Hyundai
86
176,834
JLG Scissor Lift 3369LE 4069LE M3369 M4069 Parts Catalog 3121825
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3369LE 4069LE M3369 M4069 Scissor Lift
Part Number: 3121825
Publication Date: 2025
Number of Pages: 212 Pages
SECTION 1 - FRAME
FIGURE 1-1. FRAME AND STEERING INSTALLATION - 2WD​
FIGURE 1-2. FRAME AND STEERING INSTALLATION - 4WD​
FIGURE 1-3. DRIVE VALVE ASSEMBLY (4WD ONLY)​
FIGURE 1-4. REAR AXLE INSTALLATION​
FIGURE 1-5. TIRE AND WHEEL DRIVE INSTALLATION​
FIGURE 1-6. DRIVE HUB ASSEMBLY (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (Prior to SN 0200174517, SN 1200000100 through 1200001000)​
FIGURE 1-7. DRIVE HUB ASSEMBLY (USA BUILT MACHINES) (SN 0200174517 through 0200230091)​
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (REAR)​
FIGURE 1-9. FRONT DRIVE MOTOR ASSEMBLY (4WD ONLY)​
FIGURE 1-10. YANMAR MOTOR/GENERATOR AND BATTERY CHARGER INSTALLATION (M3369,M4069)​
FIGURE 1-11. KUBOTA MOTOR/GENERATOR AND BATTERY CHARGER INSTALLATION (M3369,M4069)​
FIGURE 1-12. BATTERY CHARGER AND INVERTER INSTALLATIONS (3369LE,4069LE)​
FIGURE 1-13. BATTERY CHARGER ASSEMBLY (MAC CHARGER)​
FIGURE 1-14. BATTERY CHARGER ASSEMBLY (DELTA-Q CHARGER)​
FIGURE 1-15. INVERTER INSTALLATIONS (3369LE,4069LE)​
FIGURE 1-16. ELECTRICAL COMPONENTS INSTALLATIONS (FRAME MOUNTED)​
FIGURE 1-17. LADDER AND BEACON INSTALLATIONS​
FIGURE 1-18. LEVELING JACKS INSTALLATION (OPTIONAL)​
FIGURE 1-19. COVERS INSTALLATION (FRAME MOUNTED)​
SECTION 2 - GROUND CONTROLS
FIGURE 2-1. RIGHT SIDE COMPONENTS INSTALLATION​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-3. GROUND CONTROL BOX ASSEMBLY​
FIGURE 2-4. LEFT SIDE COMPONENTS INSTALLATION​
FIGURE 2-5. PUMP ASSEMBLY​
FIGURE 2-6. BATTERY BOX INSTALLATIONS​
SECTION 3 - SCISSORS ARMS
FIGURE 3-1. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (3369LE,M3369) (Prior to SN 0200152398)​
FIGURE 3-2. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES) (3369LE,M3369) (SN 0200152398 through 0200230091)​
FIGURE 3-3. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (4069LE,M4069) (Prior to SN 0200152398)​
FIGURE 3-4. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES) (4069LE,M4069) (SN 0200152398 through 0200230091)​
FIGURE 3-5. SCISSORS GUARDS INSTALLATION​
SECTION 4 - PLATFORM
FIGURE 4-1. PLATFORM AND ACCESSORIES INSTALLATION​
FIGURE 4-2. FOLDDOWN HANDRAILS AND EXTENSION INSTALLATION (MANUALLY OPERATED PLATFORM)​
FIGURE 4-3. PLATFORM CONSOLE BOX ASSEMBLY​
FIGURE 4-4. DRIVE/STEER CONTROLLER ASSEMBLY (Prior to SN 0200142020, SN 1200000100 through 1200001000)​
FIGURE 4-5. DRIVE/STEER CONTROLLER ASSEMBLY (SN 0200142020 through 0200230091)​
SECTION 5 - CYLINDER
FIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 5-2. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (Prior to SN 0200104829)​
FIGURE 5-3. LEVELING JACK CYLINDER ASSEMBLY (SN 0200104829 through 0200112734, SN 1200000100 through 1200001000, Including )​
FIGURE 5-4. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (ORIGINAL EQUIPMENT) (SN 0200112735 through 0200214444)​
FIGURE 5-5. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (SERVICE REPLACEMENT) (SN 0200214444 through 0200230091)​
FIGURE 5-6. LIFT CYLINDER COMPONENTS ASSEMBLY (3369LE,M3369)​
FIGURE 5-7. LIFT CYLINDER COMPONENTS ASSEMBLY (4069LE,M4069)​
FIGURE 5-8. STEER CYLINDER ASSEMBLY​
SECTION 6 - HYDRAULIC
FIGURE 6-1. HYDRAULIC DIAGRAM - FIXED AXLE​
FIGURE 6-2. HYDRAULIC DIAGRAM - OSCILLATING AXLE​
FIGURE 6-3. HYDRAULIC DIAGRAM - 4WD (OPTIONAL)​
FIGURE 6-4. HYDRAULIC DIAGRAM - LEVELING JACKS (OPTIONAL)​
FIGURE 6-5. HYDRAULIC DIAGRAM LIST​
SECTION 7 - ELECTRICAL
FIGURE 7-1. ELECTRICAL SCHEMATIC​
FIGURE 7-2. STANDARD ELECTRICAL COMPONENTS INSTALLATION (WITH MAC CHARGER)​
FIGURE 7-3. STANDARD ELECTRICAL COMPONENTS INSTALLATION (WITH DELTA-Q CHARGER)​
FIGURE 7-4. OPTIONAL ELECTRICAL COMPONENTS INSTALLATION​
SECTION 8 - DECALS
FIGURE 8-1. DECAL INSTALLATION (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (Prior to SN 0200150261)​
FIGURE 8-2. DECAL INSTALLATION (USA BUILT MACHINES) (SN 0200150261 through 0200230091)​
SECTION 9 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 9-1. STANDARD PARTS​
FIGURE 9-2. VARIABLE PARTS​
SECTION 10 - SPECIAL OPTIONS
FIGURE 10-1. SPECIAL OPTIONS​
PART NUMBER INDEX
