Hyundai
86
176,834
JLG Scissor Lift 3394RT 4394RT Service & Maintenance Manual 3121642 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3394RT, 4394RT Scissor Lift
Serial Number 0200239053 to Present
Part Number: 3121642
Publication Date: 2025
Number of Pages: 240 Pages
Section 1. Specifications
1.1 Specifications​
1.2 Capacities​
1.3 Engines​
1.4 Tires​
1.5 Machine Dimensions​
1.6 Pressure Settings​
1.7 Serial Number Locations​
1.8 Sensors​
1.9 Cylinder Specifications​
1.10 Major Component Weights​
1.11 Critical Stability Weights​
1.12 Lubrication Specifications​
1.13 Maintenance Specifications​
Fuel Tank​
Drive Hub​
Hydraulic Oil​
Oil Change w/Filter - Deutz - D 2011 L03​
Engine Oil Change w/Filter - Deutz D2.9 L4 - T4F​
Oil Change w/Filter - GM - Dual Fuel​
Engine Fuel Filter - Deutz​
Engine Fuel Filter - Deutz D 2.9 L4 - T4F​
Engine Fuel Filter (Gasoline) - GM​
Air Filter​
Electronic Pressure Regulator (LP only)​
Fuel Filter (Propane) - GM​
Draining Oil Build Up From The Propane Regulator​
Propane Fuel Filter Replacement​
Propane Fuel System Pressure Relief​
1.14 Torque Charts​
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance​
General​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
2.2 Service and Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication​
Battery​
Lubrication and Servicing​
2.3 Lubrication and Information​
Hydraulic System​
Hydraulic Oil​
Changing Hydraulic Oil​
2.4 Cylinder Drift Test​
Platform Drift​
Cylinder Drift​
2.5 Pins and Composite Bearing Repair Guidelines​
2.6 Preventive Maintenance and Inspection Schedule​
Section 3. Chassis, Platform & Scissor Arms
3.1 Operating Characteristics​
Leveling Jacks​
Power Deck​
Generator​
Lift​
Drive​
3.2 Tires, Wheels & Drive Assembly​
Tire Inflation​
Tire Damage​
Tire Replacement​
Wheel Replacement​
Wheel Installation​
Drive Assembly​
3.3 Drive Hub (Fairfield)​
Roll and Leak Testing​
Tightening and Torquing Bolts​
Oil Information​
Main Disassembly for Drive Hub​
Hub-Spindle Disassembly​
Cover Disassembly​
Carrier Disassembly​
Assembly of the Carrier​
Cover Sub-Assembly​
Hub-Spindle Sub-Assembly​
Main Assembly​
Tool List​
Re-Aligning Torque Hub Input Coupling​
3.4 Drive Motor (Sauer)​
Description​
Shaft Seal Replacement​
Loop Flushing Valve​
Troubleshooting​
Disassembly​
Inspection​
Assembly​
Initial Start-up Procedures​
3.5 Front Axle​
Steering Assembly​
Axle Assembly​
Front Axle - Tow Bar Installation (If Equipped)​
Axle Lockout Cylinder​
3.6 Leveling Jacks (If Equipped)​
Cylinder Removal​
Assembly Removal​
3.7 Platform​
Deck Extension Cylinders (If Equipped)​
Platform Control Station​
Joystick Controller​
3.8 Scissor Arms​
Lift Cylinder Removal​
Scissor Arms Removal​
Scissor Arm Assembly Removal​
3.9 Side Compartment Covers​
3.10 Ground Control Station​
Control Station Removal​
3.11 Fuel Tank​
3.12 Hydraulic Tank​
3.13 Battery​
3.14 Dual Fuel/LPG System​
Changing From Gasoline to LP Gas​
Changing From LP Gas to Gasoline​
Using Liquid Petroleum (LP) Gas​
3.15 Deutz Engine​
Engine Tray​
Deutz EMR 4​
Generator (if equipped)​
Exhaust System​
Air Cleaner System​
Relays​
Pumps​
Pump Coupling​
Engine Removal​
Radiator​
3.16 GM Engine​
Maintenance of the Drive Belt​
Engine Electrical System Maintenance​
Checking/Filling Engine Oil Level​
Changing The Engine Oil​
Engine Tray​
Generator​
Exhaust System​
Air Cleaner System​
Radiator​
Fuel Components​
Pumps​
Pump Coupling​
Engine Removal​
3.17 GM Engine Dual Fuel System​
Fuel Filter​
Electric Lock Off​
Electronic Pressure Regulator Assembly​
Low Pressure Regulator (LPR)​
Air Fuel Mixer​
Electronic Throttle Control (ETC)​
Engine Control Module (ECM)​
Heated Exhaust Gas Oxygen Sensor (HEGO)​
Gasoline Multi Point Fuel Injection System (MPFI)​
Gasoline Fuel Pump​
Gasoline Pressure And Temperature Sensor Manifold​
Fuel Filter​
Fuel Injector Rail​
Fuel Injector​
3.18 GM Engine Fuel System Repair​
Propane Fuel System Leak Test​
Electronic Pressure Regulator (EPR) Assembly Replacement​
Temperature Manifold Absolute Pressure (TMAP) Sensor​
Electronic Throttle Control Replacement​
Mixer Replacement​
Coolant Hose Replacement​
Vapor Hose Replacement​
Engine Control Module Replacement​
Heated Exhaust Gas Oxygen Sensor Replacement​
3.19 GM Engine LPG Fuel System Diagnosis​
Fuel System Description​
Diagnostic Aids​
Section 4. Hydraulics
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
Solenoid Control Valves (Bang-Bang)​
Relief Valves​
Crossover Relief Valves​
4.3 Cylinder Checking Procedure​
Cylinders Without Counterbalance Valves​
Cylinders With Single Counterbalance Valve​
4.4 Oscillating AXLE - Lockout Cylinder Test (if equipped)​
Left Side Wheel Test​
Right Side Wheel Test​
4.5 Cylinder Repair​
Disassembly​
Cleaning and Inspection​
Assembly​
4.6 Drive Pump Start-up Procedure​
4.7 Hydraulic Component Start-Up Procedures & Recommendations​
4.8 Hydraulic Gear Pump​
Pump Disassembly​
Parts Inspection​
Pump Reassembly​
4.9 Valves​
Main Valve​
Flow Divider Valve​
Leveling Jacks Directional Valve​
Powerdeck Valves​
Leveling Jack Valves​
Pressure Setting Procedures​
4.10 Gear Pump​
Gear Pump Priming​
4.11 Axial HI 45 Pump​
General Repair Instructions​
Start-Up Procedure​
Removing the pump​
Electric Control Module​
Control Solenoids​
Shaft Seal, Roller Bearing & Shaft Replacement​
Charge Pump​
Charge Check/HPRV​
Charge Pressure Relief Valve​
Pressure Limiter Valve Replacement​
4.12 Charge Pump Filter​
4.13 Auxiliary Pump Motor​
4.14 Cylinder Assemblies​
Oscillating Axle Cylinder Bleeding Procedure​
Section 5. JLG Control System
5.1 Hand Held Analyzer​
To Connect the Hand Held Analyzer:​
Using the Analyzer:​
Changing the Access Level of the Hand Held Analyzer:​
Adjusting Parameters Using the Hand Held Analyzer​
Machine Setup​
5.2 Calibrations​
Elevation Sensor Calibration​
Joystick Calibration​
Tilt Sensor Calibration​
Tilt Sensor​
5.3 Flash Codes and Descriptions​
Section 6. General Electrical Information & Schematics
6.1 General​
6.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
6.3 Applying Silicone Dielectric Compound To Amp Connectors​
Assembly​
Disassembly​
Wedge Lock​
Service - Voltage Reading​
6.4 Working With Deutsch Connectors​
DT/DTP Series Assembly​
DT/DTP Series Disassembly​
HD30/HDP20 Series Assembly​
HD30/HDP20 Series Disassembly​
6.5 Switches​
Basic check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
6.6 Schematics​
