Hyundai
86
176,834
JLG Scissor Lift 3394RT 4394RT Service & Maintenance Manual 3121133 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3394RT, 4394RT Scissor Lift
Part Number: 3121133
Publication Date: 2025
Number of Pages: 228 Pages
Section A. Introduction - Maintenance Safety Precautions​
A.A General​
A.B Hydraulic System Safety​
A.C Maintenance​
Section 1. Specifications​
1.1 Specifications​
1.2 Capacities​
1.3 Engines​
1.4 Tires​
1.5 Machine Dimensions​
1.6 Pressure Settings​
1.7 Serial Number Locations​
1.8 Sensors​
1.9 Cylinder Specifications​
1.10 Major Component Weights​
1.11 Critical Stability Weights​
1.12 Lubrication Specifications​
1.13 Operator Maintenance​
1.14 Torque Charts​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
2.2 Service and Guidelines​
2.3 Lubrication and Information​
2.4 Cylinder Drift Test​
2.5 Pins and Composite Bearing Repair Guidelines​
2.6 Preventive Maintenance and Inspection Schedule​
Section 3. Chassis & Scissor Arms​
3.1 Operating Characteristics​
3.2 Calibrations​
3.3 Level Sensor and Analyzer Connections​
3.4 Integrated Torque/drive hub​
3.5 Dual Fuel/LPG System​
3.6 Ford EFI Engine​
3.7 Generator - Ford Engine​
3.8 Deutz EMR 2 (S/N 0200138634 to Present)​
3.9 Generator - Duetz Engine​
3.10 GM Engine General Maintenance​
3.11 Generator - GM Engine​
3.12 GM Engine Dual Fuel System​
3.13 GM Engine Fuel System Repair​
3.14 GM Engine LPG Fuel System Diagnosis​
3.15 Joystick Controller​
Section 4. Hydraulics​
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
4.3 Component Functional Description​
4.4 Cylinder Checking Procedure​
4.5 Cylinder Repair​
4.6 Drive Pump Start-up Procedure​
4.7 Hydraulic Component Start-Up Procedures and Recommendations​
4.8 Hydraulic Gear Pump​
4.9 Main Valve​
4.10 Drive Header Valve (2WD)​
4.11 Drive Header Valve (4WD)​
4.12 Header Valves (4WD)​
4.13 dIRECTIONAL vALVE​
4.14 pOWER dECK sANDWICH vALVE​
4.15 Power Deck Manifold Valve​
4.16 Hydraulic Pump​
4.17 Cylinder Assemblies​
Section 5. JLG Control System​
5.1 Hand Held Analyzer​
5.2 Flash Codes and Descriptions​
Section 6. General Electrical Information & Schematics​
6.1 General​
6.2 Multimeter Basics​
6.3 Applying Silicone Dielectric Compound To Amp Connectors​
6.4 Working With Deutsch Connectors​
6.5 Switches​
6.6 Schematics​
