JLG Boom Lift T350, ET350 Service & Maintenance Manual 3122567400 2026
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service & Maintenance Manual, Electric and Hydraulic Diagrams
Model: JLG T350, ET350 Boom Lift
Part Number: 3122567400
Publication Date: 2026
Number of Pages: 350 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Tires
2.1.5 Components Weight
2.1.6 Pressure Settings
2.1.7 Electric Power Unit
2.1.8 Battery
2.1.9 Batteries (Electric Machine)
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 Hydraulic System
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Side Entry Platform
2.5.2 Platform Control Enable System (Trigger)
2.5.3 Boom Sensors
2.5.4 Outrigger Limit Switch
2.5.5 Automatic Leveling Sensing System
2.5.6 Hydraulic Manual Descent System
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventative Maintenance
3.1.7 Major Structural Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Preventative Maintenance
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Wear
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Boom Cleanliness Guidelines
Hydraulic Filter Replacement
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Engine General Inspection
3.10.1 Throttle & Choke Adjustment
3.10.2 Fuel Valve Lever
3.10.3 Checking RPM Level
3.10.4 Choke Actuator
3.10.5 Checking Oil Level
Generator Inspection
Battery Maintenance and Charging
3.12.1 Batteries (Electric Machines)
3.12.2 Quarterly Battery Maintenance
Battery Charger
3.13.1 Operating Instructions
3.13.2 Maintenance Instructions
3.13.3 Battery Charger Fault Codes
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
4.1.4 Checking Switches
Testing Procedures
4.2.1 Test from the Platform
4.2.2 Test from the Ground Station
Calibration Procedures
4.3.1 Leveling, Tilt Sensor Calibration
Special Procedures
4.4.1 Cylinder Drift
4.4.2 Breaking-in a New Trailer
4.4.3 Trailer inspection and Service Instructions
4.4.4 Hydraulic (Surge) Brakes
4.4.5 Mechanical Brake Maintenance
4.4.6 Hubs, Drums and Wheel Bearings
4.4.7 Hydraulic Brake Coupler
4.4.8 Combination Coupler
4.4.9 Coupler Assembly
4.4.10 Procedure for Retracting Outriggers Using Service Harness (Optional)
Swing Drive
System SoftwareLoad Sensing System (LSS)
JLG Analyzer
5.2.1 Introduction
5.2.2 To Connect the JLG Control System Analyzer
5.2.3 Changing Access Level
5.2.4 Adjust Parameter
5.2.5 Machine Setup
5.2.6 Analyzer Software Versions
Analyzer Software Accessibility
5.3.1 Machine Set-Up
5.3.2 Personalities
Function Test
CANBUS Communications
Service Mode
Fault CodesFault Codes Introduction
Engine Diagnostic
Machine Fault Codes
6.3.1 General
6.3.2 System Messages
Machine Diagnostics Parameters
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
7.2.3 Lubricating O-Rings in the Hydraulic System
Hydraulic Components
7.3.1 Hydraulic Oil Fill at Startup
7.3.2 Pressure Setting Procedure
7.3.3 Valves Identification
Torque Values
7.4.1 Cylinder Torque Specification
7.4.2 Valve Torque Specifications
Standard Hydraulic Diagram- Boom And Turntable
7.5.1 Machine
7.5.2 Boom Circuit
Hydraulic Diagram - Chassis
7.6.1 Chassis Circuit – (Electric)
7.6.2 Chassis Circuit – (Gas)
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Installation of Dielectric Grease
8.1.3 Deutsch HD, DT, DTM, DRC Series
8.1.4 AMP Seal
8.1.5 AMP Mate-N-Lok
8.1.6 DIN Connectors
8.1.7 Exclusions
8.1.8 Brad Harrison/phoenix Contact M12
8.1.9 Engine Control Unit Connectors
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Ground Control Module
AMP Connector
8.6.1 Applying Silicone Dielectric Compound to AMP Connectors
8.6.2 Assembly
8.6.3 Disassembly
8.6.4 Wedge Lock
8.6.5 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
Telematics Gateway
Removal and InstallationWheel and Tire
9.1.1 Tire Replacement
9.1.2 Wheel Replacement
9.1.3 Wheel Installation
9.1.4 Lug Nuts (Bolts)
Chassis/Frame Assembly
9.2.1 Axle Assembly
9.2.2 Tongue Installation
9.2.3 Brake Replacement
9.2.4 Hubs, Drums, Wheel Bearings
Boom
9.3.1 Main Boom Powertrack
9.3.2 Boom and Cylinder Assembly
9.3.3 Main Boom Assembly
Platform
9.4.1 Removal
9.4.2 Installation
Hydraulic Cylinders
9.7.1 Outrigger Cylinder and Stabilizer
9.7.2 Main Lift Cylinder
9.7.3 Master Cylinder
9.7.4 Platform Level Cylinder
Hydraulic Valves
Hydraulic Pumps
9.9.1 Hydraulic Pump (Gear)
Electrical Components
9.10.1 Battery
Tilt Sensor
9.11.1 Tilt Sensor
Turntable
9.12.1 Swing Motor
9.12.2 Swing Bearing
Generator and Pulley
Trailer Jack
9.14.1 Installation
9.14.2 Operation
9.14.3 Maintenance
9.14.4 Assembly
Disassembly and AssemblyBoom and Jib Assembly
10.1.1 Main Boom Assembly
Platform
Engine Components
10.3.1 Engine Disassembly, Inspection and Service
10.3.2 Fuel Tank
Pumps
Hydraulic Cylinders
10.5.1 Platform, Lift, Telescope and Master Cylinder
10.5.2 Outrigger Cylinder
Hydraulic Valves
Turntable
10.8.1 Swing Motor
Generator Disassembly and Assembly
Powertrack
10.10.1 Remove Link
10.10.2 Install New Link
10.10.3 Replace Fixed End Brackets
10.10.4 Replace Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
