JLG Boom Lift X1000AJ X33JP Service & Maintenance Manual 3122569100 2026
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service & Maintenance Manual, Hydraulic Diagram
Model: JLG X1000AJ X33JP Boom Lift
Part Number: 3122569100
Publication Date: 2026
Number of Pages: 312 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsOperating Specifications
Dimensional Data
Chassis Data
Capacities
Engine Data
Electric Motor Data
Lithium Ion Specifications
Major Component Weights
Track Specifications
Functions Speed Range
Hydraulic Pressure Settings - PSI(BAR)
Component Maintenance Intervals
Serial Number Location
Kubota Diesel Engine Model D902
2.14.1 Engine Identification Plate
2.14.2 Combustion Engine Fuel System
Engine/Motor Options Locations
2.15.1 Combustion Engine Option
2.15.2 AC Lithium Option
2.15.3 Bi-Energy Options
Lubrication and Infomration
2.16.1 Hydraulic System
2.16.2 Hydraulic Oil
2.16.3 Checking for Leaks in Hydraulic System
2.16.4 Changing Hydraulic Oil
2.16.5 Lubrication Specifications
Machine Temperature Chart
Fluids and Lubrication
2.18.1 General Information
2.18.2 Hydraulic Oil
Machine Characteristics
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Pins and Composite Bearing Repair Guidelines
Rubber Track Maintenance
3.4.1 Track Tension Check
3.4.2 Track Tension Adjustment
3.4.3 Checking the Rubber Tracks
Tower Boom Cable Adjustment
Ropes Tension Adjustment Procedure
Wire Rope and Pulleys
3.7.1 Wire Rope and Pulleys
3.7.2 Inspection
3.7.3 Three Month Inspection
3.7.4 Seven Year or 3000 Hour Replacement
Lithium Machine With 76V Lithium Battery System
3.8.1 Charge Information
3.8.2 Lithium Cells
3.8.3 Battery Charger
3.8.4 DC-DC Transformer
3.8.5 Electric Motor
3.8.6 RPM Regulation System
3.8.7 RPM Setting
3.8.8 Temperature Ongoings (Heaters And Fans)
3.8.9 Diagnostics and Fault Codes
Tires and Wheels
Hydraulic Filter Replacement
Engine General Inspection
Bio Fuel
Final Drive
Swing Drive (IMO)
3.14.1 Technical Data – Type Plate
Slew Drive
3.15.1 Structure and Function
3.15.2 Transporting Unpacked Slew Drive
3.15.3 Swing Drive Positioning
3.15.4 Bolting the Slew Drive
3.15.5 Maintenance Schedule
3.15.6 Lubrication
3.15.7 Maintenance Tasks
3.15.8 Lubricating the Slew Drive
Inspecting The Seals
3.16.1 Inspecting the Seals
Testing, Calibrations and Special ProceduresHydraulic Pressure Setting Check
General
Multimeter Basics
4.3.1 Multimeter Basics
12 Volt Battery
Troubleshooting
Cylinder Drift Test
System SoftwareIntroduction
Platform Remote Control Station
5.2.1 LCD Display Icon Description
5.2.2 Only Lithium Icons
Diagnostic By Service Menu
Machine Setup Menu
Machine Service Reminder Reset
Master Board (ECM1) Replacement and Setting
Code Menu
Fault CodesFault Codes Introduction
6.1.1 Fault Codes
HydraulicsOutriggers Auto Retraction
Hydraulic Component Start-Up Procedures and Recommendations
Hydraulic System Pump and Pressure Lines
Drive Gear Motors
Boom Component Hydraulic System
Track Widening
Ground Component Hydraulic System
Outriggers
Components
General Information and Safety
Theories of Operation
7.11.1 Cylinders
7.11.2 Valves
Main Hydraulic Valve Block Identification and Locations
Torque Values
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
Removal and InstallationSkyguard Installation
Turntable Rotation Sensor
Platform Rotation Sensor
Load Cell and Footswitch
Platform Removal and Installation
Boom Maintenance
9.6.1 Removal
9.6.2 Inspection
9.6.3 Installation
Replacement Hydraulic Pump
Electric Motor Replacement
Combustion Engine Replacement
Undercarriage Maintenance
Roller Lower Wheel and Tracks Adjuster Disassembly/Assembly
Sprocket and Gear Motor Replacement
Axle Extension Removal
9.13.1 Removal
Tower Boom Microswitch Replacement
9.14.1 Removal
9.14.2 Installation
Main Boom Microswitch Replacement
9.15.1 Front Side Microswitch Replacement
9.15.2 Back Side Microswitch Replacement
9.15.3 Wire Rope Microswitch Replacement
Rubber Tracks Removal and Installation
Disassembly and AssemblyCylinder Repair
Hydraulic Pump Repair
Counterbalance Valve
Boom Disassembly and Assembly
10.4.1 Disassembly
10.4.2 Inspection
10.4.3 Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematic
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
