Hyundai
86
176,834
JLG Boom Lift TOUCAN 8E to TOUCAN 26E Service & Maintenance Manual 31210465
Brand: JLG
Type of Machine: Boom Lift
Model: JLG
TOUCAN 8E
TOUCAN 20E
TOUCAN 10E
TOUCAN 26E
Part Number: 31210465
Publication Date: 2024
Number of Pages: 188 Pages
Section 1. OPERATING SPECIFICATIONS​
1.1 OPERATING SPECIFICATIONS​
1.2 DIMENSIONAL data​
1.3 PERFORMANCE DATA​
1.4 CAPACITIES​
1.5 COMPONENTS DATA​
1.6 MAJOR COMPONENTS WEIGHTS​
1.7 LUBRICATION​
1.8 TORQUE REQUIREMENTS​
1.9 SERIAL NUMBER LOCATIONS​
1.10 CLEARSKY SMART FLEET™ (IF EQUIPPED)​
Section 2. general service information​
2.1 Machine preparation, inspection and maintenance​
2.2 preventive maintenance and inspection schedule​
2.3 Servicing and maintenance guidelines​
2.4 Lubrication Information​
2.5 Pressure Relief ValVe​
Section 3. THEORY OF OPERATION​
3.1 Overview​
3.2 Modes of operation​
3.3 Can Communications​
3.4 Joysticks​
3.5 Traction​
3.6 Pump/structure movements​
Section 4. CHASSIS MOUNTED COMPONENTS​
4.1 ABM DRIVE MOTORS​
4.2 DANA DRIVE MOTORS​
4.3 Wheels and Tires​
4.3 Steering Linkage​
4.4 Front Wheel Hub​
Section 5. TURNTABLE AND VERTICAL MAST​
5.1 SWING BEARING​
5.2 Swing Motor​
5.3 Rollers​
5.4 Mast and Rollers Setting​
5.5 Lifting chains​
5.6 Pulley - Pulley Support​
5.7 Mast Cylinder Removal and Installation​
Section 6. JIB AND PLATFORM​
6.1 PLATFORM​
6.2 OVERLAOD SYSTEM​
6.3 Jib Cylinder Removal and Installation​
Section 7. HYDRAULICS​
7.1 HYDRAULIC TANK​
7.2 Hydraulic Filter Replacement​
7.3 Hydraulic Power Unit​
7.4 SWING MOTOR​
7.5 CYLINDERS HOLDING VALVES​
7.6 CYLINDER REPAIR​
Section 8. CONTROL COMPONENTS​
8.1 Control components overview​
8.2 Control Components - Service​
8.3 CLEARSKY® LED MOTION / AMBER BEACON (CS550) (IF EQUIPPED)​
8.4 Traction System​
8.5 Power Module​
8.6 Ground Module​
8.7 Ground Control Station​
8.8 Platform Control Station​
Section 9. JLG CONTROL SYSTEM​
9.1 HAND HELD ANALYZER​
9.2 Analyzer screen layout​
9.3 MACHINE SETUP PROGRAMMING INFORMATION​
9.4 CALIBRATION INSTRUCTIONS​
9.5 CALIBRATING STEERING SENSOR​
9.6 CALIBRATING OVERLOAD SYSTEM​
9.7 CALIBRATING THE JOYSTICKS​
9.8 Calibrating the pressure relief valve​
9.9 MACHINE PERSONALITY - ADJUSTMENT SETTINGS​
9.10 SYSTEM TEST​
9.11 CLEARSKY CS550 CONFIGURATION AND TROUBLESHOOTING​
Section 10. DIAGNOSTIC TROUBLE CODES​
10.1 INTRODUCTION​
10.2 DTC INDEX​
10.3 DTC CHECK TABLES​
10.4 ClearSky CSV3 Smart Fleet DTC Fault Codes​
Section 11. GENERAL ELECTRICAL INFORMATION & SCHEMATICS​
11.1 GENERAL​
11.2 Multimeter Basics​
11.3 Checking Switches​
11.4 Applying Silicone Dielectric Compound to Electrical Connections​
11.5 AMP Connector​
11.6 Deutsch Connectors​
11.7 CONNECTORS IDENTIFICATION​
11.8 ELECTRICAL SCHEMATIC 1001311640-A​
11.9 Hydraulic schematic​
