Hyundai
86
176,834
JLG Boom Lift T56-A-14 to T56-A-427 Technical Manual 31200421
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Technical Manual, Electrical and Hydraulic Diagrams
Model: JLG
T56-A-14
T56-A-16
T56-A-425
T56-A-427
Part Number: 31200421
Publication Date: 2024
Number of Pages: 620 Pages
Section 1 Safety Practices​
1.1 Introduction​
1.2 Operation & Safety Manual​
1.3 Training Mechanics as Operators​
1.4 Safety Information​
1.5 Do Not Operate Tags​
1.6 Safety Instructions​
1.7 Safety Decals​
Section 2 General Information, Specifications and Maintenance​
2.1 EIRV Component Terminology​
2.2 Introduction​
2.3 Torques​
2.4 Metric Conversion Factors​
2.5 Specifications​
2.6 Fluids, Lubricants and Capacities​
2.7 Cleaning​
2.8 Replacement​
2.9 Hoses and Tubes​
2.10 Bearings​
2.11 Pressure Testing and Adjustment​
2.12 After Service Startup and Checks​
2.13 Maintenance Instructions​
2.14 Transport​
2.15 Additional Checks​
2.16 Emergency Operations​
Section 3 Boom​
3.1 Boom System Component Terminology​
3.2 Boom System​
3.3 Boom Assembly Maintenance​
3.4 Boom Chains​
3.5 Boom Wear Pads​
3.6 Emergency Retract/Lowering of Boom​
3.7 Quick Attach Assembly​
3.8 Carriage with Hydraulic Jib​
3.9 Troubleshooting​
Section 4 Cab and Covers​
4.1 Operator Cab and Covers Component Terminology​
4.2 Operator Cab​
4.3 Cab Components​
4.4 Cab Removal​
4.5 Cab Installation​
4.6 Covers and Guards​
Section 5 Axles, Wheels and Tires​
5.1 Axle and Wheel Component Terminology​
5.2 Axle Assemblies​
5.3 Wheels and Tires​
Section 6 Transfer Case and Drive Shafts​
6.1 Transfer Case and Drive Shaft Component Terminology​
6.2 General Information​
6.3 Transfer Case​
6.4 Drive Shafts​
6.5 Troubleshooting​
Section 7 Transmission: ZF 4 WG-98 TS​
7.1 Transmission Assembly Component Terminology​
7.2 Transmission Description​
7.3 Transmission Operation​
7.4 Transmission Serial Number​
7.5 Transmission Specifications​
7.6 Transmission Maintenance​
7.7 Transmission Replacement​
7.8 Towing a Disabled Machine​
7.9 Troubleshooting​
Section 8 Engine: Cummins QSB4.5-30-T​
8.1 Introduction​
8.2 Engine Serial Number​
8.3 Specifications and Maintenance Information​
8.4 Standard Practices​
8.5 Engine Cooling System​
8.6 Engine Electrical System​
8.7 Fuel System​
8.8 Engine Exhaust System​
8.9 Engine Replacement​
8.10 Engine Storage​
8.11 Troubleshooting​
Section 9 Hydraulic System​
9.1 Hydraulic Component Terminology​
9.2 Safety Information​
9.3 Specifications​
9.4 Hydraulic Fluid​
9.5 Hoses, Tube Lines, Fittings, Etc.​
9.6 Hydraulic System Testing​
9.7 Hydraulic Circuits and Troubleshooting​
9.8 Steer Indexing Procedures​
9.9 Hydraulic Reservoir​
9.10 Hydraulic System Pump​
9.11 Valves and Manifolds​
9.12 Accumulators​
9.13 Hydraulic Cylinders​
Section 10 Electrical System​
10.1 Electrical Component Terminology​
10.2 Specifications​
10.3 Effective Ground Connections​
10.4 Wiring Harnesses​
10.5 Fuses and Relays​
10.6 Electrical System Troubleshooting​
10.7 Transmission Gear Selection Troubleshooting​
10.8 Dash Panel Warning Indicator Troubleshooting​
10.9 Engine Start Circuit​
10.10 Charging Circuit​
10.11 Electrical System Components​
10.12 Switches and Solenoids​
Section 11 Stabil-TRAK™ System​
11.1 Stabil-TRAK™ System Component Terminology​
11.2 Stabil-TRAK™ Description​
11.3 Stabil-TRAK™ Operation​
11.4 Stabil-TRAK™ Electrical Circuit Operation And Troubleshooting​
11.5 Stabil-TRAK™ Hydraulic Circuit Operation and Troubleshooting​
11.6 Stabil-TRAK™ System Test​
Section 12 Index​
