JLG Scissor Lift 260MRT Service & Maintenance Manual 3121801 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 260MRT Scissor Lift
Part Number: 3121801
Publication Date: 2025
Number of Pages: 108 Pages
Section A. Introduction - Maintenance Safety Precautions
Brand: JLG
General
Hydraulic System Safety
Maintenance
Section 1. Specifications1.1 Operating Specifications
1.2 Capacities
1.3 Component Data
Tires
Pumps
Steer/Drive System
Hydraulic Filter - Inline
Torque Requirement
1.4 Lubrication
Hydraulic Oil
1.5 Lubrication Specifications
1.6 Cylinder Specifications
1.7 Pressure Settings
1.8 Limit Switches
1.9 Major Component Weights
1.10 Critical Stability Weights
1.11 Serial Number Locations
1.12 Torque Charts
Section 2. Procedures2.1 General
2.2 Servicing and Maintenance Guidelines
General
Safety and Workmanship
Cleanliness
Components Removal and Installation
Component Disassembly and Reassembly
Pressure-Fit Parts
Bearings
Gaskets
Bolt Usage and Torque Application
Hydraulic Lines and Electrical Wiring
Lubrication
Batteries
Lubrication and Servicing
2.3 Lubrication Information
Hydraulic Oil
Changing Hydraulic Oil
2.4 Cylinders - Theory of Operation
2.5 Valves - Theory of Operation
Solenoid Control Valves (Bang-Bang)
Proportional Control Valves
Relief Valves
Crossover Relief Valves
2.6 Component Functional Description
Lift Cylinder Counterbalance/Manual Descent Valve
2.7 Wear Pads
Sliding Pads
2.8 Cylinder Checking Procedures
Cylinder w/o Counterbalance Valves - Steer Cylinder
Cylinders w/Single Counterbalance Valves - Lift Cylinder
2.9 Lift Cylinder Removal and Installation.
Removal
Installation
2.10 Cylinder Repair
Disassembly
Cleaning and Inspection
Assembly
2.11 Steer Cylinder Repair
Removal
Disassembly
Assembly
Installation
2.12 Limit Switch Adjustment
Platform Limit Switch
2.13 Pressure Setting Procedures
Main Pressure Adjustment
Lift Relief Adjustments
Steer Relief Adjustment
Leveling Jack Relief Adjustment
Main Valve Components
Leveling Jacks Directional Valve
2.14 Drive Pump Start-up Procedure
2.15 Automatic Choke - Field Adjustment (DF-750)
Inspection
Adjustments
Reassembly
Diesel Engine
2.16 Joystick Controller
2.17 Tilt Sensor
Tilt Sensor, JLG P/N 4000006:
Tilt Sensor, JLG P/N 4000021:
2.18 Calibrations
Tilt Sensor Calibration:
Joystick Calibration (Software 1.5 and Higher and Higher)
2.19 Electronic Control System
Hand Held Analyzer
To Connect the Hand Held Analyzer
Using the Analyzer
Changing the Access Level of the Hand Held Analyzer
Adjusting Parameters Using the Hand Held Analyzer
Machine Setup
2.20 Flash Codes and Descriptions
2.21 Machine Model Adjustment
2.22 Machine Configuration Programming Information
2.23 Preventive Maintenance and Inspection Schedule
Section 3. General Electrical Information & Schematics3.1 General
3.2 Multimeter Basics
Grounding
Backprobing
Min/Max
Polarity
Scale
Voltage Measurement
Resistance Measurement
Continuity Measurement
Current Measurement
Continuity Measurement Over Long Distances
Requirements:
Procedure
3.3 Applying Silicone Dielectric Compound To Amp Connectors
Assembly
Disassembly
Wedge Lock
Service - Voltage Reading
3.4 Working With Deutsch Connectors
DT/DTP Series Assembly
DT/DTP Series Disassembly
HD30/HDP20 Series Assembly
HD30/HDP20 Series Disassembly
3.5 Switches
Basic check
Limit Switches
Automatic Switches
Switch Wiring - Low Side, High Side
3.6 Troubleshooting
General
Troubleshooting Information
Hydraulic Circuit Checks
3.7 Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
