JLG Scissor Lift 2032ES 2632ES Parts Catalog 3121682
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG 2032ES 2632ES Scissor Lift
Part Number: 3121682
Publication Date: 2025
Number of Pages: 498 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEERING INSTALLATION (USA AND MEXICO BUILT MACHINES) (SN 0200000100 to Present, SN M200000100 through M200039289)
FIGURE 1-2. STEERING INSTALLATION (BELGIUM AND CHINA BUILT MACHINES)
FIGURE 1-3. DRIVE HUB AND MODULE INSTALLATION
FIGURE 1-4. DRIVE HUB AND MODULE INSTALLATION (BELGIUM BUILT MACHINES ONLY)
FIGURE 1-5. DRIVE MOTOR/HUB ASSEMBLY
FIGURE 1-6. HUB ASSEMBLY - REAR
FIGURE 1-7. TIRE AND WHEEL ASSEMBLY
FIGURE 1-8. POTHOLE PROTECTION INSTALLATION - NON-UL
FIGURE 1-9. POTHOLE PROTECTION INSTALLATION - UL
FIGURE 1-10. BATTERY CHARGER INSTALLATION WITH 110V PLUG AND DELTA-Q CHARGER (ANSI, ANSI EXPORT, CSA, JAPANESE AND UL SPECS)
FIGURE 1-11. BATTERY CHARGER INSTALLATION WITH 110V PLUG AND EAGLE PERFORMANCE CHARGER (ANSI AND CSA SPECS)
FIGURE 1-12. BATTERY CHARGER INSTALLATION WITH LOCALLY SUPPLIED PLUG AND DELTA-Q CHARGER (ANSI, ANSI EXPORT, CSA AND CE SPECS)
FIGURE 1-13. BATTERY CHARGER INSTALLATION WITH LOCALLY SUPPLIED PLUG AND EAGLE PERFORMANCE CHARGER (ANSI AND CSA SPECS)
FIGURE 1-14. BATTERY CHARGER INSTALLATION WITH LOCALLY SUPPLIED PLUG (AUSTRALIAN SPEC) (SN 0200000100 to Present, SN B200000100 through B200061738, SN M200000100 to Present, SN 1200000100 to Present)
FIGURE 1-15. BATTERY CHARGER INSTALLATION WITH LOCALLY SUPPLIED PLUG (AUSTRALIAN SPEC) (SN B200061739 to Present)
FIGURE 1-16. BATTERY CHARGER INSTALLATION – WITH VOLTAGE GUARD (LOCALLY SUPPLIED PLUG) (ANSI EXPORT AND KOREA SPECS)
FIGURE 1-17. BATTERY CHARGER INSTALLATION – WITH VOLTAGE GUARD AND CHINESE PLUG (ANSI EXPORT AND KOREA SPECS)
FIGURE 1-18. BATTERY CHARGER INSTALLATION – WITH VOLTAGE GUARD AND CHINESE PLUG (CHINESE SPECS) (SN B200000100 through B200046727)
FIGURE 1-19. BATTERY CHARGER INSTALLATION WITH CHINESE PLUG (CHINESE SPEC)
FIGURE 1-20. BATTERY CHARGER ASSEMBLY - DELTA-Q
FIGURE 1-21. BATTERY CHARGER ASSEMBLY - EAGLE PERFORMANCE
FIGURE 1-22. CHARGER (INVERTER) INSTALLATION (ANSI, ANSI EXPORT, CSA SPECS)
FIGURE 1-23. BATTERY CHARGER INSTALLATION - GREEN POWER (CHINESE PLUG) (CHINESE SPECS) (SN 0200000100 through 0200261035, SN B200000100 through B200036484, SN M200000100 through M200007339)
FIGURE 1-24. BATTERY CHARGER INSTALLATION - GREEN POWER (CHINESE PLUG) (CHINESE SPECS)
FIGURE 1-25. BATTERY CHARGER INSTALLATION - GREEN POWER (LOCALLY SUPPLIED PLUG) (KOREA SPECS)
FIGURE 1-26. BATTERY CHARGER INSTALLATION - GREEN POWER (110V PLUG) (JAPANESE SPECS)
FIGURE 1-27. BEACON (AMBER) LIGHT INSTALLATION (OPTIONAL)
FIGURE 1-28. LADDER INSTALLATION (2032ES)
FIGURE 1-29. LADDER INSTALLATION (2632ES)
SECTION 2 - GROUND COMPONENTSFIGURE 2-1. GROUND CONTROL BOX/ALARM INSTALLATION - NO LSS (SN 0200000001 to Present, SN B200023312 to Present, SN M200000100 through M200039289)
FIGURE 2-2. GROUND CONTROL BOX/ALARM INSTALLATION - NO LSS (SN B200000100 through B200023311)
FIGURE 2-3. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (ALL SPECS EXCEPT CE SPEC) (SN 0200000001 to Present, SN B200023312 to Present, SN M200000100 through M200039289)
FIGURE 2-4. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (ALL SPECS EXCEPT CE SPEC) (SN B200000100 through B200023311)
FIGURE 2-5. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (CE SPEC) (SN 0200000001 through 0200241828)
FIGURE 2-6. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (CE SPEC) (SN B200000100 through B200021650)
FIGURE 2-7. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (CE SPECS) (SN 0200241829 to Present, SN B200021651 to Present, SN M200000100 through M200039289)
FIGURE 2-8. GROUND CONTROL BOX/ALARM INSTALLATION - LSS (CE SPECS) (SN 1200025021 to Present)
FIGURE 2-9. GROUND CONTROL BOX ASSEMBLY - NO LSS (SN 0200000001 to Present, SN B200023312 to Present, SN M200000100 through M200039289)
FIGURE 2-10. GROUND CONTROL BOX ASSEMBLY - NO LSS (SN B200000100 through B200023311)
FIGURE 2-11. GROUND CONTROL BOX ASSEMBLY - LSS (ALL SPECS EXCEPT CE SPEC) (SN 0200000001 to Present, SN B200023312 to Present, SN M200000100 through M200039289)
FIGURE 2-12. GROUND CONTROL BOX ASSEMBLY - LSS (ALL SPECS EXCEPT CE SPEC) (SN B200000100 through B200023311)
FIGURE 2-13. GROUND CONTROL BOX ASSEMBLY - LSS (CE SPECS) (SN 0200000001 through 0200241828)
FIGURE 2-14. GROUND CONTROL BOX ASSEMBLY - LSS (CE SPECS) (SN B200000100 through B200021650)
FIGURE 2-15. GROUND CONTROL BOX ASSEMBLY - LSS (CE SPECS) (SN 0200241829 to Present, SN B200021651 to Present, SN M200000100 through M200039289)
FIGURE 2-16. BATTERIES INSTALLATION - AGM AND EVG TYPE - 225 AH RATING (NON-LOCKING COVERS)
FIGURE 2-17. BATTERIES INSTALLATION - AGM AND EVG TYPE - 225 AH RATING (NON-UL LOCKING COVERS)
FIGURE 2-18. BATTERIES INSTALLATION - AGM AND EVG TYPE - 225 AH RATING (UL LOCKING COVERS)
FIGURE 2-19. BATTERIES INSTALLATION - AGM VISION AND EVG TYPE - 220 AH RATING (NON-LOCKING COVERS)
FIGURE 2-20. BATTERIES INSTALLATION - AGM VISION AND EVG TYPE - 220 AH RATING (NON-UL LOCKING COVERS)
FIGURE 2-21. BATTERIES INSTALLATION - EV TYPE - 244 AH RATING (NON-LOCKING COVERS)
FIGURE 2-22. BATTERIES INSTALLATION - EV TYPE - 244 AH RATING (NON-UL LOCKING COVERS)
FIGURE 2-23. BATTERIES INSTALLATION - EV TYPE - 244 AH RATING (UL LOCKING COVERS)
FIGURE 2-24. BATTERIES INSTALLATION - GC TYPE - 225 AH RATING (NON-LOCKING COVERS)
FIGURE 2-25. BATTERIES INSTALLATION - GC TYPE - 225 AH RATING (NON-UL LOCKING COVERS)
FIGURE 2-26. BATTERIES INSTALLATION - GC TYPE - 225 AH RATING (UL LOCKING COVERS)
FIGURE 2-27. BATTERIES INSTALLATION - 220 AH RATING WITHOUT BATTERIES (NON LOCKING COVERS)
FIGURE 2-28. BATTERY TRAY ASSEMBLY - NON-UL
FIGURE 2-29. BATTERY TRAY ASSEMBLY - UL
FIGURE 2-30. BATTERY COVER ASSEMBLY - NON-LOCKING
FIGURE 2-31. BATTERY COVER ASSEMBLY - LOCKING
FIGURE 2-32. BRAKE DISCONNECT AND MDI (MULTIFUNCTION DIGITAL INDICATOR) GAUGE INSTALLATION
FIGURE 2-33. BRAKE CABLE INSTALLATION (OPTIONAL)
SECTION 3 - SCISSORS ARMSFIGURE 3-1. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2032ES) (SN 0200000100 to Present, SN M200000100 through M200039289)
FIGURE 3-2. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2032ES) (SN 0200000100 to Present, SN M200000100 through M200039289)
FIGURE 3-3. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (BELGIUM AND CHINA BUILT MACHINES) (2032ES)
FIGURE 3-4. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (BELGIUM AND CHINA BUILT MACHINES) (2032ES)
FIGURE 3-5. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2032ES) (SN 0200000100 to Present, SN M200000100 through M200039289)
FIGURE 3-6. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2032ES) (SN 0200000100 to Present, SN M200000100 through M200039289)
FIGURE 3-7. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2032ES)
FIGURE 3-8. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2032ES)
FIGURE 3-9. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (USA BUILT MACHINES) (2632ES) (SN 0200000001 through 0200241220)
FIGURE 3-10. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (USA BUILT MACHINES) (2632ES) (SN 0200000001 through 0200241220)
FIGURE 3-11. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2632ES) (SN 0200241221 to Present, SN M200000100 through M200022019)
FIGURE 3-12. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2632ES) (SN 0200241221 to Present, SN M200000100 through M200039289)
FIGURE 3-13. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200000100 through B200020981)
FIGURE 3-14. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200000100 through B200020981)
FIGURE 3-15. SCISSORS ARMS INSTALLATION - STANDARD HYDRAULIC OIL (BELGIUM, CHINA AND MEXICO BUILT MACHINES) (2632ES) (SN 1200025021 to Present, SN B200020982 to Present, SN M200022020 through M200039289)
FIGURE 3-16. SCISSORS ARMS ASSEMBLY - STANDARD HYDRAULIC OIL (BELGIUM AND CHINA BUILT MACHINES) (2632ES) (SN 1200025021 to Present, SN B200020982 to Present)
FIGURE 3-17. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (USA BUILT MACHINES) (2632ES) (SN 0200000001 through 0200241220)
FIGURE 3-18. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (USA BUILT MACHINES) (2632ES) (SN 0200000001 through 0200241220)
FIGURE 3-19. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2632ES) (SN 0200241221 to Present, SN M200000100 through M200039289)
FIGURE 3-20. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (USA AND MEXICO BUILT MACHINES) (2632ES) (SN 0200241221 to Present, SN M200000100 through M200039289)
FIGURE 3-21. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200000100 through B200020891)
FIGURE 3-22. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200000100 through B200020891)
FIGURE 3-23. SCISSORS ARMS INSTALLATION - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200020982 to Present)
FIGURE 3-24. SCISSORS ARMS ASSEMBLY - BIODEGRADEABLE HYDRAULIC OIL (CHINA BUILT MACHINES) (2632ES) (SN B200020982 to Present)
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM INSTALLATION - WITH INSIDE EXTENSION RAILS AND WITHOUT LSS
FIGURE 4-2. PLATFORM INSTALLATION - WITH OUTSIDE EXTENSION RAILS AND WITHOUT LSS
FIGURE 4-3. PLATFORM INSTALLATION - WITH INSIDE EXTENSION RAILS AND WITH LSS
FIGURE 4-4. PLATFORM INSTALLATION - WITH OUTSIDE EXTENSION RAILS AND WITH LSS
FIGURE 4-5. PLATFORM AND EXTENSION ASSEMBLY - WITH INSIDE EXTENSION RAILS
FIGURE 4-6. PLATFORM AND EXTENSION ASSEMBLY - WITH OUTSIDE EXTENSION RAILS
FIGURE 4-7. LATCH ASSEMBLY - WITH INSIDE EXTENSION RAILS (SN 0200249260 to Present, SN 1200025023 through 1200030229, SN B200024834 through B200051215, SN M200000100 through M200021508)
FIGURE 4-8. LATCH ASSEMBLY - WITH INSIDE EXTENSION RAILS (SN 1200030230 to Present, SN B200051216 to Present, SN M200021509 through M200039289)
FIGURE 4-9. LATCH ASSEMBLY - WITH OUTSIDE EXTENSION RAILS
FIGURE 4-10. RAILS INSTALLATION - WITH INSIDE EXTENSION RAILS AND CHAIN GATE
FIGURE 4-11. RAILS INSTALLATION - WITH INSIDE EXTENSION RAILS, HANDLE AND CHAIN GATE
FIGURE 4-12. RAIL KIT - WITH INSIDE EXTENSION RAILS AND CHAIN GATE
FIGURE 4-13. RAIL KIT - WITH INSIDE EXTENSION RAILS, HANDLE AND CHAIN GATE
FIGURE 4-14. RAILS INSTALLATION - WITH INSIDE EXTENSION RAILS AND SELF CLOSING GATE
FIGURE 4-15. RAILS INSTALLATION - WITH INSIDE EXTENSION RAILS, HANDLE AND SELF CLOSING GATE
FIGURE 4-16. RAILS INSTALLATION - WITH OUTSIDE EXTENSION RAILS AND SELF CLOSING GATE
FIGURE 4-17. RAIL KIT - WITH INSIDE EXTENSION RAILS AND SELF CLOSING GATE
FIGURE 4-18. RAIL KIT - WITH INSIDE EXTENSION RAILS, HANDLE AND SELF CLOSING GATE
FIGURE 4-19. RAIL KIT - WITH OUTSIDE EXTENSION RAILS AND SELF CLOSING GATE
FIGURE 4-20. PLATFORM CONSOLE ASSEMBLY
FIGURE 4-21. PLATFORM CONSOLE ASSEMBLY
FIGURE 4-22. DRIVE/STEER CONTROLLER ASSEMBLY
FIGURE 4-23. PLATFORM CONSOLE HANGER INSTALLATION (OPTIONAL)
FIGURE 4-24. WORKSTATION WITHOUT DC CONVERTER INSTALLATION
FIGURE 4-25. WORKSTATION WITH DC CONVERTER INSTALLATION (2032ES)
FIGURE 4-26. WORKSTATION WITH DC CONVERTER INSTALLATION (2632ES)
FIGURE 4-27. ELECTRICIAN'S TREE INSTALLATION
FIGURE 4-28. LOW HEIGHT DRIVE CUTOUT (JAPANESE SPECS ONLY) (2032ES)
FIGURE 4-29. LOW HEIGHT DRIVE CUTOUT (JAPANESE SPECS ONLY) (2632ES)
FIGURE 4-30. OVERHEAD PROTECTION AND LOW HEIGHT DRIVE CUTOUT (KOREAN SPECS ONLY) (2032ES)
FIGURE 4-31. OVERHEAD PROTECTION AND LOW HEIGHT DRIVE CUTOUT (KOREAN SPECS ONLY) (2632ES)
FIGURE 4-32. OVERHEAD SWITCH KIT (FRONT) (SN M200000100 through B200046826)
FIGURE 4-33. OVERHEAD SWITCH KIT (REAR) (SN M200000100 through B200046826)
FIGURE 4-34. OVERHEAD SWITCH KIT (FRONT/REAR) (SN B200046827 to Present)
FIGURE 4-35. PANEL INSTALLATION (ANSI, ANSI EXPORT, CHINESE, CSA AND KOREA SPECS)
FIGURE 4-36. PANEL INSTALLATION (AUSTRALIAN, CE AND JAPANESES SPECS)
FIGURE 4-37. PIPE RACKS INSTALLATION (FACTORY INSTALLED)
FIGURE 4-38. PIPE RACK INSTALLATION (FACTORY INSTALLED)
FIGURE 4-39. QUIK WELDER INSTALLATION (2032ES)
FIGURE 4-40. QUIK WELDER INSTALLATION (2632ES)
FIGURE 4-41. QUIK WELDER READY INSTALLATION (2032ES)
FIGURE 4-42. QUIK WELDER READY INSTALLATION (2632ES)
SECTION 5 - CYLINDERFIGURE 5-1. LIFT CYLINDER ASSEMBLY (TEXAS HYDRAULICS) (2032ES)
FIGURE 5-2. LIFT CYLINDER ASSEMBLY - WITH STANDARD HYDRAULIC OIL (SERTA) (2032ES)
FIGURE 5-3. LIFT CYLINDER ASSEMBLY - WITH STANDARD HYDRAULIC OIL (SH-PAC) (2032ES)
FIGURE 5-4. LIFT CYLINDER ASSEMBLY - WITH BIODEGRADEABLE HYDRAULIC OIL (SERTA) (2032ES)
FIGURE 5-5. LIFT CYLINDER ASSEMBLY - WITH BIODEGRADEABLE HYDRAULIC OIL (SH-PAC) (2032ES)
FIGURE 5-6. LIFT CYLINDER ASSEMBLY (TEXAS HYDRAULICS) (2632ES)
FIGURE 5-7. LIFT CYLINDER ASSEMBLY - WITH STANDARD HYDRAULIC OIL (SERTA) (2632ES)
FIGURE 5-8. LIFT CYLINDER ASSEMBLY - WITH STANDARD HYDRAULIC OIL (SH-PAC) (2632ES)
FIGURE 5-9. LIFT CYLINDER ASSEMBLY - WITH BIODEGRADEABLE HYDRAULIC OIL (SERTA) (2632ES)
FIGURE 5-10. LIFT CYLINDER ASSEMBLY - WITH BIODEGRADEABLE HYDRAULIC OIL (SH-PAC) (2632ES)
FIGURE 5-11. STEER CYLINDER ASSEMBLY (SERTA)
FIGURE 5-12. STEER CYLINDER ASSEMBLY (SH-PAC)
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM LIST
SECTION 7 - ELECTRICALFIGURE 7-1. ELECTRICAL DIAGRAM LIST
FIGURE 7-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI
FIGURE 7-3. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GRD (ANSI EXPORT SPEC ONLY)
FIGURE 7-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPEC ONLY)
FIGURE 7-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPEC ONLY)
FIGURE 7-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE SPEC ONLY)
FIGURE 7-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GRD (CE SPEC ONLY)
FIGURE 7-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GRD (CE SPEC ONLY)
FIGURE 7-9. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI EXPORT AND CHINESE SPEC ONLY)
FIGURE 7-10. BATTERY CABLE KIT
FIGURE 7-11. BRAKE DISCONNECT HARNESS
FIGURE 7-12. BREAKER BOX KIT WITH TWO BREAKERS (CE SPEC ONLY)
FIGURE 7-13. BREAKER BOX KIT WITH THREE BREAKERS (CE SPEC ONLY)
FIGURE 7-14. CABLES INSTALLATION (2032ES)
FIGURE 7-15. CABLES INSTALLATION (2032ES)
FIGURE 7-16. CABLES INSTALLATION (2032ES)
FIGURE 7-17. CABLES INSTALLATION (2032ES)
FIGURE 7-18. CABLES INSTALLATION (2032ES)
FIGURE 7-19. CABLES INSTALLATION (2032ES)
FIGURE 7-20. CABLES INSTALLATION (2632ES)
FIGURE 7-21. CABLES INSTALLATION (2632ES)
FIGURE 7-22. CABLES INSTALLATION (2632ES)
FIGURE 7-23. CABLES INSTALLATION (2632ES)
FIGURE 7-24. CABLES INSTALLATION (2632ES)
FIGURE 7-25. CABLES INSTALLATION (2632ES)
FIGURE 7-26. CHARGER CORD PLUG INSTALLATION - 110V IEC YELLOW (CE SPEC ONLY)
FIGURE 7-27. CHARGER CORD PLUG INSTALLATION - 220V IEC BLUE (CE SPEC)
FIGURE 7-28. CHARGER CORD PLUG INSTALLATION - 220V AFSINT 107 (CE SPEC)
FIGURE 7-29. CHARGER CORD PLUG INSTALLATION - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 7-30. CHARGER CORD PLUG INSTALLATION - 220V POST GROUND (CE SPEC)
FIGURE 7-31. CHARGER CORD PLUG INSTALLATION (KOREA SPEC)
FIGURE 7-32. CHASSIS HARNESS (SN 0200000100 to Present, SN B200000100 through B200061738, SN M200000100 to Present, SN 1200000100 to Present)
FIGURE 7-33. CHASSIS HARNESS (SN B200061739 to Present)
FIGURE 7-34. CHASSIS HARNESS - UL SPEC
FIGURE 7-35. CYLINDER HARNESS
FIGURE 7-36. DRIVE CABLE ASSEMBLY
FIGURE 7-37. DRIVE FIELD CONNECTION HARNESS
FIGURE 7-38. GROUND CONTROL BOX HARNESS (SN B200000100 through B200023311)
FIGURE 7-39. GROUND CONTROL BOX HARNESS (SN 0200000001 to Present, SN 1200025021 to Present, SN B200023312 to Present, SN M200000100 through M200039289)
FIGURE 7-40. GROUND CONTROL BOX HARNESS - NO LSS (SN 0200266380 to Present, SN B200042925 to Present, SN M200012165 through M200039289)
FIGURE 7-41. GROUND TO PLATFORM HARNESS (2032ES)
FIGURE 7-42. GROUND TO PLATFORM HARNESS (2032ES)
FIGURE 7-43. GROUND TO PLATFORM HARNESS (2632ES)
FIGURE 7-44. GROUND TO PLATFORM HARNESS (2632ES)
FIGURE 7-45. LOAD SENSE HARNESS WITHOUT FUSE (SN 0200000100 to Present, SN B200000100 through B200061738, SN M200000100 to Present, SN 1200000100 to Present)
FIGURE 7-46. LOAD SENSE HARNESS WITH FUSE (SN B200061739 to Present)
FIGURE 7-47. MDI (MULTIFUNCTION DIGITAL INDICATOR) HARNESS
FIGURE 7-48. PLATFORM BOX HARNESS
FIGURE 7-49. PLATFORM CABLE ASSEMBLY (SN 0200000100 through 0200262518, SN 1200025021 to Present, SN B200000100 to Present, SN M200000100 through M200010204)
FIGURE 7-50. PLATFORM CABLE ASSEMBLY (SN 0200262519 to Present, SN M20010205 through M200039289)
FIGURE 7-51. PUMP POWER CABLE ASSEMBLY
FIGURE 7-52. RECEPTACLE BOX KIT - 110V GFI
FIGURE 7-53. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)
FIGURE 7-54. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)
FIGURE 7-55. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)
FIGURE 7-56. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 7-57. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE SPEC)
FIGURE 7-58. WORKSTATION POWER HARNESS
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION - ANSI SPEC (ENGLISH)
FIGURE 8-2. DECAL INSTALLATION - AUSTRALIAN SPEC (ENGLISH)
FIGURE 8-3. DECAL INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH)
FIGURE 8-4. DECAL INSTALLATION - CE SPEC (ENGLISH)
FIGURE 8-5. DECAL INSTALLATION - CHINA SPEC (GB)
FIGURE 8-6. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)
FIGURE 8-7. DECAL INSTALLATION - CSA SPEC (ENGLISH/FRENCH)
FIGURE 8-8. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)
FIGURE 8-9. DECAL INSTALLATION - LATIN AMERICAN SPEC (ENGLISH/SPANISH)
FIGURE 8-10. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
