JLG Scissor Lift 3369LE 4069LE M3369 M4069 Service & Maintenance Manual 3121824 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3369LE, 4069LE, M3369, M4069 Scissor Lift
Prior to SN 0200230092
Part Number: 3121824
Publication Date: 2025
Number of Pages: 156 Pages
Section A. Introduction - Maintenance Safety Precautions
Brand: JLG
A General
B Hydraulic System Safety
C Maintenance
Section 1. Specifications1.1 Specifications
1.2 Capacities
1.3 Pressure Settings
1.4 Component Data
Battery Charger
Batteries (8)
Drive System
Steer System
Hydraulic Pump/Electric Motor Assembly
1.5 Torque Specifications
1.6 Lubrication
Lubrication Specifications
1.7 Cylinder Specifications
1.8 Major Component Weights
1.9 Critical Stability Weights
1.10 Lubrication
1.11 Serial Number Locations
1.12 Torque Charts
Section 2. General2.1 Machine Preparation, Inspection, and Maintenance
General
Pre-Start Inspection
Pre-Delivery Inspection and Frequent Inspection
Annual Machine Inspection
Preventative Maintenance
2.2 Service and Guidelines
General
Safety and Workmanship
Cleanliness
Components Removal and Installation
Component Disassembly and Reassembly
Pressure-Fit Parts
Bearings
Gaskets
Bolt Usage and Torque Application
Hydraulic Lines and Electrical Wiring
Lubrication
Battery
Lubrication and Servicing
2.3 Lubrication and Information
Hydraulic Oil
Changing Hydraulic Oil
2.4 Cylinder Drift Test
Platform Drift
Cylinder Drift
2.5 Pins and Composite Bearing Repair Guidelines
2.6 Preventive Maintenance and Inspection Schedule
Section 3. Chassis & Scissor Arms3.1 Calibrations
Elevation Sensor Calibration (Prior to Software V13.6)
Elevation Sensor Calibration (Software V13.6 and Higher)
Speed Sensor
Tilt Sensor Calibration:
Joystick Calibration (SW V13.5 & Higher and P1.0 & Higher)
3.2 Tilt Sensor
Tilt Sensor, JLG P/N 4000006:
Tilt Sensor, JLG P/N 4000021:
3.3 Battery Maintenance and Charging
Battery Maintenance, Quarterly
Optional On Board Generator
Battery Charging (On Board Charger) (MAC)
Charging Sequence of Remote LED Card
Battery Charger (Delta-Q)
Battery Charger Maintenance
Battery Charger Troubleshooting
Battery Temperature Sensor
Removing the Battery Box
3.4 Generator
Timing Sequences
To Connect the JLG Control System Analyzer to the Generator
Alarms and Fault Flash Codes
Output Current and Voltage Settings
Priming the Fuel Line
3.5 Supplementary Fuse For APU
Tools And Material
Procedure
3.6 Joystick Controller
Power Controller
3.7 Torque Hub
Disengaging for Towing
Engaging after Towing is Complete
3.8 Drive Hub
Disassembly
Disassembly of Cover Unit (8)
Disassembly of First Stage Planetary Assembly
Disassembly of the Second Stage Planet Gears (1)
3.9 Drive Brake - MICO
Disassembly
Assembly
Bleeding
3.10 Torque Hub
Roll Test
Leak Test (Main Unit)
Tightening and Torquing Bolts
Main Disassembly
Output Carrier Disassembly
Input Carrier Disassembly
Hub-Spindle Disassembly
Cover Disassembly
Input Carrier Sub-Assembly
Output Carrier Sub-Assembly
Hub-Spindle Sub-Assembly
Cover Sub-Assembly
Main Assembly
Section 4. Hydraulics4.1 Servicing and Maintenance Guidelines
General
Cleanliness
Component Removal and Installation
Pressure Fit Parts
Bearings
Gaskets
Lubrication
Batteries
4.2 Lubrication Information
Hydraulic Oil
4.3 Cylinders - Theory of Operation
4.4 Valves - Theory of Operation
Control Valves
4.5 Component Functional Description
Manual Descent
4.6 Wear Pads
4.7 Motor Controller - Modes of Operation
Traction Motor (Drive)
Pump Motor (LIft)
4.8 Features
Traction Mode
4.9 Cylinder Checking Procedures
Cylinder Without Counterbalance Valves (Steer)
Cylinders With Single Counterbalance Valve (Lift Cylinder)
Cylinders with Duel Counterbalance Valves (Oscillating Cylinders)
4.10 Cylinder Removal and Installation
Lift Cylinder Removal
Lift Cylinder Installation
4.11 Cylinder Repair
Disassembly
Cleaning and Inspection
Assembly
4.12 Steer Cylinder Removal
4.13 Oscillation Cylinder Bleeding
Bleeding Procedure
Checking Oscillation Cylinders
Oscillating Axle Lockout Test (If Equipped)
4.14 Cylinder Assemblies
4.15 Pressure Setting Procedures
Main Relief at Pump
Lift Relief
Steer Relief
4.16 Drive Torque Hub
Disassembly
Assembly
4.17 Drive Assist Valve
Section 5. JLG Control System5.1 Hand Held Analyzer
To Connect the Hand Held Analyzer:
Using the Analyzer:
Changing the Access Level of the Hand Held Analyzer:
Adjusting Parameters Using the Hand Held Analyzer
Machine Setup
5.2 PC Boards
5.3 Flash Codes/DTC’s and Descriptions
5.4 Ground Control Circuit Board
Software Version 13.6
Software Version P1.0
Section 6. General Electrical Information & Schematics6.1 General
6.2 Multimeter Basics
Grounding
Backprobing
Min/Max
Polarity
Scale
Continuity Measurement Over Long Distances
Requirements:
Procedure
6.3 Applying Silicone Dielectric Compound To Amp Connectors
Assembly
Disassembly
Wedge Lock
Service - Voltage Reading
6.4 Working With Deutsch Connectors
DT/DTP Series Assembly
DT/DTP Series Disassembly
HD30/HDP20 Series Assembly
HD30/HDP20 Series Disassembly
- SuperPac Parts Manual
- StratoLift Parts Manual
