JLG Scissor Lift 260MRT Parts Catalog 3121802
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 260MRT Scissor Lift
Part Number: 3121802
Publication Date: 2025
Number of Pages: 198 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. FRAME AND STEERING INSTALLATION
FIGURE 1-2. MOTOR/BRAKE/HUB ASSEMBLY (REAR END) (Prior to SN 0200078291, SN 0200104784 through 0200268449)
FIGURE 1-3. MOTOR/BRAKE/HUB ASSEMBLY (REAR ONLY) (SN 0200078291 through 0200104783)
FIGURE 1-4. MOTOR/BRAKE/HUB ASSEMBLY (REAR) (260MRT) (SN 0200268450 through 0200269760)
FIGURE 1-5. MOTOR/HUB ASSEMBLY (FRONT AND) (Prior to SN 0200078291, SN 0200112814 through 0200268449)
FIGURE 1-6. MOTOR/HUB ASSEMBLY (FRONT ONLY) (SN 0200078291 through 0200112813)
FIGURE 1-7. DRIVE MOTOR ASSEMBLY - OPERATORS POSITION RH SIDE - 4WD FRONT (260MRT) (SN 0200268450 through 0200269760)
FIGURE 1-8. FRAME MOUNTED COMPONENTS INSTALLATION
FIGURE 1-9. LEVELING JACKS INSTALLATION (Prior to SN 0200141689)
FIGURE 1-10. LEVELING JACKS AUTO LEVEL INSTALLATION (AUSTRALIAN SPEC AND CE SPEC) (SN 0200128985 through 0200244750, SN 0200141689 through 0200244750)
FIGURE 1-11. LEVELING JACKS AUTO LEVEL INSTALLATION (AUSTRALIAN SPEC AND CE SPEC) (SN 0200244751 through 0200269760)
SECTION 2 - GROUND CONTROLSFIGURE 2-1. CONTROL VALVES AND TANK INSTALLATION
FIGURE 2-2. MAIN VALVE ASSEMBLY
FIGURE 2-3. FLOW DIVIDER ASSEMBLY
FIGURE 2-4. KUBOTA ENGINE INSTALLATION (DIESEL)
FIGURE 2-5. ENGINE COMPONENTS - KUBOTA DIESEL (260MRT) (SN 0200222874 through 0200268449)
FIGURE 2-6. ENGINE COMPONENTS - KUBOTA DIESEL (260MRT) (SN 0200268450 through 0200269760)
FIGURE 2-7. VARIABLE DISPLACEMENT PUMP ASSEMBLY (Prior to SN 0200117591)
FIGURE 2-8. VARIABLE DISPLACEMENT PUMP ASSEMBLY (SN 0200117591 through 0200269760)
FIGURE 2-9. GEAR PUMP ASSEMBLY (Prior to SN 0200111922)
FIGURE 2-10. GEAR PUMP ASSEMBLY (SN 0200111922 through 0200269760)
FIGURE 2-11. GROUND CONTROLS INSTALLATION
FIGURE 2-12. HOODS INSTALLATION
SECTION 3 - SCISSORS ARMSFIGURE 3-1. SCISSOR ARMS INSTALLATION
FIGURE 3-2. ARM GUARDS INSTALLATION
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM COMPONENTS INSTALLATION
FIGURE 4-2. PLATFORM ATTACH INSTALLATION - WITH LSS
FIGURE 4-3. HANDRAIL INSTALLATION (SWING GATE)
FIGURE 4-4. CONSOLE BOX ASSEMBLY
FIGURE 4-5. DRIVE/STEER CONTROLLER ASSEMBLY (Prior to SN 0200142023)
FIGURE 4-6. DRIVE/STEER CONTROLLER ASSEMBLY (SN 0200142023 through 0200269760)
FIGURE 4-7. PLATFORM RAIL PADDING/DECK BUMPERS INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LEVELING JACKS CYLINDER ASSEMBLY (Prior to SN 0200105371)
FIGURE 5-2. LEVELING JACKS CYLINDER ASSEMBLY (SN 0200105371 through 0200141689)
FIGURE 5-3. LEVELING JACKS CYLINDER ASSEMBLY (AUTO LEVEL) (AUSTRALIAN SPEC AND CE SPEC 0200141689 TO 0200269760) (SN 0200128985 through 0200269760)
FIGURE 5-4. LIFT CYLINDER COMPONENTS ASSEMBLY
FIGURE 5-5. STEER CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. DRIVE HYDRAULIC DIAGRAM (STANDARD) (Prior to SN 0200141689)
FIGURE 6-2. DRIVE HYDRAULIC DIAGRAM (STANDARD) (SN 0200141689 through 0200269760)
FIGURE 6-3. DRIVE HYDRAULIC DIAGRAM (LEVELING JACKS) (Prior to SN 0200141689)
FIGURE 6-4. DRIVE HYDRAULIC DIAGRAM (AUTO LEVEL LEVELING JACKS) (AUSTRALIAN SPEC AND CE SPEC) (SN 0200128985 through 0200269760, SN 0200141689 through 0200269760)
FIGURE 6-5. HYDRAULIC DIAGRAM LIST
SECTION 7 - ELECTRICALFIGURE 7-1. ELECTRICAL SCHEMATIC (AUSTRALIAN SPEC AND CE SPEC) (Prior to SN 0200128985, Prior to SN 0200141689)
FIGURE 7-2. ELECTRICAL SCHEMATIC (AUSTRALIAN SPEC AND CE SPEC) (SN 0200128985 through 0200200646, SN 0200141689 through 0200200646)
FIGURE 7-3. ELECTRICAL SCHEMATIC (SN 0200200647 through 0200269760)
FIGURE 7-4. ELECTRICAL COMPONENTS INSTALLATION (Prior to SN 0200141689)
FIGURE 7-5. ELECTRICAL COMPONENTS INSTALLATION (SN 0200141689 through 0200269760)
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION (Prior to SN 0200149779)
FIGURE 8-2. DECAL INSTALLATION (SN 0200149779 through 0200269760)
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. MODEL 260MRT STANDARD PARTS
FIGURE 9-2. MODEL 260MRT VARIABLE PARTS
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
