JLG Boom Lift H800AJ Parts Catalog 3121771
Brand: JLG
Type of Machine: Boom Lift
Model: JLG H800AJ Boom Lift
Part Number: 3121771
Publication Date: 2025
Number of Pages: 542 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-2. AXLE INSTALLATION - WITH TOW PACKAGE
FIGURE 1-3. STEER INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION - WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE AND FRAME VALVES INSTALLATION
FIGURE 1-6. DRIVE HUB/BRAKE ASSEMBLY (Prior to SN 0300247156)
FIGURE 1-7. DRIVE HUB/BRAKE ASSEMBLY (SN 0300247156 through 0300270863)
FIGURE 1-8. DRIVE MOTOR ASSEMBLY
FIGURE 1-9. TIRE & WHEEL INSTALLATION - 15-625 NHS FOAM-FILLED
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 18-625 NHS FOAM-FILLED
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 18-625 NHS FOAM-FILLED NON-MARKING (Prior to SN 0300247156)
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 18-625 NHS FOAM-FILLED NON-MARKING (SN 0300247156 through 0300270863)
FIGURE 1-13. FRAME SHIELDS INSTALLATION
FIGURE 1-14. TOW PACKAGE INSTALLATION (OPTIONAL) (ANSI, ANSI EXPORT AND CHINA SPECS)
SECTION 2 - TURNTABLEFIGURE 2-1. VALVES INSTALLATION - WITHOUT LSS
FIGURE 2-2. VALVES INSTALLATION - WITH LSS
FIGURE 2-3. MAIN VALVE ASSEMBLY (Prior to SN 0300247156)
FIGURE 2-4. MAIN VALVE ASSEMBLY (SN 0300247156 through 0300270863)
FIGURE 2-5. BRAKE/2 SPEED VALVE ASSEMBLY
FIGURE 2-6. SWING DRIVE INSTALLATION
FIGURE 2-7. SWING MOTOR/HUB ASSEMBLY (Prior to SN 0300268294)
FIGURE 2-8. SWING MOTOR/HUB ASSEMBLY (SN 0300268294 through 0300270863)
FIGURE 2-9. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-10. TURNTABLE LOCK INSTALLATION
FIGURE 2-11. ROTARY COUPLING INSTALLATION
FIGURE 2-12. TANKS INSTALLATION
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY
FIGURE 2-14. FUEL TANK ASSEMBLY
FIGURE 2-15. COOLER INSTALLATION
FIGURE 2-16. BATTERY BOXES INSTALLATION
FIGURE 2-17. BATTERY CHARGERS INSTALLATION (FACTORY SUPPLIED 220V PLUG)
FIGURE 2-18. BATTERY CHARGERS INSTALLATION (CUSTOMER SUPPLIED PLUG)
FIGURE 2-19. ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-20. IMG CONTROL BOX ASSEMBLY
FIGURE 2-21. ELECTRICAL ASSEMBLY - 12V FUSE BOX (H800AJ)
FIGURE 2-22. GROUND CONTROL BOX ASSEMBLY (H800AJ)
FIGURE 2-23. GROUND CONTROL PANEL DECAL INSTALLATION (WITHOUT MSSO)
FIGURE 2-24. GROUND CONTROL PANEL DECAL INSTALLATION (WITH MSSO)
FIGURE 2-25. ALARM INSTALLATION
FIGURE 2-26. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL)
FIGURE 2-27. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL) (Prior to SN 0300259698)
FIGURE 2-28. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL) (SN 0300259698 through 0300270863)
FIGURE 2-29. STROBE LIGHT INSTALLATION - RED (OPTIONAL) (Prior to SN 0300259698)
FIGURE 2-30. STROBE LIGHT INSTALLATION - RED (OPTIONAL) (SN 0300259698 through 0300270863)
FIGURE 2-31. HEAT SHIELD AND ACCESS PANELS INSTALLATION
FIGURE 2-32. HOODS INSTALLATION
FIGURE 2-33. HOOD ASSEMBLY - TANK SIDE
FIGURE 2-34. HOOD ASSEMBLY - ENGINE SIDE
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION
FIGURE 3-2. ENGINE AND PUMPS SUB-ASSEMBLY (Prior to SN 0300259343)
FIGURE 3-3. ENGINE AND PUMPS SUB-ASSEMBLY (SN 0300259343 through 0300270863)
FIGURE 3-4. ENGINE AND TRAY ASSEMBLY (Prior to SN 0300259343)
FIGURE 3-5. ENGINE AND TRAY ASSEMBLY (SN 0300259343 through 0300270863)
FIGURE 3-6. ENGINE AND GENERATOR ASSEMBLY (Prior to SN 0300259343)
FIGURE 3-7. ENGINE AND GENERATOR ASSEMBLY (SN 0300259343 through 0300270863)
FIGURE 3-8. ENGINE AND CLUTCH ASSEMBLY (Prior to SN 0300259343)
FIGURE 3-9. ENGINE AND CLUTCH ASSEMBLY (SN 0300259343 through 0300270863)
FIGURE 3-10. ENGINE FAN MOUNTING ASSEMBLY (H800AJ)
FIGURE 3-11. KUBOTA ENGINE COMPONENTS (Prior to SN 0300259343)
FIGURE 3-12. KUBOTA ENGINE COMPONENTS (SN 0300259343 through 0300270863)
FIGURE 3-13. GENERATOR ASSEMBLY
FIGURE 3-14. VARIABLE PUMP ASSEMBLY
FIGURE 3-15. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-16. FUEL/WATER SEPARATOR ASSEMBLY
FIGURE 3-17. ENGINE HOOD BAFFLES INSTALLATION
FIGURE 3-18. TRAY JACK INSTALLATION (H800AJ)
FIGURE 3-19. 4000W GENERATOR INSTALLATION - 220V/50HZ (OPTIONAL)
FIGURE 3-20. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (OPTIONAL)
FIGURE 3-21. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (OPTIONAL)
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDER INSTALLATION (Prior to SN 0300261401)
FIGURE 4-2. BOOM AND CYLINDER INSTALLATION (SN 0300261401 through 0300270863)
FIGURE 4-3. JIB ASSEMBLY (SN 0300261401 through 0300270863)
FIGURE 4-4. MAIN BOOM ASSEMBLY
FIGURE 4-5. TOWER BOOM ASSEMBLY
FIGURE 4-6. ROTATOR ASSEMBLY
FIGURE 4-7. POWER TRACK INSTALLATION - MAIN BOOM
FIGURE 4-8. POWER TRACK INSTALLATION - TOWER BOOM
FIGURE 4-9. BOOM VALVES INSTALLATION - WITHOUT LSS
FIGURE 4-10. BOOM VALVES INSTALLATION - WITH LSS
FIGURE 4-11. BOOM VALVE ASSEMBLY
FIGURE 4-12. BOOM VALVE AND LIMIT SWITCHES INSTALLATION
FIGURE 4-13. TILT SENSOR INSTALLATION
FIGURE 4-14. TRANSPORT POSITION SWITCH INSTALLATION (CE SPECS)
FIGURE 4-15. PLATFORM SUPPORT INSTALLATION - WITHOUT LSS
FIGURE 4-16. PLATFORM SUPPORT INSTALLATION - WITH LSS
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) WITH SWING GATE
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) WITH DROP BAR
FIGURE 5-5. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA & CSA SPECS)
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST
FIGURE 5-11. TRAY ASSEMBLY
FIGURE 5-12. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (Prior to SN 0300259698)
FIGURE 5-13. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (SN 0300259698 through 0300270863)
FIGURE 5-14. CONSOLE BOX ASSEMBLY (Prior to SN 0300259698)
FIGURE 5-15. CONSOLE BOX ASSEMBLY (SN 0300259698 through 0300270863)
FIGURE 5-16. LIGHT PANEL INSTALLATION
FIGURE 5-17. JIB SWITCH INSTALLATION
FIGURE 5-18. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 5-19. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 5-20. FOOTSWITCH ASSEMBLY
FIGURE 5-21. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM (OPTIONAL)
FIGURE 5-22. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (OPTIONAL)
FIGURE 5-23. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM (OPTIONAL)
FIGURE 5-24. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (OPTIONAL)
FIGURE 5-25. SKYEYE INSTALLATION
FIGURE 5-26. SKYGUARD INSTALLATION (Prior to SN 0300259698)
FIGURE 5-27. SKYGUARD BAR INSTALLATION (SN 0300259698 through 0300270863)
FIGURE 5-28. SKYGLAZIER INSTALLATION (ANSI, ANSI EXPORT, AUSTRALIAN & CSA SPECS)
FIGURE 5-29. SKYLINE INSTALLATION
FIGURE 5-30. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-31. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-32. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-33. WELDER ASSEMBLY
FIGURE 5-34. PIPE RACK INSTALLATION (ANSI AND CSA SPECS ONLY)
FIGURE 5-35. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)
FIGURE 5-36. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)
FIGURE 5-37. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)
SECTION 6 - CYLINDERFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSMBLY
FIGURE 6-2. LEVEL (SLAVE) CYLINDER ASSEMBLY - JIB (Prior to SN 0300247156)
FIGURE 6-3. LEVEL (SLAVE) CYLINDER ASSEMBLY - JIB (SN 0300247156 through 0300270863)
FIGURE 6-4. LEVEL (SLAVE) CYLINDER ASSEMBLY - UPRIGHT (Prior to SN 0300247156)
FIGURE 6-5. LEVEL (SLAVE) CYLINDER ASSEMBLY - UPRIGHT (SN 0300247156 through 0300261401)
FIGURE 6-6. LEVEL (SLAVE) CYLINDER ASSEMBLY - UPRIGHT (SN 0300261402 through 0300270863)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (Prior to SN 0300247156)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (SN 0300247156 through 0300270863)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - MAIN BOOM (Prior to SN 0300247156)
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN 0300247156 through 0300261401)
FIGURE 6-11. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN 0300261402 through 0300270863)
FIGURE 6-12. LIFT CYLINDER ASSEMBLY - TOWER BOOM (Prior to SN 0300247156)
FIGURE 6-13. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN 0300247156 through 0300261401)
FIGURE 6-14. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN 0300261402 through 0300270863)
FIGURE 6-15. MASTER CYLINDER ASSEMBLY (Prior to SN 0300247156)
FIGURE 6-16. MASTER CYLINDER ASSEMBLY (SN 0300247156 through 0300270863)
FIGURE 6-17. STEER CYLINDER ASSEMBLY
FIGURE 6-18. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (Prior to SN 0300247156)
FIGURE 6-19. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (SN 0300247156 through 0300270863)
FIGURE 6-20. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM (Prior to SN 0300247156)
FIGURE 6-21. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM (H800AJ) (SN 0300247156 through 0300270863)
SECTION 7 - HYDRAULICFIGURE 7-1. AXLE LOCKOUT HYDRAULIC DIAGRAM
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM
FIGURE 7-3. STANDARD HYDRAULIC DIAGRAM
FIGURE 7-4. TOW HYDRAULIC DIAGRAM
FIGURE 7-5. HYDRAULIC DIAGRAM LIST
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL DIAGRAM LIST
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPECS) (MACHINES WITHOUT 4000W GENERATOR)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPECS) (MACHINES WITHOUT 4000W GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 POST GROUND (CE SPECS) (MACHINES WITHOUT 4000W GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 POST GROUND (CE SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 SIDE GROUND (CE SPECS) (MACHINES WITHOUT 4000W GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 SIDE GROUND (CE SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE SPECS) (MACHINES WITHOUT 4000W GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (ANSI EXPORT, AUSTRALIAN, CHINA & JAPANESE SPECS)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V RECEPTACLE (WITH 4000W GENERATOR) (ALL SPECS EXCEPT ANSI & CSA SPECS)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 240V RECEPTACLE (WITH 7500W SKYPOWER GENERATOR) (ANSI & CSA SPECS)
FIGURE 8-17. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT ANSI & CSA SPECS)
FIGURE 8-18. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-19. AC BREAKER BOX INSTALLATION - WITH 2 BREAKERS (CE SPECS WITHOUT 4000W GENERATOR) (Prior to SN 0300247156)
FIGURE 8-20. AC BREAKER BOX INSTALLATION - WITH 2 BREAKERS (CE SPECS WITH 4000W GENERATOR) (SN 0300247156 through 0300270863)
FIGURE 8-21. AC BREAKER BOX INSTALLATION - WITH 2 BREAKERS (BRAZIL SPECS)
FIGURE 8-22. AC BREAKER BOX INSTALLATION - WITH 3 BREAKERS (CE SPECS WITH 4000W GENERATOR)
FIGURE 8-23. BATTERY CABLES INSTALLATION
FIGURE 8-24. BATTERY STACK HARNESS (LH)
FIGURE 8-25. BATTERY STACK HARNESS (RH)
FIGURE 8-26. BOOM VALVE HARNESS
FIGURE 8-27. BOOM CABLES INSTALLATION (MACHINES WITHOUT GENERATOR)
FIGURE 8-28. BOOM CABLES INSTALLATION (AUSTRALIAN SPECS WITH 4000W GENERATOR)
FIGURE 8-29. BOOM CABLES INSTALLATION (CE SPECS WITH 4000W GENERATOR)
FIGURE 8-30. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA & JAPANESE SPECS WITH 7500W GENERATOR)
FIGURE 8-31. BOOM CABLES INSTALLATION (AUSTRALIAN & CE SPECS WITH 7500W GENERATOR)
FIGURE 8-32. BOOM CABLE - MAIN BOOM
FIGURE 8-33. BOOM CABLE - TOWER BOOM
FIGURE 8-34. BREAKER BOX KIT - WITH 2 BREAKERS (CE SPECS WITHOUT 4000W GENERATOR & BRAZIL SPECS)
FIGURE 8-35. BREAKER BOX KIT - WITH 2 BREAKERS (CE SPECS WITH 4000W GENERATOR) (H800AJ)
FIGURE 8-36. BREAKER BOX KIT - WITH 3 BREAKERS (CE SPECS WITH 4000W GENERATOR)
FIGURE 8-37. CHARGER HARNESS
FIGURE 8-38. CONTROL HARNESS
FIGURE 8-39. ELECTRICAL SYSTEM INSTALLATION
FIGURE 8-40. ENGINE HARNESS - KUBOTA
FIGURE 8-41. ENGINE TRAY HARNESS
FIGURE 8-42. GENERATOR HARNESS - 4000W
FIGURE 8-43. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-44. GENERATOR HARNESS - 4000W AND 7500W SKYPOWER
FIGURE 8-45. GROUND CONTROL BOX HARNESS
FIGURE 8-46. H-BRIDGE/CLUTCH HARNESS
FIGURE 8-47. HYBRID 84V HARNESS
FIGURE 8-48. MAIN VALVE HARNESS
FIGURE 8-49. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-50. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)
FIGURE 8-51. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)
FIGURE 8-52. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE SPEC)
FIGURE 8-53. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE SPEC)
FIGURE 8-54. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)
FIGURE 8-55. RESOLVER/CONVERTER/INVERTER HARNESS
FIGURE 8-56. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-57. SKYEYE RECEIVER HARNESS
FIGURE 8-58. SKYEYE EMITTER HARNESS
FIGURE 8-59. SKYLINE HARNESS
FIGURE 8-60. STROBE LIGHT CONTROL HARNESS (BLUE & RED LIGHTS)
FIGURE 8-61. TURNTABLE HARNESS
FIGURE 8-62. TURNTABLE/FUSE PANEL HARNESS
FIGURE 8-63. PLATFORM INTERFACE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS (ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPECS (ENGLISH LANGUAGE)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (ENGLISH/PORTUGUESE LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION - CE SPECS (ENGLISH LANGUAGE)
FIGURE 9-5. DECAL INSTALLATION - CHINA SPECS (ENGLISH/CHINESE LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPECS (ENGLISH/JAPANESE LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN LANGUAGES)
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/SPANISH LANGUAGES)
FIGURE 9-10. DECALS INSTALLATION - OPTIONS
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
