Hyundai
86
176,834
JLG Boom Lift X33JP - X1000AJ Service & Maintenance Manual 3121784 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG X33JP - X1000AJ Boom Lift
Part Number: 3121784
Publication Date: 2025
Number of Pages: 160 Pages
Section 1. Maintenance Safety Precautions
1.1 General​
Disclaimer​
Operation & Safety Manual​
Do Not Operate Tags​
1.2 Safety Information​
Safety Alert System and Signal Words​
1.3 Safety Hazards​
Personal Hazards​
Equipment Hazards​
General Hazards​
Operational Hazards​
1.4 Safety Decals​
1.5 Machine Verification​
Section 2. Specifications
2.1 Operating Specifications​
2.2 Dimensional Data​
2.3 Chassis Data​
2.4 Capacities​
2.5 Engine Data​
2.6 Electric Motor Data​
2.7 Lithium Ion Specifications​
2.8 Major Component Weights​
2.9 Track specifications​
2.10 Functions Speed Range​
Machine Orientation When Performing Speed Tests​
2.11 Hydraulic Pressure Settings - PSI (BAR)​
2.12 Hydraulic Pressure Settings Check​
Equipment and Supplies Required​
Pressure Check Procedure​
2.13 Component maintenance intervals​
Diesel Maintenance Intervals​
Lithium maintenance intervals​
2.14 Lubrication​
Hydraulic Oil​
2.15 Serial Number Location​
2.16 Fastener Torque Charts​
Section 3. General
3.1 Machine Preparation, Inspection, and Maintenance​
General​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
3.2 Service and Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication​
Battery​
Lubrication and Servicing​
3.3 Lubrication and Information​
Hydraulic System​
Hydraulic Oil​
Checking for Leaks in Hydraulic System​
Changing Hydraulic Oil​
Lubrication Specifications​
3.4 Cylinder Drift Test​
Cylinder Drift​
3.5 Pins and Composite Bearing Repair Guidelines​
3.6 Welding on JLG Equipment​
Do the Following When Welding on JLG Equipment​
Do NOT Do the Following When Welding on JLG Equipment​
Section 4. Chassis and Turntable
4.1 Rubber Track Maintenance​
Checking Track Tension​
Adjusting Track Tension​
Checking The Rubber Tracks​
4.2 Rubber Tracks Removal/Installation​
Removing The Rubber Track​
Installing The Rubber Track​
4.3 Undercarrige Maintenance​
4.4 Roller Lower Wheel and Tracks Adjuster Disassembly/Assembly​
Disassembly​
Assembly​
4.5 Sprocket Installation/Removal​
Sprocket Removal​
Sprocket Installation​
4.6 Gear Motor Installation/Removal​
Gear Motor Removal​
Gear Motor Installation​
4.7 Axle Extension Removal​
4.8 Final Drive​
Product Identification​
4.9 Swing Drive (IMO)​
Technical Data – Type Plate​
4.10 Slew Drive​
Structure and Function​
Transporting Unpacked Slew Drive​
Positioning The Swing Drive​
Bolting The Slew Drive​
Maintenance Schedule​
Lubrication​
Maintenance Tasks​
Lubricating The Slew Drive​
4.11 Inspecting The Seals​
4.12 Engine/Motor Options locations​
Combustion Engine Option​
AC Lithium Option​
Bi-Energy Option​
4.13 Kubota Diesel Engine Model D902​
Engine Identification Plate​
Combustion Engine Fuel System​
4.14 Troubleshooting​
Engine Speed Sensor​
Speed Sensor Installation and Adjustment​
Combustion Engine RPM control​
Diesel Actuator Rod Travel Adjustment​
4.15 Combustion Engine Replacement​
4.16 Electric Motor Replacement​
4.17 Lithium Machine with 76V Lithium Battery system​
Charge Information​
Lithium Cells​
Battery Charger​
DC-DC Transformer​
Electric Motor​
RPM Regulation System​
RPM Setting​
Temperature Ongoings (Heaters And Fans)​
Diagnostics And Fault Codes​
Section 5. Boom and Platform
5.1 Tower Boom Microswitch Replacement​
5.2 Main Boom Microswitch Replacement​
Front Side Microswitch Replacement​
Back Side Microwsitch Replacement​
Wire Rope Microswitch Installation​
5.3 Boom Maintenance​
Removal of the Boom Assembly​
Disassembly of the Main Boom​
Inspection​
Assembly of the Main Boom​
Installation of the Boom Assembly​
5.4 Wire Rope and Pulleys​
Inspection​
Three Month Inspection​
Seven Year or 3000 Hours Replacement​
5.5 Ropes Tension Adjustment Procedure​
5.6 Tower Boom Cable Adjustment​
Counterbalance Valve​
5.7 Platform Removal/Installation​
Platform Removal​
Platform Installation​
5.8 Load Cell and Footswitch​
Load Cell Removal​
Load Cell Installation​
5.9 Footswitch​
Footswitch Removal​
Footswitch Installation​
5.10 Platform Rotation Sensor​
Platform Rotation Sensor Removal​
Platform Rotation Sensor Installation​
5.11 Turntable Rotation Sensor​
Removal​
Installation​
5.12 SkyGuard Installation​
Procedure:​
Installation:​
SkyGuard System​
Section 6. Hydraulics
6.1 Main Hydraulic Valve Block Identification and Locations​
6.2 Components​
Safety Valve Block​
Aerial/Ground Electric Valve Deviator (X153)​
Second Speed Electric Valve (X150)​
Pumps Electric Valve (X125)​
Second Pump Pressure Sensor (X141)​
Aerial Dump Valve-Ground (X166)​
Aerial Dump Valve-Jib (X190)​
Ground Valve Block​
6.3 Schematic​
6.4 Hydraulic System Pump and Pressure Lines​
6.5 Ground Component Hydraulic System​
6.6 Outriggers​
6.7 Drive Gear Motors​
6.8 Track Widening​
6.9 Boom Component Hydraulic System​
Tower Boom​
Main Boom​
Telescope​
Jib​
Platform Leveling​
Platform Rotation​
Turn Table Rotation​
6.10 Cylinder Repair​
Specification - Cylinders Overview​
Hydraulic Cylinders Torque Specifications​
Cylinder Repair Equipment And Product List​
Cylinder With Sensor - General Cylinder Disassembly​
Cleanness And Inspection​
Magnetic Sensor Removal​
Threaded Piston Disassembly​
General Cylinder Assembly​
Cylinder Assembling​
Cylinder Repair Without Sensor​
Piston With Nut Disassembling​
Cylinder Assembly​
Seals Head Replacing​
Cylinder Inspection​
Bushing Replacement​
Cylinders Bleeding​
6.11 Replacement Hydraulic Pump​
Pump Removal​
Pump Installation​
6.12 Hydraulic Pump Repair​
Seal Kit Replacement Instruction​
External Components Disassembly​
Second Section Components Disassembly​
Second Section Seals Disassembly​
Second Section Seals Replacement​
First Section Seals Disassembly​
First Section Seals Replacement​
Cover Seals Replacement​
Second Section Components Reassembly​
First Section Components Reassembly​
Final Assembly And Check​
6.13 Hydraulic Component Start-Up Procedures and Recommendations​
6.14 Outriggers Auto-Reaction​
Section 7. JLG Control System
7.1 Introduction​
7.2 Platform - Remote Control Station​
LCD Display Screen​
LCD Display Icon Description​
Only Lithium Icons​
7.3 Diagnostic By Service Menu​
Menu Input​
Only Lithium Input​
Language Menu​
Error Menu​
Working Hours Menu​
Joystick Menu​
7.4 Machine Setup Menu​
Setup - Time​
Setup - Password​
Setup - Date​
Setup - Turn Table Sensor​
Setup - Platform Rotation Sensor​
Setup - Load Cell Board (ECM3) Calibration​
Setup - ACCELER (Calibrating Tilt Sensor)​
Setup - Extra​
7.5 Machine Service Reminder Reset​
7.6 Master Board (ECM1) Replacement and Setting​
New Master Board​
Already Initialized Master Board​
Software Recovery By Modem​
7.7 Code Menu​
Section 8. General Electrical Information & Schematics
8.1 General​
8.2 Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Voltage Measurement​
Resistance Measurement​
Continuity Measurement​
Current Measurement​
Continuity Measurement Over Long Distances​
Requirements:​
Procedure​
8.3 12 Volt Battery​
8.4 Electrical Schematics Manuals​
