JLG Scissor Lift 330LRT 430LRT Parts Catalog 3121759
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 330LRT 430LRT Scissor Lift
Part Number: 3121759
Publication Date: 2025
Number of Pages: 448 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION
FIGURE 1-2. STEER INSTALLATION (ALL SPECS EXCEPT CE SPECS)
FIGURE 1-3. STEER INSTALLTION (CE & JAPANESE SPECS)
FIGURE 1-4. DRIVE/BRAKE INSTALLATION
FIGURE 1-5. DRIVE HUB ASSEMBLY - FRONT
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR
FIGURE 1-7. DRIVE MOTOR ASSEMBLY
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM-FILLED NON MARKING
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 33/16LL X 16.1 FOAM-FILLED
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 33/1550-16.5 FOAM-FILLED
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - IN315/55D20 FOAM-FILLED
FIGURE 1-13. STROBE LIGHT INSTALLATION (AMBER)
FIGURE 1-14. LEVELING JACKS INSTALLATION (Prior to SN 0200267917)
FIGURE 1-15. LEVELING JACKS INSTALLATION (SN 0200267917 through 0200269765)
FIGURE 1-16. LEVELING JACKS ASSEMBLY
FIGURE 1-17. LEVELING JACKS VALVE ASSEMBLY
SECTION 2 - GROUND CONTROLSFIGURE 2-1. VALVES INSTALLATION (ALL SPECS EXCEPT CE SPECS)
FIGURE 2-2. VALVES INSTALLATION (CE & JAPANESE SPECS)
FIGURE 2-3. MAIN VALVE ASSEMBLY (ALL SPECS EXCEPT CE SPECS)
FIGURE 2-4. MAIN VALVE ASSEMBLY (CE SPECS)
FIGURE 2-5. FLOW DIVIDER VALVE ASSEMBLY
FIGURE 2-6. TANKS AND HORN INSTALLATION (DIESEL MACHINES)
FIGURE 2-7. TANKS AND HORN INSTALLATION (GAS MACHINES)
FIGURE 2-8. HYDRAULIC TANK ASSEMBLY
FIGURE 2-9. GROUND CONTROL BOX ASSEMBLY (DIESEL MACHINES) (Prior to SN 0200267917)
FIGURE 2-10. GROUND CONTROL BOX ASSEMBLY (DIESEL MACHINES) (SN 0200267917 through 0200269765)
FIGURE 2-11. GROUND CONTROL BOX ASSEMBLY (GAS MACHINES) (Prior to SN 0200267917)
FIGURE 2-12. GROUND CONTROL BOX ASSEMBLY (GAS MACHINES) (SN 0200267917 through 0200269765)
FIGURE 2-13. MOTION ALARM INSTALLATION
FIGURE 2-14. HOODS AND LADDERS INSTALLATION (330LRT)
FIGURE 2-15. HOODS AND LADDERS INSTALLATION (430LRT)
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION - KUBOTA DIESEL STAGE III (Prior to SN 0200268705)
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL STAGE III (Prior to SN 0200268705)
FIGURE 3-3. ENGINE ASSEMBLY - KUBOTA DIESEL STAGE III (Prior to SN 0200268705)
FIGURE 3-4. ENGINE INSTALLATION - KUBOTA DIESEL STAGE III WITH GENERATOR (Prior to SN 0200268705)
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL STAGE III WITH GENERATOR (Prior to SN 0200268705)
FIGURE 3-6. ENGINE ASSEMBLY - KUBOTA DIESEL STAGE III WITH GENERATOR (Prior to SN 0200268705)
FIGURE 3-7. ENGINE COMPONENTS - KUBOTA DIESEL STAGE III (Prior to SN 0200268705)
FIGURE 3-8. ENGINE INSTALLATION - KUBOTA DIESEL T4F
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F (Prior to SN 0200268660)
FIGURE 3-10. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL E4B (SN 0200268660 through 0200269765)
FIGURE 3-11. ENGINE ASSEMBLY - KUBOTA DIESEL T4F (Prior to SN 0200268660)
FIGURE 3-12. ENGINE ASSEMBLY - KUBOTA DIESEL E4B (SN 0200268660 through 0200269765)
FIGURE 3-13. ENGINE INSTALLATION - KUBOTA DIESEL STAGE T4F WITH GENERATOR (Prior to SN 0200268660)
FIGURE 3-14. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR (Prior to SN 0200268660)
FIGURE 3-15. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL E4B WITH GENERATOR (SN 0200268660 through 0200269765)
FIGURE 3-16. ENGINE ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR (Prior to SN 0200268660)
FIGURE 3-17. ENGINE ASSEMBLY - KUBOTA DIESEL E4B WITH GENERATOR (SN 0200268660 through 0200269765)
FIGURE 3-18. ENGINE COMPONENTS - KUBOTA DIESEL T4F (Prior to SN 0200268660)
FIGURE 3-19. ENGINE COMPONENTS - KUBOTA DIESEL E4B (SN 0200268660 through 0200269765)
FIGURE 3-20. ENGINE INSTALLATION - KUBOTA GASOLINE
FIGURE 3-21. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-22. ENGINE ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-23. ENGINE INSTALLATION - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-24. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-25. ENGINE ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-26. ENGINE COMPONENTS - KUBOTA GASOLINE
FIGURE 3-27. FUEL/WATER SEPARATOR ASSEMBLY - DIESEL ENGINES
FIGURE 3-28. COUPLING KIT - DIESEL ENGINES
FIGURE 3-29. COUPLING KIT - GASOLINE ENGINES
FIGURE 3-30. PISTON PUMP ASSEMBLY
FIGURE 3-31. SPARK ARRESTOR MUFFLER - OPTIONAL (DIESEL ENGINES) (Prior to SN 0200267546)
FIGURE 3-32. SPARK ARRESTOR MUFFLER - OPTIONAL (GASOLINE ENGINES)
FIGURE 3-33. 7500W GENERATOR INSTALLATION - KUBOTA DIESEL STAGE III
FIGURE 3-34. 7500W GENERATOR INSTALLATION - KUBOTA DIESEL T4F
FIGURE 3-35. 7500W GENERATOR INSTALLATION - KUBOTA GASOLINE
SECTION 4 - SCISSORS ARMSFIGURE 4-1. SCISSORS ARMS INSTALLATION (330LRT)
FIGURE 4-2. SCISSORS ARMS ASSEMBLY (330LRT)
FIGURE 4-3. SCISSORS ARMS INSTALLATION - WITH GENERATOR (330LRT)
FIGURE 4-4. SCISSORS ARMS ASSEMBLY - WITH GENERATOR (330LRT)
FIGURE 4-5. SCISSORS ARMS INSTALLATION (430LRT)
FIGURE 4-6. SCISSORS ARMS ASSEMBLY (430LRT)
FIGURE 4-7. SCISSORS ARMS INSTALLATION - WITH GENERATOR (430LRT)
FIGURE 4-8. SCISSORS ARMS ASSEMBLY - WITH GENERATOR (430LRT)
FIGURE 4-9. ARM GUARDS INSTALLATION (MACHINES WITH LSS)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM MOUNT INSTALLATION (NON-LSS)
FIGURE 5-2. PLATFORM MOUNT INSTALLATION (LSS)
FIGURE 5-3. PLATFORM WITH SINGLE EXTENSION INSTALLATION
FIGURE 5-4. PLATFORM (12.6FT/3.84M LENGTH) WITH DUAL EXTENSION INSTALLATION
FIGURE 5-5. PLATFORM (15.8FT/4.83M LENGTH MEGADECK) WITH DUAL EXTENSION INSTALLATION
FIGURE 5-6. RAIL INSTALLATION - PLATFORM WITH SINGLE EXTENSION
FIGURE 5-7. RAIL INSTALLATION - 12.6FT/3.84M LENGTH PLATFORM WITH DUAL EXTENSION
FIGURE 5-8. RAIL INSTALLATION - 15.8FT/4.83M LENGTH MEGADECK PLATFORM WITH DUAL EXTENSION
FIGURE 5-9. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES (Prior to SN 0200267917)
FIGURE 5-10. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES (WITHOUT LEVELING JACKS) (SN 0200267917 through 0200269765)
FIGURE 5-11. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES (WITH LEVELING JACKS) (SN 0200267917 through 0200269765)
FIGURE 5-12. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES (Prior to SN 0200267917)
FIGURE 5-13. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES (WITHOUT LEVELING JACKS) (SN 0200267917 through 0200269765)
FIGURE 5-14. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES (WITH LEVELING JACKS) (SN 0200267917 through 0200269765)
FIGURE 5-15. DRIVE/STEER CONTROLLER ASSEMBLY
FIGURE 5-16. PLATFORM MODULE INSTALLATION (NON-LSS)
FIGURE 5-17. PLATFORM MODULE INSTALLATION (LSS)
FIGURE 5-18. PIPE RACKS INSTALLATION (OPTIONAL)
FIGURE 5-19. SKYWELDER INSTALLATION (OPTIONAL) (ANSI SPECS)
FIGURE 5-20. SKYWELDER INSTALLATION (OPTIONAL) (CE SPECS)
FIGURE 5-21. WELDER ASSEMBLY
FIGURE 5-22. WORKSTATION INSTALLATION (OPTIONAL)
FIGURE 6-2. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-3. LIFT CYLINDER ASSEMBLY
FIGURE 6-4. LIFT CYLINDER ASSEMBLY
FIGURE 6-5. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - LEVELING JACKS (Prior to SN 0200267917)
FIGURE 7-2. HYDRAULIC DIAGRAM - LEVELING JACKS (SN 0200267917 through 0200269765)
FIGURE 7-3. HYDRAULIC DIAGRAM - STANDARD (ALL SPECS EXCEPT CE SPECS)
FIGURE 7-4. HYDRAULIC DIAGRAM - STANDARD (CE & JAPANESE SPECS)
FIGURE 7-5. HYDRAULIC DIAGRAM LIST
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL DIAGRAM LIST
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT AUSTRALIAN AND CE SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2X4 BOX (CE SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 70X70 BOX (CE SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2X4 BOX (CE SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 70X70 BOX (CE SPECS)
FIGURE 8-10. BATTERY CABLE KIT
FIGURE 8-11. BREAKER BOX KIT (Prior to SN 0200268756)
FIGURE 8-12. BREAKER BOX KIT (SN 0200268756 through 0200269765)
FIGURE 8-13. CHASSIS HARNESS (Prior to SN 0200267917)
FIGURE 8-14. CHASSIS HARNESS (SN 0200267917 through 0200269765)
FIGURE 8-15. ENGINE HARNESS - KUBOTA DIESEL (Prior to SN 0200267917)
FIGURE 8-16. ENGINE HARNESS - KUBOTA DIESEL (SN 0200267917 through 0200269765)
FIGURE 8-17. ENGINE HARNESS - KUBOTA GASOLINE (Prior to SN 0200267917)
FIGURE 8-18. ENGINE HARNESS - KUBOTA GASOLINE (SN 0200267917 through 0200269765)
FIGURE 8-19. GENERATOR HARNESS - 7500W (Prior to SN 0200267640)
FIGURE 8-20. GENERATOR HARNESS - 7500W (SN 0200267640 through 0200269765)
FIGURE 8-21. GROUND CONTROL BOX HARNESS (LOWER) (Prior to SN 0200267917)
FIGURE 8-22. GROUND CONTROL BOX HARNESS (LOWER) (SN 0200267917 through 0200269765)
FIGURE 8-23. GROUND CONTROL BOX HARNESS (UPPER)
FIGURE 8-24. GROUND TO PLATFORM HARNESS (330LRT)
FIGURE 8-25. GROUND TO PLATFORM HARNESS (430LRT)
FIGURE 8-26. LEVELING JACKS HARNESS
FIGURE 8-27. LSS HARNESS
FIGURE 8-28. PLATFORM CONTROL BOX HARNESS (Prior to SN 0200267917)
FIGURE 8-29. PLATFORM CONTROL BOX HARNESS (SN 0200267917 through 0200269765)
FIGURE 8-30. PLATFORM MODULE HARNESS (Prior to SN 0200267917)
FIGURE 8-31. PLATFORM MODULE HARNESS (SN 0200267917 through 0200269765)
FIGURE 8-32. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-33. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)
FIGURE 8-34. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)
FIGURE 8-35. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)
FIGURE 8-36. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE SPEC)
FIGURE 8-37. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70X70 BOX (CE SPEC)
FIGURE 8-38. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 8-39. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70X70 BOX (CE SPEC)
FIGURE 8-40. RECEPTACLE/BREAKER BOX ASSEMBLY - 220V GFI
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN, CE & JAPANESE SPEC (ENGLISH)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE)
FIGURE 9-4. DECAL INSTALLATION - CHINESE SPECS (ENGLISH/CHINESE)
FIGURE 9-5. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH)
FIGURE 9-6. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN)
FIGURE 9-7. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/SPANISH)
FIGURE 9-8. DECAL INSTALLATION - OPTIONS
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
