Hyundai
86
176,834
JLG Boom Lift EC660SJ Service & Maintenance Manual 3122551800 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC660SJ Boom Lift
Part Number: 3122551800
Publication Date: 2026
Number of Pages: 684 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Electrical Data​
2.1.4 Battery Monitoring Specifications​
2.1.5 Tires​
2.1.6 Critical Stability Weights​
2.1.7 Torque Requirements​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Ground Control Keyswitch System​
2.5.2 Platform Control Enable System​
2.5.3 Drive System​
2.5.4 Drive Orientation System​
2.5.5 Function Speed Control System​
2.5.6 Oscillating Axle System​
2.5.7 Electronic Platform Leveling​
2.5.8 Chassis Tilt Indicator System​
2.5.9 Platform Load Sensing System (LSS)​
2.5.10 Auxiliary Power System​
2.5.11 Tires and Counterweight​
2.5.12 Platform​
2.5.13 Wire Rope Break Indicator​
2.5.14 Transport Position Sensing System​
2.5.15 Beyond Transport - Drive Speed Cutback System​
2.5.16 Drive/Steer – Boom Function Interlock System​
2.5.17 Dual Capacity System​
2.5.18 Ground Panel Display​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Inspection Schedules​
3.3.2 Maintenance Schedules​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Boom Inspection and Maintenance​
3.6.1 Wire Rope Tensioning Procedure​
3.6.2 Wire Rope​
3.6.3 Boom Cleanliness Guidelines​
3.6.4 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.7.1 Hydraulic Filter Removal​
3.7.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
3.8.1 Turntable Bearing Mounting Bolt Condition Check​
3.8.2 Wear Tolerance​
Battery Packs​
3.9.1 Battery Monitoring System​
3.9.2 Troubleshooting Battery Packs​
Battery Maintenance​
3.10.1 Battery Maintenance (Daily)​
3.10.2 Battery Maintenance (Quarterly)​
3.10.3 Battery Additional Maintenance Recommendations​
3.10.4 Battery Charging - On Board Charger​
3.10.5 Over-Charging/High Battery Temperature​
Battery Charger​
3.11.1 General Information​
3.11.2 Battery Charging System Components​
3.11.3 AC Cable​
3.11.4 Battery Charger User Interface​
3.11.5 LED Indicators​
3.11.6 Operating Instructions​
3.11.7 Battery Charger Alarm Visualization​
3.11.8 Maintenance Instructions​
Electric Motor​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
SkyGuard​
4.2.1 Operation​
4.2.2 Function Test​
4.2.3 Diagnostics and Troubleshooting​
4.2.4 Fault Codes​
Load Sensing System​
4.3.1 Preparation​
4.3.2 Testing LSS Control System Warnings and Interlocks​
4.3.3 Testing LSS Control System Capacity Indication​
4.3.4 Testing LSS Platform Load Reading with Calibrated Weights​
4.3.5 Testing LSS Platform Load Reading with a Known Weight​
Performing Machine Tests​
4.4.1 Test from the Platform​
4.4.2 Test from the Ground Station​
Calibration Preparation​
4.5.1 JLG Analyzer​
4.5.2 Calibration Preparation​
Load Sensing System Calibration​
Tilt Sensor Calibration​
Boom Angle Calibration​
Level Up Crackpoint Calibration​
Level Down Crackpoint Calibration​
Platform Angle Sensor Calibration​
Steer Calibration​
Special Procedures​
4.13.1 Emergency Boom Lowering Procedure​
4.13.2 Drive Cutout Override Service Mode​
4.13.3 Cylinder Checking Procedure​
4.13.4 Cylinder Drift​
4.13.5 Hydraulic Circuits​
4.13.6 Hydraulic Pressure Settings and Adjustments​
4.13.7 Hydraulic Pressures​
4.13.8 Oscillating Axle Bleeding Procedure and Lockout Test​
Wheel Drive Hub​
Swing Drive​
System Software
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Mobile Analyzer​
5.2.4 Analyzer Software Versions P2.29​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostic​
5.3.3 Machine Set-Up​
Machine Configuration Programming Settings​
Personalities​
5.5.1 Machine Personality Settings and Function Speed​
Function Test​
CANBUS Communications​
Service Mode​
5.8.1 Load Sensing System​
5.8.2 Drive Cutout Override​
Fault Codes
Fault Codes Introduction​
Machine Fault Codes​
6.2.1 General​
6.2.2 LSS Troubleshooting​
6.2.3 System Test Messages​
Machine Diagnostics Parameters​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Hydraulic Pump Pre-Fill Procedure​
7.3.3 Main Control Valve Pressure Setting​
7.3.4 Platform Control Valve Pressure Setting Procedure​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Standard Hydraulic Diagram - Boom And Turntable​
7.5.1 2WS​
7.5.2 4WS​
Hydraulic Diagram - Chassis​
7.6.1 4WD 2WS​
7.6.2 4WD 4WS​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Ground Control Module Pin Connections​
8.5.2 Platform Control Module Pin Connections​
Wiring Harness and Connector Label Diagrams​
8.6.1 Connector Labels​
8.6.2 Component Labels​
Telematics Gateway​
8.7.1 Telematics-Ready (TCU) Plug​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Front and Rear Axle Assembly​
9.2.3 Drive Hub and Motor​
9.2.4 Knuckle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Main Boom Assembly​
9.3.5 Boom Sensors​
9.3.6 Jib and Rotator Assembly​
Platform​
9.4.1 Platform Support​
9.4.2 Bolt-On External Fall Arrest​
Electric Motor​
9.5.1 Removal​
9.5.2 Installation​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Boom Lift Cylinder​
9.7.2 Platform Level Cylinder​
9.7.3 Steer Cylinder​
9.7.4 Jib Lift Cylinder​
9.7.5 Axle Lockout Cylinder​
Hydraulic Valves​
9.8.1 Platform Valve​
9.8.2 Main Control Valve​
9.8.3 Traction Control Valve​
9.8.4 Axle Valve​
Hydraulic Pumps​
9.9.1 Drive Pump​
9.9.2 Function Pump​
Electrical Components​
9.10.1 Battery (Electric Motor Side)​
9.10.2 Battery Pack (Hydraulic Tank Side)​
Turntable​
9.11.1 Swing Drive​
9.11.2 Rotary Coupling​
9.11.3 Swing Bearing​
9.11.4 Counterweight​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
Boom and Jib Assembly​
10.2.1 Main Boom Assembly​
10.2.2 Rotator Assembly​
Platform​
Pumps​
10.4.1 Function Pump​
10.4.2 Drive Pump​
Main Lift Cylinder​
Jib Lift Cylinder​
Steer Cylinder​
Telescope Cylinder​
Hydraulic Valves​
10.12.1 Hydraulic Oil Tank​
Turntable​
10.13.1 Swing Motor​
10.13.2 Rotary Coupling​
10.13.3 Rotary Coupling Seal Kit​
Powertrack​
10.14.1 Remove Link​
10.14.2 Install New Link​
10.14.3 Replace Fixed End Brackets​
10.14.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
