JLG Boom Lift X540AJ X18JP X600AJ X20JP Operation Safety Manual 31223076
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG X540AJ X18JP X600AJ X20JP Boom Lift
Part Number: 31223076
Publication Date: 2025
Number of Pages: 166 Pages
FOREWORD
SAFETY ALERT SYMBOLS AND SAFETY SIGNAL WORDS
REVISION LOG
SECTION 1. SAFETY PRECAUTIONS
Brand: JLG
FOREWORD
REVISION LOG
1.1 GENERAL
1.2 PRE-OPERATION
Operator Training and Knowledge
Workplace Inspection
Machine Inspection
1.3 OPERATION
General
Trip and Fall Hazards
Electrocution Hazards
Tipping Hazards
Crushing and Collision Hazards
1.4 TOWING, LIFTING, AND HAULING
1.5 MAINTENANCE
Maintenance Hazards
Battery Hazards
Long-Term Storage
SECTION 2. PREPARATION AND INSPECTION2.1 PERSONNEL TRAINING
Operator Training
Training Supervision
Operator Responsibility
2.2 PREPARATION, INSPECTION, AND MAINTENANCE
Machine Familiarization
Pre-Start Inspection
Walk-Around Inspection
General
Function Check
SECTION 3. MACHINE CONTROLS, INDICATORS AND OPERATION3.1 Ground Control Station
Ground Control Station - Emergency Boom/Platform Functions
Ground Control Station - Emergency Chassis/Drive Functions
3.2 Platform/Remote Control Station
Platform/Remote Control Station Functions
Remote Control Platform Position Connection
Remote Control Ground Position Connection
Remote Control LCD Display
3.3 Wireless Controller (Radio Control)
Wireless Controller (If Equipped)
SECTION 4. MACHINE OPERATION4.1 DESCRIPTION
4.2 BOOM OPERATING CHARACTERISTICS AND LIMITATIONS
Capacities
Stability
4.3 ENGINE OPERATION
Starting Procedure - Combustion Engine Machine
Shutdown Procedure - Combustion Engine Machine
Starting Procedure - Lithium Machine (Electric)
Shutdown Procedure - Lithium Machine (Electric)
Starting Procedure - Bi-Energy Machine (Combustion Engine Option)
Shutdown Procedure - Bi-Energy Machine (Combustion Engine Option)
Starting Procedure - Bi-Energy Machine (Electric Motor/ Lithium-Ion Option)
Shutdown Procedure - Bi-Energy Machine (Electric Motor/ Lithium-Ion Option)
4.4 BASE AND BOOM/JIB ALIGNMENT
4.5 TRACKS - DRIVING, STEERING AND TRACK WIDTH ADJUST
Track Width Adjust
Traveling (Drive and Steer)
Traveling (Grades and Side Slopes)
Jib Position for Traveling
4.6 OUTRIGGER OPERATION
Setting Outriggers From the Platform/Remote Console
Retracting The Outriggers (Reference Figure 4-5. for item numbers)
4.7 BOOM/PLATFORM OPERATION
Overload Alarm
Raise And Lower The Boom
Telescope The Main Boom
Platform Rotation
Raise And Lower The Jib
Swinging The Boom
(Item 21, Figure 4-2.)
SkyGuard Operation
Manual Descent (Emergency Lowering)
4.8 PLATFORM REMOVAL/INSTALLATION
4.9 BATTERY CHARGING
Charging the Battery Pack
Charge Curve
Cold Weather Charging
Cooling Fans
4.10 SHUT DOWN AND PARK
4.11 LIFTING AND TIE DOWN
Lifting - Outrigger Lifting Rings
Lifting - Fork Lift Pockets
Loading and Unloading the Machine on Transport Vehicles Using Ramps
Tie Down
4.12 MACHINE DECALS
Section 5. EMERGENCY PROCEDURE5.1 General
5.2 Incident Notification
5.3 Emergency Operation
Power Main Cut-Off Switch Location
Operator Unable to Control Machine
Platform or Boom Caught Overhead
5.4 Manual Descent with Power
For Lithium or Combustion Engine Option Machines
For Bi-Energy Option Machines
5.5 Manual Descent Using Hand Pump
Platform Retrieval Sequence
5.6 Bypass Switch - Safety Devices
5.7 Emergency Descent If Outrigger Loses Ground Contact
5.8 Emergency Realignment Procedures
SECTION 6. GENERAL SPECIFICATIONS AND OPERATOR MAINTENANCE6.1 Introduction
6.2 Operating Specifications
Dimensional Data
Chassis Data (Continued)
Capacities
Combustion Engine Data
Lithium-Ion Specifications
Machine Major Component Weights
6.3 Service/Maintenance
Cleaning the Machine
Lubrication
Hydraulic Oil Specifications
Interval - Clean or replace every 500 hours
Interval - Clean every 100 hours
Hydraulic Oil Tank and Filter Cartridge
Rubber Track Maintenance/Replacement
Wear Pad Inspection
Turntable Attach Bolts
Battery Maintenance and Charging - Gas/AC-Electric
6.4 ELECTRIC MOTOR MAINTENANCE
Electric Motor
6.5 PLATFORM/REMOTE CONTROL SERVICE MENU
Service Button
Menu Input
Errors Menu
Working Hours Menu
Set-up Menu
Joystick Menu
6.6 LITHIUM-ION MACHINE only - additional MAINTAINANCE inFormation
Lithium-Ion Machine Fault Codes
BMS Fault Codes - (Battery Management System)
Battery Charger Fault Codes
6.7 Lithium-ION Battery Pack - Handling In Dangerous Conditions
Procedure For Handling Hot Cells
Procedure For Handling Vented Cells
Procedure For Exploded Cells
Lithium Battery Fire
6.8 Supplemental Information Only Applicable to CE Machines (EN280-1:2022)
EC Declaration of Conformity
6.9 Supplemental Information Only Applicable to CE Machines (EN280:2013+A1:2015)
SECTION 7. INSPECTION AND REPAIR LOG
- SuperPac Parts Manual
- StratoLift Parts Manual
