Hyundai
86
178,635
JLG Boom Lift EC600SJ, H600SJ, EC600SJP, H600SJP Service & Maintenance Manual 3122558900 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC600SJ, H600SJ, EC600SJP, H600SJP Boom Lift
Part Number: 3122558900
Publication Date: 2026
Number of Pages: 678 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Batteries​
2.1.4 Tires​
2.1.5 Major Component Weights​
2.1.6 Torque Requirements​
2.1.7 Battery Charger Specifications​
Machine Temperature Chart​
Serial Number Location (concept)​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Ground Control Keyswitch System​
2.5.2 Platform Control Enable System​
2.5.3 Side Entry Platform​
2.5.4 Drive Orientation System​
2.5.5 Function Speed Control System​
2.5.6 Transport Position Interlock System​
2.5.7 Above Elevation (Above Horizontal) Cutout System​
2.5.8 Dual Capacity System​
2.5.9 Platform Load Control System​
2.5.10 All-Wheel Drive​
2.5.11 Automatic Traction Control System​
2.5.12 Oscillating Axle System​
2.5.13 Positive Opening Switch Systems​
2.5.14 Generator Charging Set​
2.5.15 Sustained Involuntary Operation (SIO) Protection​
2.5.16 Chassis Tilt Indicator System​
Clearsky Smart Fleet (If Equipped)​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Check Daily​
3.3.2 First 50 Hours​
3.3.3 Every 150 Hours or 3 Months​
3.3.4 Every 6 Months or 300 Hours​
3.3.5 Every 1200 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Boom Cleanliness Guidelines​
3.7.2 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
3.9.2 Wear Tolerance​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Glow Plugs​
3.10.3 Replacing Engine Oil​
3.10.4 Replacing the Oil Filter​
3.10.5 Replacing the Primary Fuel Filters​
Battery Maintenance and Charging​
3.11.1 Battery Maintenance, Quarterly​
3.11.2 Optional On Board Generator​
3.11.3 Battery Charging (On Board Charger)​
Battery Charger​
3.12.1 Operating Instructions​
3.12.2 Battery Charger Fault Codes​
3.12.3 Excessive Battery Watering Requirements or Strong Sulphur (Rotten Egg) Smell​
3.12.4 Checking/Changing the Battery Charger Algorithm​
Generator​
3.13.1 Engine​
3.13.2 Alternator​
3.13.3 Dynamo and Dynamo Voltage Regulator​
3.13.4 Dynamo Output Fuse​
3.13.5 Control Fuse​
3.13.6 Start Battery​
3.13.7 Engine Starter​
3.13.8 Start Control Relay​
3.13.9 Fuel Control Relay​
3.13.10 Glow Plug Control Relay​
3.13.11 Glow Plug​
3.13.12 Fuel Pump​
3.13.13 Fuel Solenoid​
3.13.14 Engine Low Oil Pressure Switch​
3.13.15 Engine Oil Temperature Sensor​
3.13.16 Alternator Output Current Sensor​
3.13.17 Engine Speed Sensor​
3.13.18 RBS Engine/Generator Controller​
3.13.19 Warnings and Safety Precautions​
3.13.20 System Controls​
3.13.21 System Status and Performance Monitoring​
3.13.22 System Settings​
3.13.23 RBS Start​
3.13.24 RBS shutdown​
3.13.25 RBS Alarms and Flash Codes​
3.13.26 Resetting the RBS Controller​
3.13.27 Maintenance Schedule​
3.13.28 Troubleshooting​
3.13.29 APU Engine Start Battery Boosting​
Supplementary Fuse for APU​
3.14.1 Tools and Material​
3.14.2 Procedure​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
4.2.4 Troubleshooting​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Calibrating Tilt Sensor​
4.3.5 Calibrating Steer​
4.3.6 Calibrating Load Sensing​
4.3.7 Calibration of Motor (with New ZAPI Module)​
Special Procedures​
4.4.1 Drive Cutout Override Service Mode​
4.4.2 Fuel Tank Cleaning and Drying​
4.4.3 Cylinder Checking Procedure​
4.4.4 Cylinder Drift​
4.4.5 Hydraulic Circuits​
4.4.6 Hydraulic Pressure Settings and Adjustments​
4.4.7 Hydraulic Pressures​
4.4.8 Oscillating Axle Bleeding Procedure and Lockout Test​
Wheel Drive Hub​
4.5.1 Roll and Leak Testing​
4.5.2 Tightening and Torquing Bolts​
Swing Drive​
4.6.1 Roll, Leak and Brake Testing​
4.6.2 Tightening and Torquing Bolts​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Using the Analyzer​
5.2.4 Changing the Access Level of the Hand Held Analyzer​
5.2.5 Adjusting Parameters Using the Hand Held Analyzer​
5.2.6 Machine Setup​
5.2.7 Level Vehicle Description​
5.2.8 Analyzer Flow Chart​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostic​
5.3.3 Machine Set-Up​
5.3.4 Machine Personality Settings​
5.3.5 Operator Tools​
5.3.6 Calibrations​
Function Test​
5.4.1 Test Notes​
CANBUS Communications​
Service Mode​
5.6.1 Load Sensing System​
5.6.2 Drive Cutout Override​
5.7.1 ClearSky Smart FleetTM CS550 Configuration​
5.7.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Machine Fault Codes​
6.2.1 General​
6.2.2 ClearSky CSV3 Smart Fleet DTC Fault Codes​
6.2.3 LSS Troubleshooting​
6.2.4 System Self Test​
ClearSky CS550 Troubleshooting Procedures​
Machine Diagnostics Parameters​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Pressure Setting​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Standard Hydraulic Diagram- Boom And Turntable​
7.5.1 2WD​
Hydraulic Diagram - Chassis​
7.6.1 4WD​
7.6.2 2WD Oscillating Axle​
7.6.3 Tow​
7.6.4 4WD Oscillating Axle​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Ground Control Module Pin Connections​
8.5.2 Platform Control Module Pin Connections​
8.5.3 Platform Control Module — UL​
AMP Connector​
8.6.1 Assembly​
8.6.2 Disassembly​
8.6.3 Wedge Lock​
8.6.4 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
8.7.1 Connector Labels​
8.7.2 Component Labels​
Telematics Gateway​
8.8.1 Telematics-Ready (TCU) Plug​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Front and Rear Axle Assembly​
9.2.3 Drive Hub and Drive Motor/Brake Assembly​
9.2.4 Spindle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Boom Maintenance​
9.3.5 Jib and Rotator Assembly​
9.3.6 Swing Jib and Rotator Assembly​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform Support (Traditional Design)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
9.4.4 Bolt-On External Fall Arrest​
Engine Generator​
9.5.1 Component Terminology​
9.5.2 Engine Generator Replacement (H600SJ/H600SJP Only)​
9.5.3 Starter​
9.5.4 Fuel Tank (H600SJ/H600SJP Only)​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Boom Telescope Cylinder​
9.7.2 Main Boom Lift Cylinder​
9.7.3 Master Cylinder​
9.7.4 Slave Cylinder​
9.7.5 Platform Level Cylinder​
9.7.6 Jib Lift Cylinder​
9.7.7 Axle Lockout Cylinder​
9.7.8 Steer Cylinder​
Hydraulic Valves​
9.8.1 Platform Valve​
9.8.2 Main Control Valve​
9.8.3 Drive Valve​
9.8.4 Axle Lockout Valve​
Hydraulic Pumps​
Electrical Components​
9.10.1 Battery Box and Battery​
Battery Charger​
9.11.1 Battery Charger (Delta Q)​
9.11.2 Battery Charger (Green Power)​
Turntable​
9.12.1 Replacement of Swing Bearing​
9.12.2 Counterweight​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
10.1.3 Spindle, 2WD​
Boom and Jib Assembly​
10.2.1 Main Boom Assembly​
10.2.2 Platform Rotator​
10.2.3 Jib Rotator​
Platform​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Pumps​
10.5.1 Function Pump​
10.5.2 Drive Pump​
10.6.1 Axle Lockout Cylinder​
10.6.2 Slave Cylinder​
10.6.3 Jib Lift Cylinder​
10.6.4 Main Lift Cylinder​
10.6.5 Master Cylinder​
10.6.6 Steer Cylinder​
10.6.7 Telescope Cylinder​
Hydraulic Valves​
10.8.1 Hydraulic Oil Tank​
Turntable​
10.9.1 Swing Motor​
Generator Disassembly and Assembly​
Powertrack​
10.11.1 Remove Link​
10.11.2 Install New Link​
10.11.3 Replace Fixed End Brackets​
10.11.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
