Hyundai
86
176,834
JLG Boom Lift T500J Service & Maintenance Manual 31221322
Brand: JLG
Type of Machine: Boom Lift
Model: JLG T500J Boom Lift
Part Number: 31221322
Publication Date: 2024
Number of Pages: 350 Pages
Specifications​
Operating Specifications (reference)​
Dimensional Data (reference)​
Capacities​
Electric Power Unit (reference)​
Tires (reference)​
Engine​
Battery (reference)​
Batteries (electric machines) (reference)​
Lubrication (reference)​
Component Weights​
Pressure Settings (reference)​
Maintenance & Lubrication (task)​
Threadlocking Compound (reference)​
Torque Charts (reference)​
General​
Machine Preparation, Inspection, and Maintenance​
Service and Guidelines (task)​
Lubrication and Information (task)​
Cylinder Drift (reference)​
Pins and Composite Bearing Repair Guidelines (task)​
Welding on JLG Equipment (reference)​
Chassis and Turntable​
Breaking-in a New Trailer (task)​
Trailer Inspection and Service Instructions (task)​
Electric Brakes (reference)​
Hydraulic (Surge) Brakes (task)​
Mechanical Brake (task)​
Hubs, Drums, Wheel Bearings (task)​
Tires & Wheels (task)​
Coupler Assembly (task)​
Hitch Coupler & Axle (CE Only) (task)​
Trailer Jack (task)​
Swing Motor (task)​
Swing Bearing (task)​
Engine​
Outrigger Cylinder and Stabilizer (task)​
Outrigger Limit Switches (reference)​
Automatic Leveling Sensing System (concept)​
Procedure for Retracting Outriggers Using Service Harness (O​
Drive & Set (task)​
Wheel Drive (task)​
Drive Motor (task)​
Drive Engage Cylinder (task)​
Batteries (Electric Machines) (task)​
Battery Charger (task)​
Boom and Platform​
Platform and Rotator (task)​
Main Boom Powertrack (task)​
Boom and Cylinder Assembly (task)​
Main Boom Assembly (task)​
Main lift cylinder (task)​
Master Cylinder (task)​
Platform Level Cylinder (task)​
Jib Cylinder (task)​
Boom Sensors (task)​
Boom Cleanliness Guidelines (task)​
Platform Control Enable System (Trigger) (concept)​
Side Entry Platform (concept)​
Hydraulic Manual Descent System (concept)​
Powertrack Maintenance (task)​
Basic Hydraulic Information and Schematics​
Lubricating O-Rings in the Hydraulic System (reference)​
Hydraulic Cylinders (task)​
Hydraulic Pump (Gear)​
Pressure Setting Procedure (task)​
Hydraulic Oil Fill at Startup (task)​
Hydraulic Hoses (concept)​
Hydraulic Filter and Breather (concept)​
Hydraulic Schematics (concept)​
Hydraulic Diagram (concept)​
JLG Control System​
Introduction (reference)​
To Connect the JLG Control System Analyzer (task)​
Changing Access Level (concept)​
Adjust Parameters (reference)​
Machine Setup (reference)​
System Test (task)​
Leveling, Tilt Sensor Calibration (task)​
User Fault Codes (reference)​
Machine Orientation When Setting Speeds (task)​
Basic Electrical Information and Schematics​
General (concept)​
Multimeter Basics (concept)​
Checking Switches (task)​
Applying Silicone Dielectric Compound to Electrical Connecti​
AMP Connector (task)​
Deutsch Connectors (task)​
Electrical Component (reference)​
Electrical Schematics (reference)​
