JLG Boom Lift TOUCAN 12E TOUCAN 12E Plus TOUCAN 32E Service & Maintenance Manual 31210537 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG TOUCAN 12E, TOUCAN 12E Plus, TOUCAN 32E Boom Lift
Part Number: 31210537
Publication Date: 2025
Number of Pages: 212 Pages
Section A. INTRODUCTION - MAINTENANCE SAFETY PRECAUTIONS
Brand: JLG
A General
B Hydraulic System Safety
C Maintenance
Section 1. OPERATING SPECIFICATIONS1.1 OPERATING SPECIFICATIONS
1.2 DIMENSIONAL data
1.3 PERFORMANCE DATA
1.4 CAPACITIES
1.5 COMPONENTS DATA
Batteries
Electric Pump / Electric Motor Assembly
Drive Motor Assembly
Swing Drive
Platform Rotation Drive
Cylinders
Tires
1.6 MAJOR COMPONENTS WEIGHTS
1.7 LUBRICATION
Hydraulic Oil
Lubrication Chart
Lube Specifications
1.8 TORQUE REQUIREMENTS
1.9 SERIAL NUMBER LOCATIONS
1.10 CLEARSKY SMART FLEET™ (IF EQUIPPED)
General
ClearSky Smart Fleet™ — Access Control
Section 2. general service information2.1 Machine preparation, inspection and maintenance
General
Preparation, Inspection and Maintenance
Pre-Start Inspection
Pre-Delivery Inspection and Frequent Inspection
Annual Machine Inspection
Preventative Maintenance
2.2 preventive maintenance and inspection schedule
2.3 Servicing and maintenance guidelines
General
Safety and Workmanship
Cleanliness
Components Removal and Installation
Component Disassembly and Reassembly
Pressure-Fit Parts
Bearings
Care and Installation of Teflon Coated Bushings
Bolt Usage and Torque Application
Hydraulic Lines and Electrical Wiring
Welding on Work Platform
Lubrication
Battery
2.4 Lubrication Information
Lubrication Specifications
Hydraulic Oil
Changing Hydraulic Oil
2.5 Pressure Relief ValVe
2.6 Hydraulic cartridge installation
Section 3. THEORY OF OPERATION3.1 OVERVIEW
3.2 Modes of operation
Ground Mode
Platform Mode
3.3 Can Communications
3.4 Joysticks
3.5 Traction
3.6 Pump/structure movements
Lift Up/Down
Swing
Steer
Telescope
Platform Level
Interlocks
Personality Settings and Calibration
Section 4. CHASSIS MOUNTED COMPONENTS4.1 DRIVE MOTORS
Brake - Electrical Characteristics
Brake - Dust Cleaning
Brake Disassembly
Brake Disk Wear Checking
Brake Assembly
Drive Motor Assembly Removal
Drive Motor Assembly Installation
Oil Type & Capacity
Oil Filling
4.2 Wheels and Tires
Tire Wear and Damage
Wheel and Tire Replacement
Wheel Installation
4.3 Steering Linkage
Steer Cylinder
Steering Linkage - Spindle/Hub Assembly
Section 5. TURNTABLE AND VERTICAL MAST5.1 SWING BEARING
Swing Bearing Attach Bolts Check
Swing Bearing Lubrication
Swing Bearing Wear Tolerance Check
Replacement of Swing Bearing
5.2 Swing DRIVE
Swing Drive Removal
Swing Drive Disassembly
Swing Drive Assembly
Swing Drive Installation
5.3 Rollers
Inspection
5.4 Mast and Rollers Setting
Introduction
Procedure
5.5 Lifting chains
Safety Accessories and Tooling
Lubrication
Lifting Chains Inspection
Lifting Chains Rotated
Lifting Chains Removal and Installation
Chain Tension Adjustment
5.6 PULLEY - PULLEY SUPPORT
Pulley Inspection
5.7 Mast Cylinder
Mast Cylinder Removal
Mast Cylinder Disassembly
Mast Cylinder Installation
5.8 Counterweight
Counterweight Removal
Counterweight Installation
Section 6. TELESCOPIC BOOM AND PLATFORM6.1 OVERLOAD SYSTEM
Overload System Verification
Overload System Setting
6.2 PLATFORM
Platform Removal
Platform Installation
6.3 PLATFORM SUPPORTS AND SLAVE CYLINDER
Platform Supports and Slave Cylinder Removal
Slave Cylinder Disassembly
Platform Supports and Slave Cylinder Installation
6.4 TELESCOPIC BOOM, BOOM AND MASTER CYLINDERS
Boom and Cylinders Removal
Boom and Master Cylinders Disassembly
Boom Disassembly
Boom and Cylinders Installation
6.5 TELESCOPE
6.5.1 Telescope Toucan 12E Plus
Telescope Sections and Cylinder Removal
Telescope Dual Cylinder Disassembly
Telescope Sections and Cylinder Installation
6.5.2 Telescope Toucan 12E / Toucan 32E
Telescope Cylinder Disassembly
Section 7. HYDRAULICS7.1 Hydraulic lines Connections
7.2 Hydraulic Power Unit
Ports Identification
Proportional Pressure Relief Valve
Air bleeding
Hand Pump
Proportional Flow Control Valve
Solenoid Valve 4-3
Check Valve 0.5 bar
Electric Motor
7.3 HYDRAULIC TANK
Oil Level
Adding Oil to the System
Tank Draining/Cleaning
Tank Filling
7.4 SECONDARY MANIFOLD
Manifold Schematic
A, B: Counterbalance Valve
C: Check Valve 3 bar
RT-ST/CAV-CAR: Solenoid Valve 4-3
Disassembly
Inspection
Assembly
7.5 cylinders holding valves
Mast Cylinder Holding Valve
Jib Cylinder Holding Valve
Telescope Cylinder Holding Valve
Slave Cylinder Holding Valve
7.6 SWING MOTOR
7.7 CYLINDER REPAIR
Disassembly
Inspection
Assembly
Section 8. CONTROL COMPONENTS8.1 Control components overview
8.2 Control Components - Service
Battery Maintenance and Safety Practices
Main Power Contactor Relay
Power Fuse
Mast Elevation Limit Switch
Jib Elevation Limit Switches
Chain Slack Sensor
Overload Sensor
Drive Orientation Switch
Skyguard Switch
Steering Sensor
Tilt Sensor
8.3 CLEARSKY® LED MOTION / AMBER BEACON (CS550) (IF EQUIPPED)
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
8.4 Traction System
Common Traction System Difficulties
8.5 Power Module
Removal
Installation
Power Module Electrical Evaluation
8.6 Ground Control Station
Ground Module
Membrane Panel
Printed Circuit Board (PCB) Replacement
8.7 Platform Control Station
Upper Control Box - Component Replacement
Upper Control Box - Components Evaluation
Section 9. JLG CONTROL SYSTEM9.1 HAND HELD ANALYZER
Analyzer Menu Structure
Hand Analyzer
Using the Analyzer
Changing the Access Level of the Hand Held Analyzer
Adjusting Parameters Using the Hand Held Analyzer
Machine Setup
9.2 Analyzer screen layout
9.3 MACHINE SETUP PROGRAMMING INFORMATION
9.4 CALIBRATION INSTRUCTIONS
9.5 CALIBRATING STEERING SENSOR
9.6 Calibrating Tilt Sensor
9.7 CALIBRATING OVERLOAD SYSTEM
9.8 CALIBRATING THE JOYSTICKS
9.9 Calibrating the pressure relief valve
9.10 Calibrating the drive motor temperature sensor
9.11 Calibrating the charger
9.12 MACHINE PERSONALITY - ADJUSTMENT SETTINGS
9.13 SYSTEM TEST
9.14 CLEARSKY CS550 CONFIGURATION AND TROUBLESHOOTING
ClearSky Smart FleetTM CS550 Configuration
Troubleshooting
Section 10. DIAGNOSTIC TROUBLE CODES10.1 INTRODUCTION
10.2 DTC INDEX
10.3 DTC CHECK TABLES
0-0 Help Comments
2-1 Power-Up
2-2 Platform Controls
2-3 Ground Controls
2-5 Function Prevented
3-1 Line Contactor Open Circuit
3-2 Line Contactor Short Circuit
3-3 Ground Output Driver
4-2 Thermal Limit
4-4 Battery Supply
4-6 Transmission and Drive System
6-6 Communication
6-7 Accessory
6-8 Functions in Creep or Locked
7-7 Electric Motor
8-1 Tilt Sensor
8-2 Platform Load Sense
8-6 Steering/Axle
8-7 Safety System Override
9-9 Hardware
10.4 ClearSky CSV3 Smart Fleet DTC Fault Codes
Section 11. GENERAL ELECTRICAL INFORMATION & SCHEMATICS11.1 GENERAL
11.2 Multimeter Basics
Grounding
Backprobing
Min/Max
Polarity
Scale
Voltage Measurement
Resistance Measurement
Continuity Measurement
Current Measurement
11.3 Checking Switches
Basic Check
Limit Switches
Automatic Switches
Switch Wiring - Low Side, High Side
11.4 Applying Silicone Dielectric Compound to Electrical Connections
11.5 AMP Connector
Applying Silicone Dielectric Compound to AMP Connectors
Assembly
Disassembly
Wedge Lock
Service - Voltage Reading
11.6 Deutsch Connectors
DT/DTP Series Assembly
DT/DTP Series Disassembly
HD30/HDP20 Series Assembly
HD30/HDP20 Series Disassembly
11.7 CONNECTORS IDENTIFICATION
11.8 ELECTRICAL SCHEMATIC
11.9 Hydraulic schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
