Hyundai
86
176,834
JLG Boom Lift T350 T500J Parts Catalog 3121199
Brand: JLG
Type of Machine: Boom Lift
Model: JLG T350 T500J Boom Lift
Part Number: 3121199
Publication Date: 2025
Number of Pages: 280 Pages
SECTION 1 - FRAME
FIGURE 1-1. TONGUE JACK INSTALLATIONS (WITH POLY JACK TIRES)​
FIGURE 1-2. TONGUE JACK INSTALLATIONS (WITH PNEUMATIC JACK TIRES)​
FIGURE 1-3. AXLE AND TONGUE INSTALLATION WITH ELECTRIC BRAKES (ANSI, ANSI EXPORT, AUSTRALIAN AND SOUTH AFRICA SPECS)​
FIGURE 1-4. AXLE AND TONGUE INSTALLATION WITH HYDRAULIC BRAKES - WITH 2IN BALL (ANSI, ANSI EXPORT AND AUSTRALIAN SPEC MACHINES)​
FIGURE 1-5. AXLE AND TONGUE INSTALLATION WITH HYDRAULIC BRAKES - WITH 50MM BALL (ANSI EXPORT, AUSTRALIAN AND SOUTH AFRICA SPEC MACHINES)​
FIGURE 1-6. AXLE AND TONGUE INSTALLATION WITH MECHANICAL BRAKES (CE SPEC MACHINES)​
FIGURE 1-7. HYDRAULIC BRAKE COUPLER WITH 2 INCH BALL ASSEMBLY (ANSI AND ANSI EXPORT SPEC MACHINES) (Prior to SN 0030002099)​
FIGURE 1-8. HYDRAULIC BRAKE COUPLER WITH COMBINATION 2 INCH BALL ASSEMBLY (ANSI AND ANSI EXPORT SPEC MACHINES) (Prior to SN 0030002099)​
FIGURE 1-9. HYDRAULIC BRAKE COUPLER WITH COMBINATION 2 INCH BALL ASSEMBLY (ANSI AND ANSI EXPORT SPEC MACHINES) (SN 0030002099 through 0030012032)​
FIGURE 1-10. HYDRAULIC BRAKE COUPLER WITH 2 INCH BALL AND COLLAR ASSEMBLY (ANSI AND ANSI EXPORT SPEC MACHINES) (T350,T500J) (SN 0030010384 through 0030012032)​
FIGURE 1-11. HYDRAULIC BRAKE COUPLER WITH 50MM BALL ASSEMBLY (CE SPEC MACHINES)​
FIGURE 1-12. HYDRAULIC BRAKE COUPLER WITH 50MM BALL ASSEMBLY - T350 (CSA SPEC MACHINES)​
FIGURE 1-13. PARKING BRAKE CABLE (ANSI, ANSI EXPORT AND AUSTRALIAN SPEC MACHINES ONLY) AND TRANSPORT LOCK ASSEMBLIES​
FIGURE 1-14. ELECTRIC BRAKE AND AXLE ASSEMBLY​
FIGURE 1-15. HYDRAULIC BRAKE ASSEMBLY (ANSI AND ANSI EXPORT SPEC MACHINES)​
FIGURE 1-16. MECHANICAL BRAKE ASSEMBLY (CE SPEC MACHINES)​
FIGURE 1-17. CHASSIS DRIVE INSTALLATION (OPTIONAL)​
FIGURE 1-18. DRIVE ENABLE VALVE ASSEMBLY (USED WITH DRIVE OPTION ONLY)​
FIGURE 1-19. DRIVE DIRECTIONAL VALVE ASSEMBLY (USED WITH DRIVE OPTION ONLY)​
FIGURE 1-20. DRIVE MOTOR ASSEMBLY (USED WITH DRIVE OPTION ONLY)​
FIGURE 1-21. CONTROL MODULES AND VALVES INSTALLATION​
FIGURE 1-22. CONTROL VALVE ASSEMBLY (ELECTRIC POWERED MACHINES)​
FIGURE 1-23. CONTROL VALVE ASSEMBLY (GAS POWERED MACHINES)​
FIGURE 1-24. HONDA ENGINE INSTALLATION (GAS POWERED MACHINES)​
FIGURE 1-25. BATTERIES INSTALLATION (ELECTRIC POWERED MACHINES) (Prior to SN 0030001804)​
FIGURE 1-26. BATTERIES INSTALLATION (ELECTRIC POWERED MACHINES) (SN 0030001804 through 0030012032)​
FIGURE 1-27. MAC BATTERY CHARGER ASSEMBLY (ELECTRIC POWERED MACHINES)​
FIGURE 1-28. DELTA-Q AND PRO CHARGING BATTERY CHARGER ASSEMBLIES (ELECTRIC POWERED MACHINES)​
FIGURE 1-29. TAILLIGHTS AND MARKERS INSTALLATION (ANSI AND ANSI EXPORT SPECS)​
FIGURE 1-30. TAILLIGHTS AND MARKERS INSTALLATION (AUSTRALIAN, CE AND SOUTH AFRICA SPECS)​
FIGURE 1-31. SPARE TIRE AND WHEEL CHOCKS INSTALLATIONS (OPTIONAL)​
FIGURE 1-32. FENDERS INSTALLATION​
FIGURE 1-33. FRAME COVERS INSTALLATION​
FIGURE 1-34. OUTRIGGERS INSTALLATION​
FIGURE 1-35. SIDE GUARDS INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. SWING DRIVE AND TURNTABLE BEARING INSTALLATIONS​
FIGURE 2-2. TURNTABLE BEARING ASSEMBLY​
FIGURE 2-3. SWING DRIVE MOTOR ASSEMBLY (WHITE)​
FIGURE 2-4. SWING DRIVE MOTOR ASSEMBLY (PARKER)​
FIGURE 2-5. GROUND CONTROL BOX ASSEMBLY AND INSTALLATION​
FIGURE 2-6. TURNTABLE MOUNTED COMPONENTS (STROBE LIGHT, ALARM AND ACCESSORY TRAY)​
FIGURE 2-7. 2500W GENERATOR INSTALLATION (OPTIONAL) (Prior to SN 0030004340)​
FIGURE 2-8. 3000W GENERATOR INSTALLATION (OPTIONAL) (SN 0030004340 through 0030012032)​
SECTION 3 - BOOM
FIGURE 3-1. BOOM ASSEMBLY AND INSTALLATION (T350)​
FIGURE 3-2. MAIN BOOM ASSEMBLY (T350)​
FIGURE 3-3. BOOM ASSEMBLY AND INSTALLATION (T500J)​
FIGURE 3-4. MAIN BOOM ASSEMBLY (T500J)​
FIGURE 3-5. MATERIAL HOOK INSTALLATION (OPTIONAL)​
SECTION 4 - PLATFORM
FIGURE 4-1. PLATFORM AND ROTATOR INSTALLATIONS​
FIGURE 4-2. PLATFORM ROTATOR ASSEMBLY (OPTIONAL)​
FIGURE 4-3. CONSOLE BOX ASSEMBLY​
SECTION 5 - CYLINDER
FIGURE 5-1. BRAKE RELEASE CYLINDER ASSEMBLY​
FIGURE 5-2. DRIVE ENGAGE CYLINDER ASSEMBLY​
FIGURE 5-3. JIB CYLINDER ASSEMBLY (T500J)​
FIGURE 5-4. PLATFORM LEVEL (SLAVE) CYLINDER ASSEMBLY (T350)​
FIGURE 5-5. PLATFORM LEVEL (SLAVE) CYLINDER ASSEMBLY (T500J)​
FIGURE 5-6. LIFT CYLINDER ASSEMBLY​
FIGURE 5-7. MASTER CYLINDER ASSEMBLY​
FIGURE 5-8. OUTRIGGER CYLINDER ASSEMBLY​
FIGURE 5-9. TELESCOPE CYLINDER ASSEMBLY​
SECTION 6 - HYDRAULIC
FIGURE 6-1. HYDRAULIC DIAGRAM - BOOM AND CHASSIS (ALL SPECS) (T350)​
FIGURE 6-2. HYDRAULIC DIAGRAM - BOOM AND CHASSIS (T500J)​
FIGURE 6-3. HYDRAULIC DIAGRAM - DRIVE AND SET​
FIGURE 6-4. HYDRAULIC DIAGRAM LIST​
SECTION 7 - ELECTRICAL
FIGURE 7-1. ELECTRICAL COMPONENTS INSTALLATION - ELECTRIC POWERED MACHINES (Prior to SN 00300001804)​
FIGURE 7-2. ELECTRICAL COMPONENTS INSTALLATION - ELECTRIC POWERED MACHINES (SN 00300001804 through 0030012032)​
FIGURE 7-3. ELECTRICAL COMPONENTS INSTALLATION - ENGINE POWERED MACHINES​
SECTION 8 - DECALS
FIGURE 8-1. DECAL INSTALLATION (ANSI SPEC) (Prior to SN 0030000281)​
FIGURE 8-2. DECAL INSTALLATION (ANSI SPEC) (SN 0030000281 through 0030012032)​
FIGURE 8-3. DECAL INSTALLATION (COUNTRY SPEC)​
FIGURE 8-4. DECAL INSTALLATION (AUSTRALIAN AND CE SPECS)​
SECTION 9 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK​
SECTION 10 - SPECIAL OPTIONS
FIGURE 10-1. SPECIAL OPTIONS​
PART NUMBER INDEX
