Hyundai
86
176,834
JLG Scissor Lift 330LRT 430LRT Service & Maintenance Manual 3121758 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 330LRT 430LRT Scissor Lift
Serial Number: 0200000100-0200269765
Part Number: 3121758
Publication Date: 2025
Number of Pages: 258 Pages
Section A. Introduction - Maintenance Safety Precautions
A General​
B Hydraulic System Safety​
C Maintenance​
Section 1. Specifications
1.1 Specifications​
Operating Specifications​
Generator Specifications (If Equipped)​
Dimensional Data​
Fluid Capacities​
Drive Information​
Steering Information​
Tires​
Critical Stability Weights​
1.2 Serial Number Location​
1.3 Lubrication​
Hydraulic Oil Specifications​
1.4 Hydraulic Pressure Settings​
1.5 Hydraulic Cylinder Specifications​
1.6 Engine Specifications​
1.7 Elevation/Tilt Limit Settings​
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance​
General​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
2.2 Preventive Maintenance and Inspection Schedule​
Maintenance and Inspection Schedule Codes​
Footnotes​
2.3 Service And Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication​
Battery​
Lubrication and Servicing​
2.4 Lubrication And Information​
Hydraulic System​
Hydraulic Oil​
Changing Hydraulic Oil​
Lubrication Specifications​
2.5 Service Maintenance Components​
Setting Scissor Arm Safety Prop​
General Maintenance Tips​
Fuel Tank​
Drive Hub​
Scissor Arms - Sliding Wear Pads​
Hydraulic Oil Tank​
Hydraulic Charge Filter​
Oil Change with Filter​
Fuel/Water Separator Filter (Diesel) - Kubota​
Fuel Strainer (Diesel) - Kubota​
Fuel Filter (Gas) - Kubota​
Air Filter​
Engine Coolant​
2.6 Cylinder Drift Test​
Platform Drift​
Cylinder Drift​
2.7 Pins and Composite Bearing Repair Guidelines​
Section 3. Chassis, Platform, & Scissor Arms
3.1 Operating Characteristics​
Leveling Jacks (If Equipped)​
Generator​
Lift​
Drive​
3.2 Tires, Wheels & Drive Assembly​
Tire Damage​
Tire Replacement​
Wheel Replacement​
Wheel Installation​
Drive Assembly​
3.3 Drive Hub (Fairfield)​
Roll and Leak Testing​
Tightening and Torquing Bolts​
Oil Information​
Main Disassembly for Drive Hub​
Hub-Spindle Disassembly​
Cover Disassembly​
Carrier Disassembly​
Carrier Assembly​
Cover Sub-Assembly​
Hub-Spindle Sub-Assembly​
Main Assembly​
Tool List​
Re-Aligning Torque Hub Input Coupling​
3.4 Drive Motor (Sauer)​
Description​
Shaft Seal Replacement​
Loop Flushing Valve​
Troubleshooting​
Disassembly​
Inspection​
Assembly​
Initial Start-Up Procedures​
3.5 Axle Installation​
Removal​
Assembly​
3.6 Steer Installation (All Markets Except for CE and JAPAN)​
Steer Cylinder Removal​
Spindle Removal​
Assembly​
3.7 Steer Installation (CE and Japan Markets)​
Spindle Removal​
Assembly​
Axle Lockout Cylinder​
3.8 Leveling Jacks (If Equipped)​
Cylinder Removal​
Assembly Removal​
3.9 Platform​
Platform Control Station​
Joystick Controller​
3.10 Scissor Arms​
Lift Cylinder Removal​
Scissor Arms Removal​
Scissor Arm Assembly Removal​
3.11 Side Compartment Covers​
Cover Removal​
Cover Installation​
3.12 Ground Control Station​
Control Station Removal​
Ground Control Station Components​
Options Control Module​
3.13 Battery​
3.14 Fuel Tank​
3.15 Hydraulic Tank​
3.16 Kubota Engine​
Engine Tray - Swing Out​
Engine Removal​
Dual Fuel/LPG System​
Changing From Gasoline to LP Gas​
Changing From LP Gas to Gasoline​
Using Liquid Petroleum (LP) Gas​
Propane Fuel System Pressure Relief​
Propane Fuel System Leak Test​
Generator (If Equipped)​
Exhaust System​
Dual Fuel - Gas/Lpg​
Diesel​
Air Cleaner System​
Radiator​
Engine Electrical Component Locations​
Hydraulic Pump Installation​
Pump Coupling Assembly​
Engine Speed Sensor (Kubota Diesel Engine)​
Throttle Actuator Adjustment​
Air Gap Setting​
Diagnosis of Actuator​
Adjustment of The Actuator​
Adjustment Verification of Actuator​
Section 4. Basic Hydraulic Information & Schematics
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
Solenoid Control Valves (Bang-Bang)​
Relief Valves​
Crossover Relief Valves​
4.3 Cylinder Checking Procedure​
Cylinders Without Counterbalance Valves​
Cylinders With Single Counterbalance Valve​
4.4 Oscillating Axle - Lockout Cylinder Test (If Equipped)​
Left Side Wheel Test​
Right Side Wheel Test​
4.5 Drive Pump Pre-fill Procedure​
Pre-Fill of the Drive Pump Housing Without HOC​
Pre-Fill of the Drive Pump Housing With HOC​
Priming the Gear Pump​
4.6 Drive Pump Start-up Procedure​
4.7 Hydraulic Component Start-Up Procedures & Recommendations​
4.8 Hydraulic Valves​
Main Hydraulic Valve​
Main Hydraulic Valve (CE Only)​
Flow Divider Valve​
Leveling Jack Directional Valve (If Equipped)​
Leveling Jack Valves (If Equipped)​
Leveling Jack Manifold Valve (SN 0200267917 to Present) (If Equipped)​
Pressure Relief Valve - Setting Procedures​
4.9 Gear Pump​
4.10 Axial HI 45 Pump​
General Repair Instructions​
Start-Up Procedure​
Removing the Pump​
Electric Control Module​
Control Solenoids​
Shaft Seal, Roller Bearing & Shaft Replacement​
Charge Pump​
Charge Check/HPRV​
Charge Pressure Relief Valve​
Pressure Limiter Valve Replacement​
4.11 Charge Pump Filter​
4.12 Cylinder Repair​
Disassembly​
Cleaning and Inspection​
Assembly​
4.13 Cylinder Assemblies​
Oscillating Axle Cylinder Bleeding Procedure​
4.14 Hydraulic Schematics​
Section 5. JLG Control System
5.1 Analyzer​
Connecting the Analyzer​
Using the Analyzer​
Changing the Access Level​
Adjusting Parameters​
Machine Setup​
System Fault/DTC Indication​
5.2 Analyzer Menu Flow Chart​
Prior to SN 0200267916​
SN 0200267917 to Present​
5.3 Diagnostic Troubleshooting codes (DTC’s) and Flash Codes Description​
5.4 Chassis Tilt Sensor Installation​
5.5 Location of Additional Sensors​
5.6 Calibration Procedures (Prior to SN 0200267916)​
Rotary Angle (Elevation) Sensor Calibration​
Arm Stack Tilt Sensor Calibration​
Oscillating Axle Tilt Sensor​
Chassis Tilt Sensor Calibration​
Drive Minimum Calibration​
Reset Personality Calibration​
5.7 Calibration Procedures (SN 0200267917 to Present)​
Chassis Tilt Sensor​
Set Stow Elevation​
Load Sensing​
Joystick​
5.8 Service Mode Procedures​
ECM Override (Dual Fuel Only)​
Elevation Service​
EEPROM Reset​
Allow Drive​
Allow Leveling Jack Retract​
5.9 Machine Configuration and Programming Settings (Prior to SN 0200267916)​
5.10 Machine Configuration and Programming Settings (SN 0200267917 to Present)​
Section 6. LSS Setup/Calibration/Service
6.1 Connecting the JLG Control System Analyzer​
6.2 Help Menu & Fault Codes​
6.3 Diagnostic Menu​
6.4 Personalities​
6.5 Machine Setup Menu​
6.6 Calibration Menu​
6.7 Service​
Description​
6.8 Calibration​
Procedure​
Testing & Evaluation​
6.9 Troubleshooting​
Section 7. General Electrical Information & Schematics
7.1 General​
7.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Voltage Measurement​
Resistance Measurement​
Continuity Measurement​
Current Measurement​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
7.3 Applying Silicone Dielectric Compound to Electrical Connections​
Installation of Dielectric Grease​
Deutsch HD, DT, DTM, DRC Series​
AMP Seal​
AMP Mate-N-Lok​
DIN Connectors​
Exclusions​
7.4 AMP Connector​
Assembly​
Disassembly​
Wedge Lock​
Service - Voltage Reading​
7.5 Working with Deutsch Connectors​
DT/DTP Series Assembly​
DT/DTP Series Disassembly​
HD30/HDP20 Series Assembly​
HD30/HDP20 Series Disassembly​
7.6 Switches​
Basic Check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
7.7 Electrical Schematics​
