JLG Boom Lift X600AJ X20JP Service & Maintenance Manual 31223077 2025
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service & Maintenance Manual
Model: JLG X600AJ X20JP Boom Lift
Part Number: 31223077
Publication Date: 2025
Number of Pages: 326 Pages
Safety
Brand: JLG
Safety
General (concept)
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information & SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Reach Specification
2.1.5 Function Speed Data
2.1.6 Hydraulic Pressure Settings
2.1.7 Major Components Weight
Machine Temperature Chart
Serial Number Locations
2.3.1 Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Capacities
Machine Characteristics
Maintenance & Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 As Needed
3.3.2 Before starting
3.3.3 First 50 Hours
3.3.4 Every 100 Hours
3.3.5 First 250 Hours
3.3.6 Every 250 Hours
3.3.7 Every 500 Hours
3.3.8 Every 1000 Hours
3.3.9 Every 1000 Hours or 1 Year
3.3.10 Every 1000 Hours or 3 Months
3.3.11 First 2000 Hours
3.3.12 Every 3000 Hours or Every 7 Years
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Wire Rope and Pulleys
3.7.2 Inspection
3.7.3 Three Month Inspection
3.7.4 Seven Year or 3000 Hour Replacement
3.7.5 Wire Rope Tension Adjustment Procedure
Hydraulic Filter Replacement
Engine General Inspection
Bio Fuel
Swing Drive
3.11.1 Structure and Function
3.11.2 Transporting Swing Drives
3.11.3 Swing Drive Positioning
3.11.4 Bolting the Swing Drive
3.11.5 Maintenance Schedule
3.11.6 Lubrication
3.11.7 Maintenance Tasks
3.11.8 Lubricating the Swing Drive
3.11.9 Inspecting the Seals
Wheel Drive
3.12.1 Wheel Drive
Rubber Track Maintenance
3.13.1 Track Tension Check
3.13.2 Track Tension Adjustment
3.13.3 Checking the Rubber Tracks
Battery Maintenance and Charging
3.14.1 Charge Information
3.14.2 Lithium Cells
3.14.3 Battery Charger
3.14.4 DC-DC Transformer
3.14.5 Electric Motor
3.14.6 RPM Regulation System
3.14.7 RPM Setting
3.14.8 Temperature Ongoings (Heaters And Fans)
3.14.9 Diagnostics and Fault Codes
3.14.10 Battery Charging System
Testing, Calibrations, & Special ProceduresSpecial Tools
4.1.1 General
4.1.2 Multimeter Basics
Testing Procedures
Calibration Procedures
4.3.1 Calibration Requirement
4.3.2 Proximity Sensor Adjustment
Special Procedures
4.4.1 Cylinder Drift Test
4.4.2 Fuel Tank Cleaning and Drying
Wheel Drive Hub
System SoftwareJLG Control System
5.1.1 Introduction
5.1.2 Machine Ignition
5.1.3 Platform - Remote Control Station
5.1.4 LCD Display Icon
5.1.5 Lithium Only Icons
5.1.6 Tilt Conditions Drive Cut-Out
5.1.7 Speed Control Conditions on X Axle
5.1.8 Pushbuttons
Analyzer Software Accessibility
5.2.1 Platform Remote Control Service
5.2.2 Input Menu
5.2.3 Language Menu
5.2.4 Errors Menu
5.2.5 RAMP Menu
5.2.6 CURRENT Menu
5.2.7 Working Hours Menu
5.2.8 Machine Setup Menu
5.2.9 Joystick
5.2.10 Calibrating the Joystick
Software & Electronic Control Module
5.3.1 Electronic Control Module (ECM)
CanBus Communication
5.4.1 CANBus Diagnostics
5.4.2 CAN Timeout Menu
5.4.3 CANBus Device Layout
5.4.4 SENSORS AND DEVICES NOT COMMUNICATING THROUGH CANBus
Fault CodesFault Codes Introduction
6.1.1 Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
7.3.1 Hydraulic Components Identification and location
7.3.2 Boom Component Hydraulic System
7.3.3 Hydraulic Component Start-Up Procedures and Recommendations
7.3.4 Pressure Setting Procedure
7.3.5 Control Valve Turntable Functions
7.3.6 Outriggers Auto Retraction
7.3.7 Hydraulic System Pump and Pressure Lines
7.3.8 Ground Component Hydraulic System
7.3.9 Outriggers
7.3.10 Drive Gear Motors
7.3.11 Tracks Widening
Torque Values
Hydraulic Diagrams
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
Removal and InstallationRubber Track
9.1.1 Removal of Rubber Track
9.1.2 Installation of the Rubber Track
9.1.3 Checking Tightness of Nuts and Bolts
Undercarriage Components
9.2.1 Roller Lower Wheel and Tracks Adjuster Replacement
9.2.2 Sprocket and Gear Motor Replacement
Axle Extension Removal
9.3.1 Removal
9.3.2 Inspection of Slide Guides
9.3.3 Installation
Boom
9.4.1 Removal
9.4.2 Inspection
9.4.3 Installation
Platform
9.5.1 Platform Removal/Installation
9.5.2 Load Cell and Footswitch Removal/ Installation
SkyGuard
9.6.1 SkyGuard Installation – One/Two-Person Platform
9.7.1 Thermic Engine Replacement
9.7.2 Electric Motor Replacement
Hydraulic Cylinders
Hydraulic Valves
Hydraulic Pumps
9.11.1 Removal
9.11.2 Installation
9.11.3 Repair
Electrical Components
Disassembly and AssemblyDrive Assembly
Boom
10.2.1 Disassembly
10.2.2 Inspection
10.2.3 Assembly
Rotary Actuator
10.3.1 Disassembly
10.3.2 Cleaning
10.3.3 Assembly
10.3.4 Installing Counterbalance Valve
Engine Components
Pumps
10.5.1 Disassembly
10.5.2 Assembly
Hydraulic Cylinders
10.7.1 Cylinders Disassembly and Assembly
10.7.2 Cylinders With Sensors
10.7.3 Cylinder Repair Without Sensor
Hydraulic Valves
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
12.2.1 ELECTRICAL SCHEMATICS MANUALS
- SuperPac Parts Manual
- StratoLift Parts Manual
