Hyundai
86
176,834
JLG Scissor Lift 260MRT Service & Maintenance Manual 3121108 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 260MRT Scissor Lift
Prior to SN 0200269761
Part Number: 3121108
Publication Date: 2025
Number of Pages: 112 Pages
Section A. Introduction - Maintenance Safety Precautions
General​
Hydraulic System Safety​
Maintenance​
Section 1. Specifications
1.1 Operating Specifications​
1.2 Capacities​
1.3 Component Data​
Engine​
Tires​
Pumps​
Steer/Drive System​
Hydraulic Filter - Inline​
Torque Requirement​
1.4 Lubrication​
Hydraulic Oil​
1.5 Lubrication Specifications​
1.6 Cylinder Specifications​
1.7 Pressure Settings​
1.8 Limit Switches​
1.9 Major Component Weights​
1.10 Critical Stability Weights​
1.11 Serial Number Locations​
1.12 Torque Charts​
Section 2. Procedures
2.1 General​
2.2 Servicing and Maintenance Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication​
Batteries​
Lubrication and Servicing​
2.3 Lubrication Information​
Hydraulic System​
Hydraulic Oil​
Changing Hydraulic Oil​
2.4 Cylinders - Theory of Operation​
2.5 Valves - Theory of Operation​
Solenoid Control Valves (Bang-Bang)​
Proportional Control Valves​
Relief Valves​
Crossover Relief Valves​
2.6 Component Functional Description​
Hydraulic Pump​
Lift Cylinder Counterbalance/Manual Descent Valve​
2.7 Wear Pads​
Sliding Pads​
2.8 Cylinder Checking Procedures​
Cylinder w/o Counterbalance Valves - Steer Cylinder​
Cylinders w/Single Counterbalance Valves - Lift Cylinder​
2.9 Lift Cylinder Removal and Installation.​
Removal​
Installation​
2.10 Cylinder Repair​
Disassembly​
Cleaning and Inspection​
Assembly​
2.11 Steer Cylinder Repair​
Removal​
Disassembly​
Assembly​
Installation​
2.12 Limit Switch Adjustment​
Platform Limit Switch​
2.13 Pressure Setting Procedures​
Main Pressure Adjustment​
Lift Relief Adjustments​
Steer Relief Adjustment​
Leveling Jack Relief Adjustment​
Main Valve Components​
Leveling Jacks Directional Valve​
2.14 Drive Pump Start-up Procedure​
2.15 Automatic Choke - Field Adjustment (DF-750)​
Inspection​
Adjustments​
Reassembly​
Diesel Engine​
2.16 Joystick Controller​
2.17 Tilt Sensor​
Tilt Sensor, JLG P/N 4000006:​
Tilt Sensor, JLG P/N 4000021:​
2.18 Calibrations​
Tilt Sensor Calibration:​
Joystick Calibration (Software 1.5 and Higher and Higher)​
2.19 Electronic Control System​
Hand Held Analyzer​
To Connect the Hand Held Analyzer​
Using the Analyzer​
Changing the Access Level of the Hand Held Analyzer​
Adjusting Parameters Using the Hand Held Analyzer​
Machine Setup​
2.20 Flash Codes and Descriptions​
2.21 Machine Model Adjustment​
2.22 Machine Configuration Programming Information​
2.23 Preventive Maintenance and Inspection Schedule​
Section 3. General Electrical Information & Schematics
3.1 General​
3.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Voltage Measurement​
Resistance Measurement​
Continuity Measurement​
Current Measurement​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
3.3 Applying Silicone Dielectric Compound To Amp Connectors​
Assembly​
Disassembly​
Wedge Lock​
Service - Voltage Reading​
3.4 Working With Deutsch Connectors​
DT/DTP Series Assembly​
DT/DTP Series Disassembly​
HD30/HDP20 Series Assembly​
HD30/HDP20 Series Disassembly​
3.5 Switches​
Basic check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
3.6 Troubleshooting​
General​
Troubleshooting Information​
Hydraulic Circuit Checks​
3.7 Electrical Schematics​
