Hyundai
86
176,834
JLG Boom Lift T350, ET350 Service & Maintenance Manual 31220341 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG T350, ET350 Boom Lift
Part Number: 31220341
Publication Date: 2025
Number of Pages: 350 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires​
2.1.5 Components Weight​
2.1.6 Pressure Settings​
2.1.7 Electric Power Unit​
2.1.8 Battery​
2.1.9 Batteries (Electric Machine)​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 Hydraulic System​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Side Entry Platform​
2.5.2 Platform Control Enable System (Trigger)​
2.5.3 Boom Sensors​
2.5.4 Outrigger Limit Switch​
2.5.5 Automatic Leveling Sensing System​
2.5.6 Hydraulic Manual Descent System​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
3.1.7 Major Structural Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Preventative Maintenance​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Wear​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Boom Cleanliness Guidelines​
Hydraulic Filter Replacement​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
3.9.2 Wear Tolerance​
Engine General Inspection​
3.10.1 Throttle & Choke Adjustment​
3.10.2 Fuel Valve Lever​
3.10.3 Checking RPM Level​
3.10.4 Choke Actuator​
3.10.5 Checking Oil Level​
Generator Inspection​
Battery Maintenance and Charging​
3.12.1 Batteries (Electric Machines)​
3.12.2 Quarterly Battery Maintenance​
Battery Charger​
3.13.1 Operating Instructions​
3.13.2 Maintenance Instructions​
3.13.3 Battery Charger Fault Codes​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
4.1.4 Checking Switches​
Testing Procedures​
4.2.1 Test from the Platform​
4.2.2 Test from the Ground Station​
Calibration Procedures​
4.3.1 Leveling, Tilt Sensor Calibration​
Special Procedures​
4.4.1 Cylinder Drift​
4.4.2 Breaking-in a New Trailer​
4.4.3 Trailer inspection and Service Instructions​
4.4.4 Hydraulic (Surge) Brakes​
4.4.5 Mechanical Brake Maintenance​
4.4.6 Hubs, Drums and Wheel Bearings​
4.4.7 Hydraulic Brake Coupler​
4.4.8 Combination Coupler​
4.4.9 Coupler Assembly​
4.4.10 Procedure for Retracting Outriggers Using Service Harness (Optional)​
Swing Drive​
System Software
Load Sensing System (LSS)​
JLG Analyzer​
5.2.1 Introduction​
5.2.2 To Connect the JLG Control System Analyzer​
5.2.3 Changing Access Level​
5.2.4 Adjust Parameter​
5.2.5 Machine Setup​
5.2.6 Analyzer Software Versions​
Analyzer Software Accessibility​
5.3.1 Machine Set-Up​
5.3.2 Personalities​
Function Test​
CANBUS Communications​
Service Mode​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
Machine Fault Codes​
6.3.1 General​
6.3.2 System Messages​
Machine Diagnostics Parameters​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
7.2.3 Lubricating O-Rings in the Hydraulic System​
Hydraulic Components​
7.3.1 Hydraulic Oil Fill at Startup​
7.3.2 Pressure Setting Procedure​
7.3.3 Valves Identification​
Torque Values​
7.4.1 Cylinder Torque Specification​
7.4.2 Valve Torque Specifications​
Standard Hydraulic Diagram- Boom And Turntable​
7.5.1 Machine​
7.5.2 Boom Circuit​
Hydraulic Diagram - Chassis​
7.6.1 Chassis Circuit – (Electric)​
7.6.2 Chassis Circuit – (Gas)​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.2 Installation of Dielectric Grease​
8.1.3 Deutsch HD, DT, DTM, DRC Series​
8.1.4 AMP Seal​
8.1.5 AMP Mate-N-Lok​
8.1.6 DIN Connectors​
8.1.7 Exclusions​
8.1.8 Brad Harrison/phoenix Contact M12​
8.1.9 Engine Control Unit Connectors​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Ground Control Module​
AMP Connector​
8.6.1 Applying Silicone Dielectric Compound to AMP Connectors​
8.6.2 Assembly​
8.6.3 Disassembly​
8.6.4 Wedge Lock​
8.6.5 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
Telematics Gateway​
Wheel and Tire​
9.1.1 Tire Replacement​
9.1.2 Wheel Replacement​
9.1.3 Wheel Installation​
9.1.4 Lug Nuts (Bolts)​
Chassis/Frame Assembly​
9.2.1 Axle Assembly​
9.2.2 Tongue Installation​
9.2.3 Brake Replacement​
9.2.4 Hubs, Drums, Wheel Bearings​
Boom​
9.3.1 Main Boom Powertrack​
9.3.2 Boom and Cylinder Assembly​
9.3.3 Main Boom Assembly​
Platform​
9.4.1 Removal​
9.4.2 Installation​
Engine​
Transmission​
Hydraulic Cylinders​
9.7.1 Outrigger Cylinder and Stabilizer​
9.7.2 Main Lift Cylinder​
9.7.3 Master Cylinder​
9.7.4 Platform Level Cylinder​
Hydraulic Valves​
Hydraulic Pumps​
9.9.1 Hydraulic Pump (Gear)​
Electrical Components​
9.10.1 Battery​
Tilt Sensor​
9.11.1 Tilt Sensor​
Turntable​
9.12.1 Swing Motor​
9.12.2 Swing Bearing​
Generator and Pulley​
Trailer Jack​
9.14.1 Installation​
9.14.2 Operation​
9.14.3 Maintenance​
9.14.4 Assembly​
Disassembly and Assembly
Boom and Jib Assembly​
10.1.1 Main Boom Assembly​
Platform​
Engine Components​
10.3.1 Engine Disassembly, Inspection and Service​
10.3.2 Fuel Tank​
Pumps​
10.5.1 Platform, Lift, Telescope and Master Cylinder​
10.5.2 Outrigger Cylinder​
Hydraulic Valves​
Turntable​
10.8.1 Swing Motor​
Generator Disassembly and Assembly​
Powertrack​
10.10.1 Remove Link​
10.10.2 Install New Link​
10.10.3 Replace Fixed End Brackets​
10.10.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
