JLG Boom Lift X1000AJ X33JP Operation Safety Manual 3122569000
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG X1000AJ X33JP Boom Lift
Part Number: 3122569000
Publication Date: 2025
Number of Pages: 180 Pages
FOREWORD
SAFETY ALERT SYMBOLS AND SAFETY SIGNAL WORDS
Section 1. SAFETY PRECAUTIONS
Brand: JLG
FOREWORD
Contact :
In USA:
Outside USA:
REVISION LOGSection 1. SAFETY PRECAUTIONS
1.1 General
1.2 Pre-Operation
Operator Training and Knowledge
Workplace Inspection
Machine Inspection
1.3 Operation
General
Trip and Fall Hazards
Electrocution Hazards
Tipping Hazards
Crushing and Collision Hazards
1.4 Towing, Lifting, and Hauling
1.5 Maintenance
Maintenance Hazards
Battery Hazards (Lead Acid/AGM)
Long-Term Storage
Battery Hazards (Lithium-Ion)
SECTION 2. PREPARATION AND INSPECTION2.1 Personnel Training
Training Supervision
Operator Responsibility
2.2 Preparation, Inspection, and Maintenance
Machine Familiarization
Pre-Start Inspection
Walk-Around Inspection
Function Check
SECTION 3. MACHINE CONTROLS, INDICATORS AND OPERATION3.1 Ground Control Station
Main Menu
Service
Controls
Tower Boom (TOWER)
Main Boom (MAIN)
Extend/Retract Main Boom (EX-MAIN)
Jib (JIB)
Platform Rotate (ROTATE)
Turn Table Rotate (SWING)
Go Home (1)
Operating Speed (2)
Combustion Engine (3)
Electric Motor (4)
Emergency Descent (5)
Bypass Button (6)
3.2 Platform Control Station
Platform Control Functions
Platform/Remote Control Station LCD Display
3.3 WIRELESS CONTROLLER (RADIO CONTROL)
Wireless Controller (If Equipped) See Figure 3-4. Wireless Controller (Radio Control)
Wireless Controller Functions
SECTION 4. MACHINE OPERATION4.1 DESCRIPTION
4.2 BOOM OPERATING CHARACTERISTICS AND LIMITATIONS
Capacities
Stability
4.3 ENGINE OPERATION
Starting Procedure - Combustion Engine Option
Shutdown Procedure - Combustion Engine
Starting Procedure - AC Lithium Option (Electric)
Shutdown Procedure - AC Lithium Option (Electric)
Starting Procedure - Bi-Energy (Combustion Engine Option)
Shutdown Procedure - Bi-Energy (Combustion Engine Option)
Starting Procedure - Bi-Energy (Electric Motor/Lithium- Ion Option)
Shutdown Procedure - Bi-Energy (Electric Motor/Lithium- Ion Option)
4.4 BASE AND BOOM/JIB ALIGNMENT
4.5 TRACKS - DRIVING, STEERING AND TRACK WIDTH ADJUST
Track width adjust
Traveling (Drive and Steer)
Traveling (Grades and Side Slopes)
Jib Position for Traveling
4.6 OUTRIGGER OPERATION
Variable Outrigger Positioning
Operating with Outriggers Set to 32° - Restricted Work Area Of Operation
Setting Outriggers From the Platform/Remote Console
Retracting The Outriggers
4.7 BOOM/PLATFORM OPERATION
Overload Alarm
Platform Level Adjustment
Raise And Lower The Tower Boom
Raise And Lower The Main Boom
Telescope The Main Boom
Platform Rotation
Raise And Lower The Jib
Swinging The Boom
SkyGuard Operation
Platform Removal/Installation
4.8 LITHIUM-ION BATTERY CHARGING
Battery Charging - Daily
Battery Charging Indicators
Charge Curve
Cold Weather Charging
Cooling Fans
4.9 SHUT DOWN AND PARK
4.10 LIFTING AND TIE DOWN
Lifting with a Forklift
Lifting with Slings or Chains
Tie Down
4.11 MACHINE DECALS (X1000AJ)
4.12 MACHINE DECALS (X33JP)
4.13 Dual Side Entry (DSE) PLATFORM DECALS
Section 5. EMERGENCY PROCEDURES5.1 General
5.2 Incident Notification
5.3 Emergency Operation
Power Main Cut-Off Switch Location
Operator Unable to Control Machine
Platform or Boom Caught Overhead
Using Platform Control Box from Platform
5.4 Bypass Key
Using Emergency Descent In Case Of An Outrigger Losing Contact With The Ground
Machine Realignment Emergency Procedure
Movement Of Tracks With Machine Not Aligned:
5.5 LITHIUM-ION BATTERY (IF EQUIPPED)
SECTION 6. GENERAL SPECIFICATIONS AND OPERATOR MAINTENANCE6.1 Introduction
6.2 Operating Specifications
Dimensional Data
Capacities
Combustion Engine Data
Combustion Engine Electrical System Data
Lithium-Ion Battery Pack Data
Major Component Weights
6.3 Service/Maintenance
Cleaning the Machine
Lubrication
Hydraulic Oil Specifications
Engine Air Filter
Engine Oil
Engine Oil Filter (if equipped)
Engine Fuel Filter/Sediment Bowl (if equipped)
Engine Cooling System and Fluid (if equipped)
Hydraulic Oil
Hydraulic Oil Filter Cartridge
Rubber Track Maintenance/Replacement
Wire Cable Inspection
Wire Cable Adjustment
Wear Pad Inspection
Turntable Attach Bolts
Battery Maintenance and Charging - Diesel/AC-Electric
6.4 BATTERY MAINTENANCE AND CHARGING (LITHIUM-ION)
Battery Charging
General Maintenance
6.5 ELECTRIC MOTOR MAINTENANCE
Electric Motor
6.6 PLATFORM CONTROL SERVICE MENU
Service Button
Input Menu
Language Menu Allows you to select preferred language among those available. Errors Menu
Ramps Menu
Current Menu
Working Hours Menu (W. Hours)
Setup Menu
Joystick Menu
Exit Menu
6.7 LITHIUM-ION MACHINE - MAINTENANCE
Battery Pack System Components and Maintenance
Lithium-Ion Machine Fault Codes
BMS Fault Codes - (Battery Management System)
Battery Charger Fault Codes
6.8 Supplemental Information Only Applicable to CE Machines (EN280-1:2022)
EC Declaration of Conformity
SECTION 7. INSPECTION AND REPAIR LOG
- SuperPac Parts Manual
- StratoLift Parts Manual
