JLG Boom Lift EC600SJ EC600SJP H600SJ H600SJP Parts Manual 3122559000
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC600SJ, EC600SJP, H600SJ, H600SJP Boom Lift
Part Number: 3122559000
Publication Date: 2025
Number of Pages: 664 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED (2WD)
FIGURE 1-2. AXLE INSTALLATION - FIXED (4WD)
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING WITHOUT TOW PACKAGE (2WD) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-4. AXLE INSTALLATION - OSCILLATING WITHOUT TOW PACKAGE (2WD) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-5. AXLE INSTALLATION - OSCILLATING WITHOUT TOW PACKAGE (2WD) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-6. AXLE INSTALLATION - OSCILLATING WITH TOW PACKAGE (2WD)
FIGURE 1-7. AXLE INSTALLATION - OSCILLATING (4WD) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-8. AXLE INSTALLATION - OSCILLATION (4WD) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-9. AXLE INSTALLATION - OSCILLATION (4WD) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-10. AXLE LOCKOUT VALVE ASSEMBLY
FIGURE 1-11. AXLE LOCKOUT VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-12. AXLE LOCKOUT VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-13. STEER INSTALLATION (2WD/2WS) (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-14. STEER INSTALLATION (2WD/2WS) (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-15. STEER INSTALLATION (2WD/2WS) (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-16. STEER INSTALLATION (2WD/2WS) (WITH TOW PACKAGE)
FIGURE 1-17. STEER INSTALLATION (4WD/2WS) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 1-18. STEER INSTALLATION (4WD/2WS) (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 1-19. STEER INSTALLATION (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJ,H600SJ)
FIGURE 1-20. STEER INSTALLATION (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJP,H600SJP)
FIGURE 1-21. STEER INSTALLATION (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ)
FIGURE 1-22. STEER INSTALLATION (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJP)
FIGURE 1-23. NON-DRIVE HUB ASSEMBLY - LH (2WD FRONT)
FIGURE 1-24. NON-DRIVE HUB ASSEMBLY - RH (2WD FRONT)
FIGURE 1-25. WHEEL DRIVE INSTALLATION (MACHINES WITH SN STARTING WITH 03) (ALL SPECS EXCEPT UL SPEC)
FIGURE 1-26. WHEEL DRIVE INSTALLATION (MACHINES WITH SN STARTING WITH 03) (UL SPEC) (EC600SJ,EC600SJP)
FIGURE 1-27. WHEEL DRIVE INSTALLATION (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-28. WHEEL DRIVE INSTALLATION (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-29. AC DRIVE ELECTRICAL PLATE ASSEMBLY (ALL SPECS EXCEPT UL SPEC)
FIGURE 1-30. AC DRIVE ELECTRICAL PLATE ASSEMBLY (UL SPEC) (EC600SJ,EC600SJP)
FIGURE 1-31. DRIVE HUB ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-32. DRIVE HUB ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-33. DRIVE HUB ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-34. DRIVE MODULE PLATE ASSEMBLY
FIGURE 1-35. DRIVE MOTOR ASSEMBLY (4WD FRONT)
FIGURE 1-36. DRIVE MOTOR ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-37. DRIVE MOTOR ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-38. DRIVE MOTOR ASSEMBLY (REAR) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-39. DRIVE VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-40. DRIVE VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 1-41. DRIVE VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 1-42. FRAME SHIELDS INSTALLATION
FIGURE 1-43. TIRE AND WHEEL INSTALLATION - 36/14LL X 22.5 FOAM-FILLED NON-MARKING
FIGURE 1-44. TIRE AND WHEEL INSTALLATION - 355/55D625 FOAM FILLED (EC600SJ,EC600SJP)
FIGURE 1-45. TOW PACKAGE INSTALLATION - WITHOUT NATO EYE
FIGURE 1-46. TOW PACKAGE INSTALLATION - WITH NATO EYE
SECTION 2 - TURNTABLEFIGURE 2-1. MAIN CONTROL VALVE INSTALLATION (EC600SJ,H600SJ)
FIGURE 2-2. MAIN CONTROL VALVE INSTALLATION (EC600SJP,H600SJP)
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-4. SWING DRIVE INSTALLATION
FIGURE 2-5. SWING MOTOR ASSEMBLY
FIGURE 2-6. TURNTABLE BEARING, STOP AND LUBE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-7. TURNTABLE BEARING, STOP AND LUBE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-8. TURNTABLE LOCK INSTALLATION
FIGURE 2-9. DRIVE ORIENTATION INSTALLATION
FIGURE 2-10. HYDRAULIC TANK AND PUMP/MOTOR INSTALLATION (MACHINES WITH SN STARTING WITH 03) (ALL SPECS EXCEPT UL SPEC)
FIGURE 2-11. HYDRAULIC TANK AND PUMP/MOTOR INSTALLATION (MACHINES WITH SN STARTING WITH 03) (UL SPEC) (EC600SJ,EC600SJP)
FIGURE 2-12. HYDRAULIC TANK AND PUMP/MOTOR INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-14. ELECTRIC MOTOR ASSEMBLY
FIGURE 2-15. FUEL TANK AND ENGINE MODULE INSTALLATION - WITH STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 2-16. FUEL TANK AND ENGINE MODULE INSTALLATION - WITH AGM BATTERIES (H600SJ,H600SJP)
FIGURE 2-17. ALARM INSTALLATION
FIGURE 2-18. BATTERY CHARGER INSTALLATION - GREEN POWER CHARGER (EC600SJ,EC600SJP)
FIGURE 2-19. BATTERY CHARGER INSTALLATION - SMART CHARGER (110V/60HZ)
FIGURE 2-20. BATTERY CHARGER INSTALLATION - SMART CHARGER (120V-240V/50-60HZ)
FIGURE 2-21. BATTERY CHARGER INSTALLATION - SMART CHARGER (250V/50HZ)
FIGURE 2-22. BATTERY BOX INSTALLATION - METAL LATCH - AGM BATTERIES (390 AMP HOUR)
FIGURE 2-23. BATTERY BOX INSTALLATION - METAL LATCH - STANDARD BATTERIES (415 AMP HOUR) (EC600SJ,EC600SJP)
FIGURE 2-24. BATTERY BOX INSTALLATION - RUBBER LATCH - AGM BATTERIES (390 AMP HOUR)
FIGURE 2-25. BATTERY BOX INSTALLATION - RUBBER LATCH - AGM BATTERIES (400 AMP HOUR)
FIGURE 2-26. BATTERY BOX INSTALLATION - RUBBER LATCH - STANDARD BATTERIES (415 AMP HOUR)
FIGURE 2-27. BEACON LIGHT INSTALLATION - AMBER (EC600SJ,EC600SJP)
FIGURE 2-28. ENGINE CONTROLS INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 2-29. ENGINE CONTROLS INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
FIGURE 2-30. GROUND CONTROL ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-31. GROUND CONTROL PANEL INSTALLATION (EC600SJ,H600SJ)
FIGURE 2-32. GROUND CONTROL PANEL INSTALLATION (EC600SJP,H600SJP)
FIGURE 2-33. HOODS INSTALLATION
FIGURE 2-34. INVERTER INSTALLATION - 120V 2000W
FIGURE 2-35. INVERTER INSTALLATION - 240V 2000W
FIGURE 2-36. LIMIT SWITCH INSTALLATION
FIGURE 2-37. WHITE NOISE ALARM INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE AND GENERATOR INSTALLATION - WITH STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 3-2. ENGINE AND GENERATOR INSTALLATION - WITH AGM BATTERIES (H600SJ,H600SJP)
FIGURE 3-3. KUBOTA ENGINE ASSEMBLY (H600SJ,H600SJP)
FIGURE 3-4. KUBOTA ENGINE COMPONENTS (H600SJ,H600SJP)
FIGURE 3-5. EXHAUST STACK AND HOOD BAFFLES INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 3-6. EXHAUST STACK AND HOOD BAFFLES INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 4-2. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJ,H600SJ)
FIGURE 4-3. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ)
FIGURE 4-4. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 4-5. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJP,H600SJP)
FIGURE 4-6. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJP)
FIGURE 4-7. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 4-8. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJ,H600SJ)
FIGURE 4-9. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ)
FIGURE 4-10. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 4-11. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJP,H600SJP)
FIGURE 4-12. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJP)
FIGURE 4-13. POWER TRACK ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-14. POWER TRACK ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 4-15. POWER TRACK ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 4-16. JIB ROTATOR ASSEMBLY (EC600SJP,H600SJP)
FIGURE 4-17. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 4-18. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (EC600SJ,H600SJ)
FIGURE 4-19. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 4-20. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (EC600SJP,H600SJP)
FIGURE 4-21. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 4-22. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJ,H600SJ)
FIGURE 4-23. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 4-24. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJP,H600SJP)
FIGURE 4-25. BOOM VALVE INSTALLATION (EC600SJ,H600SJ)
FIGURE 4-26. BOOM VALVE INSTALLATION (EC600SJP,H600SJP)
FIGURE 4-27. BOOM VALVE ASSEMBLY (EC600SJ,H600SJ)
FIGURE 4-28. BOOM VALVE ASSEMBLY (EC600SJP,H600SJP)
FIGURE 4-29. BOOM LIMIT SWITCH INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. RAPID REPLACEABLE PLATFORM - 30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-2. RAPID REPLACEABLE PLATFORM - 30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-3. RAPID REPLACEABLE PLATFORM - 30IN X 6FT (76.2CM X 1.83M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-4. RAPID REPLACEABLE PLATFORM - 30IN X 6FT (76.2CM X 1.83M) (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-5. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-6. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-7. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,EC600SJP)
FIGURE 5-8. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH B3) (EC600SJ,EC600SJP)
FIGURE 5-9. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,EC600SJP)
FIGURE 5-10. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) (MACHINES WITH SN STARTING WITH B3) (EC600SJ,EC600SJP)
FIGURE 5-11. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,EC600SJP)
FIGURE 5-12. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH B3) (EC600SJ,EC600SJP)
FIGURE 5-13. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,EC600SJP)
FIGURE 5-14. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (MACHINES WITH SN STARTING WITH B3) (EC600SJ,EC600SJP)
FIGURE 5-15. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-16. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-17. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-18. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-19. PLATFORM CONSOLE AND FOOTSWITH INSTALLATION - 2WD (NON UL)
FIGURE 5-20. PLATFORM CONSOLE AND FOOTSWITH INSTALLATION - 2WD (UL) (EC600SJ,EC600SJP)
FIGURE 5-21. PLATFORM CONSOLE AND FOOTSWITH INSTALLATION - 4WD (NON UL)
FIGURE 5-22. PLATFORM CONSOLE AND FOOTSWITH INSTALLATION - 4WD (UL) (EC600SJ,EC600SJP)
FIGURE 5-23. PLATFORM CONSOLE AND FOOTSWITH ASSEMBLEY - 2WD (NON UL)
FIGURE 5-24. PLATFORM CONSOLE AND FOOTSWITH ASSEMBLEY - 2WD (UL) (EC600SJ,EC600SJP)
FIGURE 5-25. PLATFORM CONSOLE AND FOOTSWITH ASSEMBLEY - 4WD (NON UL)
FIGURE 5-26. PLATFORM CONSOLE AND FOOTSWITCH ASSEMBLY - 4WD (UL) (EC600SJ,EC600SJP)
FIGURE 5-27. FOOTSWITCH ASSEMBLY
FIGURE 5-28. ENGINE CONTROLS INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 5-29. ENGINE CONTROLS INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
FIGURE 5-30. FALL ARREST INSTALLATION (30IN X 4FT/76CM X 1.22M PLATFORM)
FIGURE 5-31. FALL ARREST INSTALLATION (30IN X 6FT/76CM X 1.82M PLATFORM)
FIGURE 5-32. FALL ARREST INSTALLATION (36IN X 6FT/91.5CM X 1.82M PLATFORM)
FIGURE 5-33. FALL ARREST INSTALLATION (36IN X 8FT/91.5CM X 2.44M PLATFORM) (EC600SJ,H600SJ)
FIGURE 5-34. JIB ROTATE SWITCH INSTALLATION (EC600SJP,H600SJP)
FIGURE 5-35. LIGHT PANEL INSTALLATION
FIGURE 5-36. PLATFORM BEACON INSTALLATION
FIGURE 5-37. SKYGLAZIER INSTALLATION (ENGLISH LANGUAGE DECALS)
FIGURE 5-38. SKYGLAZIER INSTALLATION (SPANISH/ENGLISH LANGUAGE DECALS)
FIGURE 5-39. SKYGLAZIER INSTALLATION (SPANISH/PORTUGUESE LANGUAGE DECALS)
FIGURE 5-40. SKYLINE INSTALLATION
FIGURE 5-41. SOFT TOUCH INSTALLATION (WITHOUT FALL ARREST) (EC600SJ,H600SJ)
FIGURE 5-42. SOFT TOUCH INSTALLATION (WITH FALL ARREST) (EC600SJ,H600SJ)
FIGURE 5-43. SOFT TOUCH OVERHEAD SENSORS INSTALLATION
FIGURE 5-44. USB CHARGER INSTALLATION
FIGURE 5-45. TRAY ASSEMBLY
SECTION 6 - CYLINDERSFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN
FIGURE 6-6. MASTER CYLINDER ASSEMBLY
FIGURE 6-7. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-8. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 6-9. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (FIXED)
FIGURE 7-2. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (2WD)
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD) (MACHINES WITH SN STARTING WITH 03)
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (4WD) (MACHINES WITH SN STARTING WITH B3)
FIGURE 7-6. HYDRAULIC DIAGRAM - STANDARD (EC600SJ,H600SJ)
FIGURE 7-7. HYDRAULIC DIAGRAM - STANDARD (EC600SJP,H600SJP)
FIGURE 7-8. HYDRAULIC DIAGRAM - TOW
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM - LOCALLY SUPPLIED COMPONENTS
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2IN X 4IN BOX
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2IN X 4IN BOX
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH DUAL AC CABLE (EC600SJP,H600SJP)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V DUPLEX RECEPTACLE
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-13. BATTERY BOX CABLE ASSEMBLY (RH SIDE BOX) (STANDARD BATTERIES)
FIGURE 8-14. BATTERY BOX CABLE ASSEMBLY (LH SIDE BOX) (STANDARD BATTERIES)
FIGURE 8-15. BATTERY BOX CABLE ASSEMBLY (AGM BATTERIES) (390 AMP HOUR)
FIGURE 8-16. BATTERY BOX CABLE ASSEMBLY (AGM BATTERIES) (400 AMP HOUR)
FIGURE 8-17. BOOM CABLE - LOWER (WITHOUT AC CABLE) (EC600SJ,EC600SJP)
FIGURE 8-18. BOOM CABLE - LOWER (WITH AC CABLE OR DUAL AC BOXES) (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-19. BOOM CABLE - LOWER (WITH AC CABLE OR DUAL AC BOXES) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC)
FIGURE 8-20. BOOM CABLE - LOWER (WITH AC CABLE) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 8-21. BOOM CABLE - UPPER (WITHOUT AC CABLE) (EC600SJ)
FIGURE 8-22. BOOM CABLE - UPPER (WITHOUT AC CABLE) (EC600SJP)
FIGURE 8-23. BOOM CABLE - UPPER (WITH AC CABLE) (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 8-24. BOOM CABLE - UPPER (WITH AC CABLE) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJ,H600SJ)
FIGURE 8-25. BOOM CABLE - UPPER (WITH AC CABLE) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ)
FIGURE 8-26. BOOM CABLE - UPPER (WITH AC CABLE OR DUAL AC BOXES) (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 8-27. BOOM CABLE - UPPER (WITH AC CABLE OR DUAL AC BOXES) (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJP,H600SJP)
FIGURE 8-28. BOOM CABLE - UPPER (WITH AC CABLE) (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJP)
FIGURE 8-29. BOOM VALVE HARNESS
FIGURE 8-30. BREAKER BOX KIT - WITH ONE BREAKER (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-31. BREAKER BOX KIT - WITH ONE BREAKER (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-32. BREAKER BOX KIT - WITH TWO BREAKERS
FIGURE 8-33. CABLES AND CLAMPS INSTALLATION - WITHOUT AC CABLE (EC600SJ)
FIGURE 8-34. CABLES AND CLAMPS INSTALLATION - WITHOUT AC CABLE (EC600SJP)
FIGURE 8-35. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 8-36. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CHINA SPEC) (EC600SJ,H600SJ)
FIGURE 8-37. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ)
FIGURE 8-38. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (AUSTRALIAN, CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 8-39. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH 03) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 8-40. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 8-41. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJP)
FIGURE 8-42. CABLES AND CLAMPS INSTALLATION - WITH DUAL AC BOXES (EC600SJP,H600SJP)
FIGURE 8-43. CHARGER CORD PLUG INSTALLATION - 110V IEC YELLOW
FIGURE 8-44. CHARGER CORD PLUG INSTALLATION - 220V (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 8-45. CHARGER CORD PLUG INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS)
FIGURE 8-46. CHARGER CORD PLUG INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-47. CHARGER CORD PLUG INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-48. CHARGER CORD PLUG INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-49. CHARGER DC CONNECTION HARNESS
FIGURE 8-50. CHARGER HARNESS
FIGURE 8-51. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-52. DRIVE CABLE KIT (MACHINES WITH SN STARTING WITH 03) (ALL SPECS EXCPET UL SPEC)
FIGURE 8-53. DRIVE CABLE KIT (MACHINES WITH SN STARTING WITH 03) (UL SPEC) (EC600SJ,EC600SJP)
FIGURE 8-54. DRIVE CABLE KIT (MACHINES WITH SN STARTING WITH B3) (ALL SPECS EXCPET CHINA SPEC)
FIGURE 8-55. DRIVE CABLE KIT (MACHINES WITH SN STARTING WITH B3) (CHINA SPEC) (EC600SJ,EC600SJP)
FIGURE 8-56. GENERATOR HARNESS (H600SJ,H600SJP)
FIGURE 8-57. GROUND CONTROL HARNESS
FIGURE 8-58. INVERTER HARNESS (110V)
FIGURE 8-59. INVERTER HARNESS (220V)
FIGURE 8-60. INVERTER IGNITION HARNESS
FIGURE 8-61. LED CABLE
FIGURE 8-62. LIMIT SWITCH CABLE
FIGURE 8-63. LOWER VALVE HARNESS
FIGURE 8-64. PLATFORM BEACON HARNESS
FIGURE 8-65. PLATFORM CONSOLE HARNESS
FIGURE 8-66. RECEPTACLE BOX KIT - 110V IEC YELLOW (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-67. RECEPTACLE BOX KIT - 220V IEC BLUE (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-68. RECEPTACLE BOX KIT - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-69. SKYLINE HARNESS
FIGURE 8-70. STEER HARNESS
FIGURE 8-71. TRACTION HARNESS
FIGURE 8-72. TRACTION TO TURNTABLE HARNESS
FIGURE 8-73. TRANSPORT BOOM HARNESS
FIGURE 8-74. TURNTABLE HARNESS
FIGURE 8-75. USB HARNESS
FIGURE 8-76. WHITE NOISE MOTION ALARM HARNESS
FIGURE 8-77. WORK LIGHTS HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION (ENGLISH LANGUAGE) (ANSI, ANSI EXPORT, CSA & UL SPECS)
FIGURE 9-2. DECAL INSTALLATION (ENGLISH LANGUAGE) (AUSTRALIAN, CE & UK CA SPECS)
FIGURE 9-3. DECAL INSTALLATION (CHINESE/ENGLISH LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION (FRENCH/ENGLISH LANGUAGES)
FIGURE 9-5. DECAL INSTALLATION (JAPANESE LANGUAGE)
FIGURE 9-6. DECAL INSTALLATION (KOREAN LANGUAGE)
FIGURE 9-7. DECAL INSTALLATION (PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION (SPANISH/ENGLISH LANGUAGES)
FIGURE 9-9. DECALS INSTALLATION - OPTIONS
FIGURE 9-10. FALL ARREST DECALS INSTALLATION (EC600SJ,H600SJ)
FIGURE 9-11. TOW BAR DECAL INSTALLATION (ENGLISH LANGUAGE)
FIGURE 9-12. TOW BAR DECAL INSTALLATION (SPANISH LANGUAGE))
FIGURE 9-13. TOW BAR DECAL INSTALLATION(SPANISH/ENGLISH LANGUAGES)
FIGURE 9-14. TOW BAR DECAL INSTALLATION (PICTURE ONLY)
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
