JLG Scissor Lift 3369LE 4069LE M3369 M4069 Parts Catalog 3121640
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3369LE 4069LE M3369 M4069 Scissor Lift
Part Number: 3121640
Publication Date: 2025
Number of Pages: 418 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. REAR AXLE INSTALLATION - FIXED
FIGURE 1-2. REAR AXLE INSTALLATION - OSCILLATING (ALL SPECS EXCEPT CE SPEC)
FIGURE 1-3. OSCILLATING AXLE VALVE ASSEMBLY (ALL SPECS EXCEPT CE SPEC)
FIGURE 1-4. REAR AXLE INSTALLATION - OSCILLATING (CE SPEC) (SN 0200246353 through 0200266243, SN M200000100 through M200039307)
FIGURE 1-5. OSCILLATING AXLE VALVE ASSEMBLY (CE SPEC) (SN 0200246353 through 0200266243, SN M200000100 through M200039307)
FIGURE 1-6. STEERING INSTALLATION - 2WD
FIGURE 1-7. STEERING INSTALLATION - 4WD
FIGURE 1-8. STEERING AND FRONT DRIVE INSTALLATION - 4WD FRONT
FIGURE 1-9. WHEEL DRIVE AND CONTROLLER INSTALLATION - 2WD/4WD REAR
FIGURE 1-10. HUB ASSEMBLY - 2WD FRONT
FIGURE 1-11. DRIVE HUB ASSEMBLY - 2WD/4WD REAR
FIGURE 1-12. DRIVE BRAKE ASSEMBLY - 2WD/4WD REAR
FIGURE 1-13. DRIVE MOTOR ASSEMBLY - OPERATORS POSITION RH SIDE - 4WD FRONT (SN 0200230092 through 0200266243, SN M200000100 through M200023101)
FIGURE 1-14. DRIVE MOTOR ASSEMBLY - OPERATORS POSITION RH SIDE - 4WD FRONT (3369LE,4069LE,M3369,M4069) (SN M200023102 through M200039307)
FIGURE 1-15. DRIVE MOTOR ASSEMBLY - OPERATORS POSITION LH SIDE - 4WD FRONT (SN 0200230092 through 0200266243, SN M200000100 through M200023101)
FIGURE 1-16. DRIVE MOTOR ASSEMBLY - OPERATORS POSITION LH SIDE - 4WD FRONT (3369LE,4069LE,M3369,M4069) (SN M200023102 through M200039307)
FIGURE 1-17. DRIVE MOTOR ASSEMBLY - 2WD/4WD REAR
FIGURE 1-18. DRIVE VALVE ASSEMBLY - 4WD ONLY
FIGURE 1-19. FLOW DIVIDER VALVE ASSEMBLY - 4WD ONLY
FIGURE 1-20. TIRE AND WHEEL INSTALLATION - IN240/55 X 17.5 FOAM-FILLED
FIGURE 1-21. TIRE AND WHEEL INSTALLATION - IN240/55 X 17.5 NON-MARKING FOAM FILLED
FIGURE 1-22. TIRE AND WHEEL INSTALLATION - 27.2/10.5LL X 15 TURF FOAM-FILLED
FIGURE 1-23. LEVELING JACKS INSTALLATION - OPTIONAL
FIGURE 1-24. LEVELING JACK CONTROL VALVE ASSEMBLY
FIGURE 1-25. BATTERY CHARGER INSTALLATION - 110V/60HZ (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (3369LE,4069LE)
FIGURE 1-26. BATTERY CHARGER INSTALLATION - 110V/60HZ (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (M3369,M4069)
FIGURE 1-27. BATTERY CHARGER INSTALLATION - 120-240V/50-60HZ (ANSI, ANSI EXPORT, CSA AND CE SPECS) (3369LE,4069LE)
FIGURE 1-28. BATTERY CHARGER INSTALLATION - 120-240V/50-60HZ (ANSI, ANSI EXPORT, CSA AND CE SPECS) (M3369,M4069)
FIGURE 1-29. BATTERY CHARGER INSTALLATION - 250V/50HZ (ANSI EXPORT AND AUSTRALIAN SPECS) (3369LE,4069LE)
FIGURE 1-30. BATTERY CHARGER INSTALLATION - 250V/50HZ (ANSI EXPORT AND AUSTRALIAN SPECS) (M3369,M4069)
FIGURE 1-31. BATTERY CHARGER ASSEMBLY
FIGURE 1-32. BATTERY CHARGER DOOR ASSEMBLY (3369LE,4069LE)
FIGURE 1-33. INVERTER INSTALLATION - OPTIONAL
FIGURE 1-34. BEACON INSTALLATION
FIGURE 1-35. LADDER INSTALLATION WITHOUT LEVELING JACKS (ALL SPEC EXCEPT CE SPEC) (3369LE,M3369)
FIGURE 1-36. LADDER INSTALLATION WITHOUT LEVELING JACKS (CE SPEC) (3369LE,M3369)
FIGURE 1-37. LADDER INSTALLATION WITHOUT LEVELING JACKS (ALL SPECS EXCEPT CE SPEC) (4069LE,M4069)
FIGURE 1-38. LADDER INSTALLATION WITHOUT LEVELING JACKS (CE SPECS) (4069LE,M4069)
FIGURE 1-39. LADDER INSTALLATION WITH LEVELING JACKS
FIGURE 1-40. FRAME COVER INSTALLATION (STANDARD)
FIGURE 1-41. FRAME COVER INSTALLATION (HOSTILE ENVIRONMENT) (4069LE,M4069)
FIGURE 1-42. FRAME COVER INSTALLATION (HOSTILE ENVIRONMENT) (3369LE,M3369)
SECTION 2 - GROUND COMPONENTSFIGURE 2-1. MAIN CONTROL VALVE INSTALLATION
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-3. HYDRAULIC COMPARTMENT INSTALLATION
FIGURE 2-4. MOTOR ASSEMBLY
FIGURE 2-5. GROUND CONTROL BOX AND HORN INSTALLATIONS - 3369LE/4069LE WITHOUT LEVELING JACKS (ALL SPECS EXCEPT CE SPEC) (3369LE,4069LE)
FIGURE 2-6. GROUND CONTROL BOX AND HORN INSTALLATIONS - 3369LE/4069LE WITHOUT LEVELING JACKS (CE SPEC) (3369LE,4069LE)
FIGURE 2-7. GROUND CONTROL BOX AND HORN INSTALLATIONS - 3369LE/4069LE WITH LEVELING JACKS (ALL SPECS EXCEPT CE SPEC) (3369LE,4069LE)
FIGURE 2-8. GROUND CONTROL BOX AND HORN INSTALLATIONS - 3369LE/4069LE WITH LEVELING JACKS (CE SPEC) (3369LE,4069LE)
FIGURE 2-9. GROUND CONTROL BOX AND HORN INSTALLATIONS - M3369/M4069 (2WD - ALL SPECS EXCEPT CE SPEC) (M3369,M4069)
FIGURE 2-10. GROUND CONTROL BOX AND HORN INSTALLATIONS - M3369/M4069 (2WD - CE SPEC) (M3369,M4069)
FIGURE 2-11. GROUND CONTROL BOX AND HORN INSTALLATIONS - M3369/M4069 (4WD - ALL SPECS EXCEPT CE SPEC) (M3369,M4069)
FIGURE 2-12. GROUND CONTROL BOX AND HORN INSTALLATIONS - M3369/M4069 (4WD - CE SPEC) (M3369,M4069)
FIGURE 2-13. GROUND CONTROL BOX AND HORN INSTALLATIONS - M4069 (DRIVE AT FULL HEIGHT) (M3369,M4069)
FIGURE 2-14. GROUND CONTROL BOX ASSEMBLY - 3369LE/4069LE (ALL SPECS EXCEPT CE SPEC) (3369LE,4069LE)
FIGURE 2-15. GROUND CONTROL BOX ASSEMBLY - 3369LE/4069LE (CE SPEC) (3369LE,4069LE)
FIGURE 2-16. GROUND CONTROL BOX ASSEMBLY - M3369/M4069 (ALL SPECS EXCEPT CE SPEC) (M3369,M4069)
FIGURE 2-17. GROUND CONTROL BOX ASSEMBLY - M3369/M4069 (CE SPECS) (M3369,M4069)
FIGURE 2-18. GROUND CONTROL BOX ASSEMBLY - M4069 DRIVE AT FULL HEIGHT (M4069)
FIGURE 2-19. GROUND CONTROL BOX COMPONENTS (SN 0200243015 through 0200266243, SN M200000100 through M200039307)
FIGURE 2-20. BATTERY BOX INSTALLATION - 370A-H BATTERIES (SN 0200230092 through 0200258591)
FIGURE 2-21. BATTERY BOX INSTALLATION - 370A-H BATTERIES (SN 0200258591 through 0200266243)
FIGURE 2-22. BATTERY BOX INSTALLATION - 390A-H AGM BATTERIES (SN 0200230092 through 0200258591)
FIGURE 2-23. BATTERY BOX INSTALLATION - 390A-H AGM BATTERIES (SN 0200258591 through 0200266243, SN M200009860 through M200039307)
FIGURE 2-24. ALARM INSTALLATION
FIGURE 2-25. ALARM INSTALLATION - MOTION
FIGURE 2-26. COVERS INSTALLATION
FIGURE 2-27. TANK INSTALLATION - M3369/M4069 (MACHINES WITH STANDARD BATTERY) (M3369,M4069)
FIGURE 2-28. TANK INSTALLATION - M3369/M4069 (MACHINES WITH AGM BATTERY) (M3369,M4069)
SECTION 3 - ENGINEFIGURE 3-1. KUBOTA ENGINE/GENERATOR INSTALLATION (WITH STANDARD BATTERY) (M3369,M4069)
FIGURE 3-2. KUBOTA ENGINE/GENERATOR INSTALLATION (WITH AGM BATTERY) (M3369,M4069)
FIGURE 3-3. KUBOTA MOTOR/GENERATOR ASSEMBLY (M3369,M4069) (SN 0200230092 through 0200266243, SN M200000100 through M200028845)
FIGURE 3-4. KUBOTA MOTOR/GENERATOR ASSEMBLY (M3369,M4069) (SN M200028846 through M200032748)
FIGURE 3-5. KUBOTA MOTOR/GENERATOR ASSEMBLY (M3369,M4069) (SN M200032749 through M200039307)
FIGURE 3-6. KUBOTA MOTOR/GENERATOR COMPONENTS (M3369,M4069) (SN 0200230092 through 0200266243, SN M200000100 through M200028845)
FIGURE 3-7. KUBOTA MOTOR/GENERATOR COMPONENTS (M3369,M4069) (SN M200028846 through M200032748)
FIGURE 3-8. KUBOTA MOTOR/GENERATOR COMPONENTS (M3369,M4069) (SN M200032749 through M200039307)
SECTION 4 - SCISSORS ARMSFIGURE 4-1. SCISSORS ARMS INSTALLATION WITHOUT LSS (3369LE,M3369)
FIGURE 4-2. SCISSORS ARMS ASSEMBLY WITHOUT LSS (3369LE,M3369)
FIGURE 4-3. SCISSORS ARMS INSTALLATION WITH LSS (3369LE,M3369)
FIGURE 4-4. SCISSORS ARMS ASSEMBLY WITH LSS (3369LE,M3369)
FIGURE 4-5. SCISSORS ARMS INSTALLATION WITHOUT LSS (4069LE,M4069)
FIGURE 4-6. SCISSORS ARMS ASSEMBLY WITHOUT LSS (4069LE,M4069)
FIGURE 4-7. SCISSORS ARMS INSTALLATION WITH LSS (4069LE,M4069)
FIGURE 4-8. SCISSORS ARMS ASSEMBLY WITH LSS (4069LE,M4069)
FIGURE 4-9. SCISSORS ARM GUARDS INSTALLATION (CE SPECS ONLY)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM INSTALLATION WITHOUT D-RINGS
FIGURE 5-2. PLATFORM INSTALLATION WITH D-RINGS
FIGURE 5-3. PLATFORM INSTALLATION WITHOUT D-RINGS AND WITH LSS
FIGURE 5-4. PLATFORM INSTALLATION WITH D-RINGS AND WITH LSS
FIGURE 5-5. HANDRAILS INSTALLATION WITH CHAIN GATE
FIGURE 5-6. HANDRAILS INSTALLATION WITH SELF-CLOSING GATE
FIGURE 5-7. 3FT PLATFORM EXTENSION W/RAILS
FIGURE 5-8. CONSOLE BOX ASSEMBLY - NO LEVELING (3369LE,4069LE)
FIGURE 5-9. CONSOLE BOX ASSEMBLY - WITH LEVELING JACKS (3369LE,4069LE)
FIGURE 5-10. CONSOLE BOX ASSEMBLY - 2WD NO LEVELING JACKS (M3369,M4069)
FIGURE 5-11. CONSOLE BOX ASSEMBLY - 2WD WITH LEVELING JACKS (M3369,M4069)
FIGURE 5-12. CONSOLE BOX ASSEMBLY - 4WD NO LEVELING JACKS (M3369,M4069)
FIGURE 5-13. CONSOLE BOX ASSEMBLY - 4WD WITH LEVELING JACKS (M3369,M4069)
FIGURE 5-14. DRIVE/STEER CONTROLLER ASSEMBLY
FIGURE 6-2. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-3. LIFT CYLINDER ASSEMBLY (3369LE,M3369)
FIGURE 6-4. LIFT (LOWER) CYLINDER ASSEMBLY (4069LE,M4069)
FIGURE 6-5. LIFT (UPPER) CYLINDER ASSEMBLY (4069LE,M4069)
FIGURE 6-6. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM LIST
FIGURE 7-2. HYDRAULIC DIAGRAM - 4WD
FIGURE 7-3. HYDRAULIC DIAGRAM - LEVELING JACKS (OPTIONAL)
FIGURE 7-4. HYDRAULIC DIAGRAM - LIFT CYLINDER - WITHOUT LSS (3369LE,M3369)
FIGURE 7-5. HYDRAULIC DIAGRAM - LIFT CYLINDER - WITH LSS (3369LE,M3369)
FIGURE 7-6. HYDRAULIC DIAGRAM - LIFT CYLINDER - WITHOUT LSS (4069LE,M4069)
FIGURE 7-7. HYDRAULIC DIAGRAM - LIFT CYLINDER - WITH LSS (4069LE,M4069)
FIGURE 7-8. HYDRAULIC DIAGRAM - STANDARD - WITH FIXED AXLE (3369LE,M3369)
FIGURE 7-9. HYDRAULIC DIAGRAM - STANDARD - WITH OSCILLATING AXLE (ALL SPECS EXCEPT CE SPEC) (3369LE,M3369)
FIGURE 7-10. HYDRAULIC DIAGRAM - STANDARD - WITH FIXED AXLE (4069LE,M4069)
FIGURE 7-11. HYDRAULIC DIAGRAM - STANDARD - WITH OSCILLATING AXLE (ALL SPECS EXCEPT CE SPEC) (4069LE,M4069)
FIGURE 7-12. HYDRAULIC DIAGRAM - STANDARD - WITH OSCILLATING AXLE (CE SPEC) (3369LE,M3369) (SN 0200246353 through 0200266243, SN M200000100 through M200039307)
FIGURE 7-13. HYDRAULIC DIAGRAM - STANDARD - WITH OSCILLATING AXLE (CE SPEC) (4069LE,M4069) (SN 0200246353 through 0200266243, SN M200000100 through M200039307)
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL DIAGRAM LIST
FIGURE 8-2. AC TO PLATFORM INSTALLATION - 110V GFI (3369LE,M3369)
FIGURE 8-3. AC TO PLATFORM INSTALLATION - 110V GFI (4069LE,M4069)
FIGURE 8-4. AC TO PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPEC ONLY)
FIGURE 8-5. AC TO PLATFORM INSTALLATION - 220V IEC BLUE (CE SPEC ONLY)
FIGURE 8-6. AC TO PLATFORM INSTALLATION - 220V AFSINT107 (CE SPEC ONLY)
FIGURE 8-7. AC TO PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE SPEC ONLY)
FIGURE 8-8. AC TO PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE SPEC ONLY)
FIGURE 8-9. ALARM HARNESS
FIGURE 8-10. BEACON LIGHT HARNESS
FIGURE 8-11. BREAKER BOX KIT WITH TWO BREAKERS - CE SPEC ONLY
FIGURE 8-12. BREAKER BOX KIT WITH THREE BREAKERS - CE SPEC ONLY
FIGURE 8-13. CHARGER CORD PLUG INSTALLATION - 110V IEC YELLOW PLUG (CE SPEC)
FIGURE 8-14. CHARGER CORD PLUG INSTALLATION - 220V IEC BLUE PLUG (CE SPEC)
FIGURE 8-15. CHARGER CORD PLUG INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE SPEC)
FIGURE 8-16. CHARGER CORD PLUG INSTALLATION - 220V CEE7 POST GROUND (CE SPEC)
FIGURE 8-17. CHARGER CORD PLUG INSTALLATION - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 8-18. FRONT WHEEL ASSIST (4WD) HARNESS
FIGURE 8-19. GENERATOR HARNESS (M3369,M4069)
FIGURE 8-20. GROUND CONTROL BOX HARNESS (3369LE,4069LE)
FIGURE 8-21. GROUND CONTROL BOX HARNESS (M3369,M4069)
FIGURE 8-22. GROUND CONTROL BOX HARNESS (DRIVE AT FULL HEIGHT) (M4069)
FIGURE 8-23. GROUND CONTROL BOX TO BULKHEAD HARNESS INSTALLATION (3369LE,M3369)
FIGURE 8-24. GROUND CONTROL BOX TO BULKHEAD HARNESS INSTALLATION (4069LE,M4069)
FIGURE 8-25. GROUND CONTROL BOX TO BULKHEAD HARNESS
FIGURE 8-26. LEVELING JACK HARNESS
FIGURE 8-27. LEVELING JACK N.C. HARNESS
FIGURE 8-28. LEVELING JACK N.O. HARNESS
FIGURE 8-29. LEVELING JACK VALVE HARNESS
FIGURE 8-30. LIFT DOWN HARNESS - LOWER
FIGURE 8-31. LIFT DOWN HARNESS - UPPER (3369LE,M3369)
FIGURE 8-32. LIFT DOWN HARNESS - UPPER (4069LE,M4069)
FIGURE 8-33. PLATFORM CABLE HARNESS (3369LE,M3369)
FIGURE 8-34. PLATFORM CABLE HARNESS (4069LE,M4069)
FIGURE 8-35. PLATFORM CONSOLE BOX HARNESS WITHOUT LEVELING JACKS
FIGURE 8-36. PLATFORM CONSOLE BOX HARNESS WITH LEVELING JACKS
FIGURE 8-37. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-38. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)
FIGURE 8-39. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)
FIGURE 8-40. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)
FIGURE 8-41. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 8-42. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE SPEC)
FIGURE 8-43. VALVE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPEC (ENGLISH)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN AND CE SPECS (3369LE,4069LE)
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN AND CE SPECS (M3369,M4069)
FIGURE 9-4. DECAL INSTALLATION - BRAZIL SPEC (DUAL LANGUAGE - PORTUGUESE/SPANISH)
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPEC (DUAL LANGUAGE - ENGLISH/CHINESE)
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (DUAL LANGUAGE - ENGLISH/FRENCH)
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPEC (DUAL LANGUAGE - ENGLISH/JAPANESE)
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPEC (DUAL LANGUAGE - ENGLISH/KOREAN)
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPEC (DUAL LANGUAGE - ENGLISH/SPANISH)
FIGURE 9-10. DECAL INSTALLATION - OPTIONS
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
