JLG Scissor Lift 3369LE 4069LE M3369 M4069 Parts Catalog 3121123
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 3369LE 4069LE M3369 M4069 Scissor Lift
Part Number: 3121123
Publication Date: 2025
Number of Pages: 206 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. FRAME AND STEERING INSTALLATION - 2WD
FIGURE 1-2. FRAME AND STEERING INSTALLATION - 4WD
FIGURE 1-3. DRIVE VALVE ASSEMBLY (4WD ONLY)
FIGURE 1-4. REAR AXLE INSTALLATION
FIGURE 1-5. TIRE AND WHEEL DRIVE INSTALLATION
FIGURE 1-6. DRIVE HUB ASSEMBLY (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (Prior to SN 0200174517)
FIGURE 1-7. DRIVE HUB ASSEMBLY (USA BUILT MACHINES) (SN 0200174517 through 0200230091)
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (REAR)
FIGURE 1-9. FRONT DRIVE MOTOR ASSEMBLY (4WD ONLY)
FIGURE 1-10. YANMAR MOTOR/GENERATOR AND BATTERY CHARGER INSTALLATION (M3369,M4069)
FIGURE 1-11. KUBOTA MOTOR/GENERATOR AND BATTERY CHARGER INSTALLATION (M3369,M4069)
FIGURE 1-12. BATTERY CHARGER INSTALLATION (3369LE,4069LE)
FIGURE 1-13. BATTERY CHARGER ASSEMBLY (MAC CHARGER)
FIGURE 1-14. BATTERY CHARGER ASSEMBLY (DELTA-Q CHARGER)
FIGURE 1-15. INVERTER INSTALLATION (3369LE,4069LE)
FIGURE 1-16. ELECTRICAL COMPONENTS INSTALLATION (FRAME MOUNTED)
FIGURE 1-17. LADDER AND BEACON INSTALLATION
FIGURE 1-18. LEVELING JACKS INSTALLATION (OPTIONAL)
FIGURE 1-19. COVERS INSTALLATION (FRAME MOUNTED)
SECTION 2 - GROUND CONTROLSFIGURE 2-1. RIGHT SIDE COMPONENTS INSTALLATION
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-3. GROUND CONTROL BOX ASSEMBLY
FIGURE 2-4. LEFT SIDE COMPONENTS INSTALLATION
FIGURE 2-5. PUMP ASSEMBLY
FIGURE 2-6. BATTERY BOX INSTALLATIONS
SECTION 3 - SCISSORS ARMSFIGURE 3-1. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (3369LE,M3369) (Prior to SN 0200152398)
FIGURE 3-2. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES) (3369LE,M3369) (SN 0200152398 through 0200230091)
FIGURE 3-3. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (4069LE,M4069) (Prior to SN 0200152398)
FIGURE 3-4. SCISSORS ARMS INSTALLATION (USA BUILT MACHINES) (4069LE,M4069) (SN 0200152398 through 0200230091)
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM AND ACCESSORIES INSTALLATION
FIGURE 4-2. FOLDDOWN HANDRAILS AND EXTENSION INSTALLATION (MANUALLY OPERATED PLATFORM)
FIGURE 4-3. PLATFORM CONSOLE BOX ASSEMBLY
FIGURE 4-4. DRIVE/STEER CONTROLLER ASSEMBLY (Prior to SN 0200142020, SN 1200000100 to Present)
FIGURE 4-5. DRIVE/STEER CONTROLLER ASSEMBLY (SN 0200142020 through 0200230091)
SECTION 5 - CYLINDERFIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 5-2. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (Prior to SN 0200104829)
FIGURE 5-3. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES AND ALL BELGIUM BUILT MACHINES) (SN 0200104829 through 0200112734)
FIGURE 5-4. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (ORIGINAL EQUIPMENT) (SN 0200112735 through 0200214443)
FIGURE 5-5. LEVELING JACK CYLINDER ASSEMBLY (USA BUILT MACHINES) (SERVICE REPLACEMENT) (SN 0200214444 through 0200230091)
FIGURE 5-6. LIFT CYLINDER COMPONENTS ASSEMBLY (3369LE,M3369)
FIGURE 5-7. LIFT CYLINDER COMPONENTS ASSEMBLY (4069LE,M4069)
FIGURE 5-8. STEER CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM - FIXED AXLE
FIGURE 6-2. HYDRAULIC DIAGRAM - OSCILLATING AXLE
FIGURE 6-3. HYDRAULIC DIAGRAM - 4WD (OPTIONAL)
FIGURE 6-4. HYDRAULIC DIAGRAM - LEVELING JACKS (OPTIONAL)
FIGURE 6-5. HYDRAULIC DIAGRAM LIST
SECTION 7 - ELECTRICALFIGURE 7-1. ELECTRICAL SCHEMATIC
FIGURE 7-2. STANDARD ELECTRICAL COMPONENTS INSTALLATION (WITH MAC CHARGER)
FIGURE 7-3. STANDARD ELECTRICAL COMPONENTS INSTALLATION (WITH DELTA-Q CHARGER)
FIGURE 7-4. OPTIONAL ELECTRICAL COMPONENTS INSTALLATION
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION - ANSI SPECS
FIGURE 8-2. DECAL INSTALLATION - ANSI EXPORT SPECS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. STANDARD PARTS
FIGURE 9-2. VARIABLE PARTS
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
