JLG Boom Lift X600AJ Operation Safety Manual 3121637
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG X600AJ Boom Lift
Part Number: 3121637
Publication Date: 2025
Number of Pages: 170 Pages
FOREWORD
SAFETY ALERT SYMBOLS AND SAFETY SIGNAL WORDS
REVISION LOG
SECTION 1. SAFETY PRECAUTIONS
Brand: JLG
FOREWORD
REVISION LOG
1.1 GENERAL
1.2 PRE-OPERATION
Operator Training and Knowledge
Workplace Inspection
Machine Inspection
1.3 OPERATION
General
Trip and Fall Hazards
Electrocution Hazards
Tipping Hazards
Crushing and Collision Hazards
1.4 TOWING, LIFTING, AND HAULING
1.5 MAINTENANCE
Maintenance Hazards
Battery Hazards
SECTION 2. PREPARATION AND INSPECTION2.1 PERSONNEL TRAINING
Operator Training
Training Supervision
Operator Responsibility
2.2 PREPARATION, INSPECTION, AND MAINTENANCE
Machine Familiarization
Pre-Start Inspection
Walk-Around Inspection
General
Function Check
SECTION 3. MACHINE CONTROLS, INDICATORS AND OPERATION3.1 Ground Control Station
Ground Control Station - With Enable Lever
Ground Control Station - With Enable Knob
3.2 Platform/Remote Control Station
Maintenance Control Position On The Ground
Platform/Remote Control Position From The Ground
Control Position From In The Platform
Platform/Remote Control Station Functions
Platform/Remote Control Station LCD Display
SECTION 4. MACHINE OPERATION4.1 DESCRIPTION
4.2 BOOM OPERATING CHARACTERISTICS AND LIMITATIONS
Capacities
Stability
4.3 ENGINE OPERATION
Gas Engine Starting Procedure
Gas Engine Shutdown Procedure
Electric Engine Starting Procedure - AC Voltage Machine
Electric Engine Starting Procedure - LITHIUM-ION Machine
4.4 BASE AND BOOM/JIB ALIGNMENT
4.5 TRACKS - DRIVING, STEERING AND TRACK WIDTH ADJUST
Track Width Adjust
Traveling (Drive and Steer)
Traveling (Grades and Side Slopes)
Jib Position for Traveling
4.6 OUTRIGGER OPERATION
Setting Outriggers From the Platform/Remote Console
Retracting The Outriggers (Reference Figure 4-5. for item numbers)
4.7 BOOM/PLATFORM OPERATION
Overload Alarm
Engine Pre-Heat
Platform Level Adjustment
Raise And Lower The Tower Boom
Raise And Lower The Main Boom
Telescope The Main Boom
Platform Rotation (Item 19, Figure 4-5.)
Raise And Lower The Jib (Item 20, Figure 4-5.)
Swinging The Boom (Item 21, Figure 4-5.)
SkyGuard Operation
4.8 PLATFORM REMOVAL/INSTALLATION
4.9 BATTERY CHARGING - GAS/AC-ELECTRIC
Battery Charging - Daily
4.10 BATTERY CHARGING - LITHIUM-ION MACHINE
Charging the Battery Pack
Charge Curve
4.11 SHUT DOWN AND PARK
4.12 LIFTING AND TIE DOWN
Lifting - Outrigger Lifting Rings
Lifting - Fork Lift Pockets
Loading and Unloading the Machine on Transport Vehicles Using Ramps
Tie Down
4.13 MACHINE DECALS
4.14 DUAL SIDE ENTRY(DSE) PLATFORM DECALS
SECTION 5. EMERGENCY PROCEDURES5.1 General
5.1 Incident Notification
5.1 Emergency Operation
Power Main Cut-Off Switch Location
Operator Unable to Control Machine
Platform or Boom Caught Overhead
Manual Descent with Engine Running and Electrical Power
Manual Descent with Engine Running but without Electrical Power (Combustion Engines Only)
Manual Descent without Engine and Electrical Power
Outrigger/Track Movement Emergency Procedure:
5.1 Safety Devices Bypass Key Use
Using The Emergency Descent In The Case Of An Outrigger Losing Contact With The Ground
Machine Realignment Emergency Procedure
SECTION 6. GENERAL SPECIFICATIONS AND OPERATOR MAINTENANCE6.1 Introduction
6.2 Operating Specifications
Dimensional Data
Capacities
Engine Data
Lithium-Ion Specifications
Machine Major Component Weights
Performance
6.3 Service/Maintenance
Lubrication
Hydraulic Oil Specifications
Rubber Track Maintenance/Replacement
Wear Pad Inspection
Turntable Attach Bolts
Battery Maintenance and Charging - Gas/AC-Electric
6.4 ELECTRIC MOTOR MAINTENANCE
Electric Motor
6.5 PLATFORM/REMOTE CONTROL SERVICE MENU
Service Button
Menu Input
Errors Menu
Working Hours Menu
Set-up Menu
Joystick Menu
6.6 LITHIUM-ION MACHINE only - additional MAINTAINANCE inFormation
Cleaning the Machine
Battery Pack System Components and Maintenance
Lithium-Ion Machine Fault Codes
BMS Fault Codes - (Battery Management System)
Battery Charger Fault Codes
6.7 Lithium-ION Battery Pack - Handling In Dangerous Conditions
Procedure For Handling Hot Cells
Procedure For Handling Vented Cells
Procedure For Exploded Cells
Lithium Battery Fire
SECTION 7. INSPECTION AND REPAIR LOG
- SuperPac Parts Manual
- StratoLift Parts Manual
