Module​
Control Solenoids​
Shaft Seal, Roller Bearing & Shaft Replacement​
Charge Pump​
Charge Check/HPRV​
Charge Pressure Relief Valve​
Pressure Limiter Valve Replacement​
4.10 Charge Pump Filter​
4.11 Cylinder Repair​
Disassembly​
Cleaning and Inspection​
Assembly​
4.12 Cylinder Assemblies​
Oscillating Axle Cylinder Bleeding Procedure​
Section 5. JLG Control System
5.1 Hand Held Analyzer​
To Connect the Hand Held Analyzer​
Using the Analyzer​
Changing the Access Level of the Hand Held Analyzer​
Adjusting Parameters Using the Hand Held Analyzer​
Machine Setup​
Analyzer Menu Flow Charts​
5.2 Diagnostic Troubleshooting codes (DTC’s) and Flash Codes Description​
5.3 Tilt Sensor Installation​
5.4 Sensor Location and Calibration​
Rotary Angle (Elevation) Sensor Calibration​
Arm Stack Angle Sensor Calibration​
Oscillating Axle Tilt Sensor​
Tilt Sensor Calibration​
Leveling Jack Pressure Set Calibration​
Drive Minimum Calibration​
Reset Personality Calibration​
5.5 Machine Setup (Configuration) and Calibration Procedure​
5.6 Machine Configuration And Programming Settings​
Machine Tilt Configuration​
Machine Model Personality Adjustment​
Section 6. General Electrical Information & Schematics
6.1 General​
6.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Voltage Measurement​
Resistance Measurement​
Continuity Measurement​
Current Measurement​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
6.3 Applying Silicone Dielectric Compound To Amp Connectors​
Assembly​
Disassembly​
Wedge Lock​
Service - Voltage Reading​
6.4 Working With Deutsch Connectors​
DT/DTP Series Assembly​
DT/DTP Series Disassembly​
HD30/HDP20 Series Assembly​
HD30/HDP20 Series Disassembly​
6.5 Switches​
Basic check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
6.6 Electrical Schematic​
Ground Controls​
Chassis, Arm Stack, and Options​
Platform Controls​
Platform Control Box​
Kubota Diesel Engine​
Kubota Dual Fuel Engine Chassis​
Kubota Dual Fuel Engine​
Generator and Light Options​
6.7 Hydraulic Schematics​
Oscillating Axle Valve​
